staging: lustre: osc: Use !x to check for kzalloc failure
Author: Julia Lawall <Julia.Lawall@lip6.fr>
!x is more normal for kzalloc failure in the kernel.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
expression x;
statement S1, S2;
x = kzalloc(...);
if (
- x == NULL
+ !x
 ) S1 else S2
Signed-off-by: Julia Lawall
 drivers/staging/lustre/lustre/osc/osc_dev.c     | 2 +-
 drivers/staging/lustre/lustre/osc/osc_request.c | 4 ++--
 2 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/staging/lustre/lustre/osc/osc_dev.c b/drivers/staging/lustre/lustre/osc/osc_dev.c
index 9222c9f..91fdec4 100644
--- a/drivers/staging/lustre/lustre/osc/osc_dev.c
+++ b/drivers/staging/lustre/lustre/osc/osc_dev.c
@@ -218,7 +218,7 @@ static struct lu_device *osc_device_alloc(const struct lu_env *env,
 	int rc;
 	od = kzalloc(sizeof(*od), GFP_NOFS);
-	if (od == NULL)
+	if (!od)
 		return ERR_PTR(-ENOMEM);
 	cl_device_init(&od->od_cl, t);
diff --git a/drivers/staging/lustre/lustre/osc/osc_request.c b/drivers/staging/lustre/lustre/osc/osc_request.c
index f84b4c7..96c80e9 100644
--- a/drivers/staging/lustre/lustre/osc/osc_request.c
+++ b/drivers/staging/lustre/lustre/osc/osc_request.c
@@ -119,7 +119,7 @@ static int osc_packmd(struct obd_export *exp, struct lov_mds_md **lmmp,
 	if (*lmmp == NULL) {
 		*lmmp = kzalloc(lmm_size, GFP_NOFS);
-		if (*lmmp == NULL)
+		if (!*lmmp)
 			return -ENOMEM;
@@ -1909,7 +1909,7 @@ int osc_build_rpc(const struct lu_env *env, struct client_obd *cli,
 		mpflag = cfs_memory_pressure_get_and_set();
 	crattr = kzalloc(sizeof(*crattr), GFP_NOFS);
-	if (crattr == NULL) {
+	if (!crattr) {
 		rc = -ENOMEM;
 		goto out;
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
