staging: lustre: osc: Use kzalloc and kfree
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Replace OBD_ALLOC, OBD_ALLOC_WAIT, OBD_ALLOC_PTR, and OBD_ALLOC_PTR_WAIT by
kalloc/kcalloc, and OBD_FREE and OBD_FREE_PTR by kfree.
A simplified version of the semantic patch that makes these changes is as
follows: (http://coccinelle.lip6.fr/)
@@ expression ptr,size; @@
- OBD_ALLOC(ptr,size)
+ ptr = kzalloc(size, GFP_NOFS)
@@ expression ptr, size; @@
- OBD_FREE(ptr, size);
+ kfree(ptr);
Signed-off-by: Julia Lawall
 drivers/staging/lustre/lustre/osc/osc_dev.c     |  4 +--
 drivers/staging/lustre/lustre/osc/osc_request.c | 33 +++++++++++++------------
 2 files changed, 19 insertions(+), 18 deletions(-)
diff --git a/drivers/staging/lustre/lustre/osc/osc_dev.c b/drivers/staging/lustre/lustre/osc/osc_dev.c
index 4935fc7..ce5c3af 100644
--- a/drivers/staging/lustre/lustre/osc/osc_dev.c
+++ b/drivers/staging/lustre/lustre/osc/osc_dev.c
@@ -204,7 +204,7 @@ static struct lu_device *osc_device_free(const struct lu_env *env,
 	struct osc_device *od = lu2osc_dev(d);
 	cl_device_fini(lu2cl_dev(d));
-	OBD_FREE_PTR(od);
+	kfree(od);
 	return NULL;
@@ -217,7 +217,7 @@ static struct lu_device *osc_device_alloc(const struct lu_env *env,
 	struct obd_device *obd;
 	int rc;
-	OBD_ALLOC_PTR(od);
+	od = kzalloc(sizeof(*od), GFP_NOFS);
 	if (od == NULL)
 		return ERR_PTR(-ENOMEM);
diff --git a/drivers/staging/lustre/lustre/osc/osc_request.c b/drivers/staging/lustre/lustre/osc/osc_request.c
index d7a9b65..7ddf46b 100644
--- a/drivers/staging/lustre/lustre/osc/osc_request.c
+++ b/drivers/staging/lustre/lustre/osc/osc_request.c
@@ -110,7 +110,7 @@ static int osc_packmd(struct obd_export *exp, struct lov_mds_md **lmmp,
 		return lmm_size;
 	if (*lmmp != NULL && lsm == NULL) {
-		OBD_FREE(*lmmp, lmm_size);
+		kfree(*lmmp);
 		*lmmp = NULL;
 		return 0;
 	} else if (unlikely(lsm != NULL && ostid_id(&lsm->lsm_oi) == 0)) {
@@ -118,7 +118,7 @@ static int osc_packmd(struct obd_export *exp, struct lov_mds_md **lmmp,
 	if (*lmmp == NULL) {
-		OBD_ALLOC(*lmmp, lmm_size);
+		*lmmp = kzalloc(lmm_size, GFP_NOFS);
 		if (*lmmp == NULL)
 			return -ENOMEM;
@@ -157,19 +157,20 @@ static int osc_unpackmd(struct obd_export *exp, struct lov_stripe_md **lsmp,
 		return lsm_size;
 	if (*lsmp != NULL && lmm == NULL) {
-		OBD_FREE((*lsmp)->lsm_oinfo[0], sizeof(struct lov_oinfo));
-		OBD_FREE(*lsmp, lsm_size);
+		kfree((*lsmp)->lsm_oinfo[0]);
+		kfree(*lsmp);
 		*lsmp = NULL;
 		return 0;
 	if (*lsmp == NULL) {
-		OBD_ALLOC(*lsmp, lsm_size);
+		*lsmp = kzalloc(lsm_size, GFP_NOFS);
 		if (unlikely(*lsmp == NULL))
 			return -ENOMEM;
-		OBD_ALLOC((*lsmp)->lsm_oinfo[0], sizeof(struct lov_oinfo));
+		(*lsmp)->lsm_oinfo[0] = kzalloc(sizeof(struct lov_oinfo),
+						GFP_NOFS);
 		if (unlikely((*lsmp)->lsm_oinfo[0] == NULL)) {
+			kfree(*lsmp);
 			return -ENOMEM;
 		loi_init((*lsmp)->lsm_oinfo[0]);
@@ -962,7 +963,7 @@ int osc_shrink_grant_to_target(struct client_obd *cli, __u64 target_bytes)
 	client_obd_list_unlock(&cli->cl_loi_list_lock);
-	OBD_ALLOC_PTR(body);
+	body = kzalloc(sizeof(*body), GFP_NOFS);
 	if (!body)
 		return -ENOMEM;
@@ -984,7 +985,7 @@ int osc_shrink_grant_to_target(struct client_obd *cli, __u64 target_bytes)
 				sizeof(*body), body, NULL);
 	if (rc != 0)
 		__osc_update_grant(cli, body->oa.o_grant);
-	OBD_FREE_PTR(body);
+	kfree(body);
 	return rc;
@@ -1748,7 +1749,7 @@ static void sort_brw_pages(struct brw_page **array, int num)
 static void osc_release_ppga(struct brw_page **ppga, u32 count)
 	LASSERT(ppga != NULL);
-	OBD_FREE(ppga, sizeof(*ppga) * count);
+	kfree(ppga);
 static int brw_interpret(const struct lu_env *env,
@@ -1908,13 +1909,13 @@ int osc_build_rpc(const struct lu_env *env, struct client_obd *cli,
 	if (mem_tight)
 		mpflag = cfs_memory_pressure_get_and_set();
-	OBD_ALLOC(crattr, sizeof(*crattr));
+	crattr = kzalloc(sizeof(*crattr), GFP_NOFS);
 	if (crattr == NULL) {
 		rc = -ENOMEM;
 		goto out;
-	OBD_ALLOC(pga, sizeof(*pga) * page_count);
+	pga = kcalloc(page_count, sizeof(*pga), GFP_NOFS);
 	if (pga == NULL) {
 		rc = -ENOMEM;
 		goto out;
@@ -2055,7 +2056,7 @@ out:
 	if (crattr != NULL) {
 		capa_put(crattr->cra_capa);
-		OBD_FREE(crattr, sizeof(*crattr));
+		kfree(crattr);
 	if (rc != 0) {
@@ -2064,7 +2065,7 @@ out:
 		if (oa)
 			OBDO_FREE(oa);
 		if (pga)
-			OBD_FREE(pga, sizeof(*pga) * page_count);
+			kfree(pga);
 		/* this should happen rarely and is pretty bad, it makes the
 		 * pending list not follow the dirty order */
 		while (!list_empty(ext_list)) {
@@ -2617,7 +2618,7 @@ static int osc_getstripe(struct lov_stripe_md *lsm, struct lov_user_md *lump)
 	 * because lov_user_md_vX and lov_mds_md_vX have the same size */
 	if (lum.lmm_stripe_count > 0) {
 		lum_size = lov_mds_md_size(lum.lmm_stripe_count, lum.lmm_magic);
-		OBD_ALLOC(lumk, lum_size);
+		lumk = kzalloc(lum_size, GFP_NOFS);
 		if (!lumk)
 			return -ENOMEM;
@@ -2639,7 +2640,7 @@ static int osc_getstripe(struct lov_stripe_md *lsm, struct lov_user_md *lump)
 		rc = -EFAULT;
 	if (lumk != &lum)
-		OBD_FREE(lumk, lum_size);
+		kfree(lumk);
 	return rc;
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
