staging: lustre: osc: Replace kmem_cache_alloc with kmem_cache_zalloc
Author: Amitoj Kaur Chawla <amitoj1606@gmail.com>
Use kmem_cache_zalloc instead of manually setting kmem_cache_alloc
with flag GFP_ZERO since kmem_alloc_zalloc sets allocated memory
to zero.
The Coccinelle semantic patch used to make this change is as
follows:
expression e,f;
- kmem_cache_alloc(e, f |__GFP_ZERO)
+ kmem_cache_zalloc(e, f)
Signed-off-by: Amitoj Kaur Chawla
 drivers/staging/lustre/lustre/osc/osc_cache.c   | 2 +-
 drivers/staging/lustre/lustre/osc/osc_dev.c     | 4 ++--
 drivers/staging/lustre/lustre/osc/osc_io.c      | 2 +-
 drivers/staging/lustre/lustre/osc/osc_lock.c    | 2 +-
 drivers/staging/lustre/lustre/osc/osc_object.c  | 2 +-
 drivers/staging/lustre/lustre/osc/osc_quota.c   | 2 +-
 drivers/staging/lustre/lustre/osc/osc_request.c | 4 ++--
 7 files changed, 9 insertions(+), 9 deletions(-)
diff --git a/drivers/staging/lustre/lustre/osc/osc_cache.c b/drivers/staging/lustre/lustre/osc/osc_cache.c
index 031746a..6243aac 100644
--- a/drivers/staging/lustre/lustre/osc/osc_cache.c
+++ b/drivers/staging/lustre/lustre/osc/osc_cache.c
@@ -347,7 +347,7 @@ static struct osc_extent *osc_extent_alloc(struct osc_object *obj)
 	struct osc_extent *ext;
-	ext = kmem_cache_alloc(osc_extent_kmem, GFP_NOFS | __GFP_ZERO);
+	ext = kmem_cache_zalloc(osc_extent_kmem, GFP_NOFS);
 	if (!ext)
 		return NULL;
diff --git a/drivers/staging/lustre/lustre/osc/osc_dev.c b/drivers/staging/lustre/lustre/osc/osc_dev.c
index 67cb6e4..d4fe507 100644
--- a/drivers/staging/lustre/lustre/osc/osc_dev.c
+++ b/drivers/staging/lustre/lustre/osc/osc_dev.c
@@ -122,7 +122,7 @@ static void *osc_key_init(const struct lu_context *ctx,
 	struct osc_thread_info *info;
-	info = kmem_cache_alloc(osc_thread_kmem, GFP_NOFS | __GFP_ZERO);
+	info = kmem_cache_zalloc(osc_thread_kmem, GFP_NOFS);
 	if (!info)
 		info = ERR_PTR(-ENOMEM);
 	return info;
@@ -147,7 +147,7 @@ static void *osc_session_init(const struct lu_context *ctx,
 	struct osc_session *info;
-	info = kmem_cache_alloc(osc_session_kmem, GFP_NOFS | __GFP_ZERO);
+	info = kmem_cache_zalloc(osc_session_kmem, GFP_NOFS);
 	if (!info)
 	return info;
diff --git a/drivers/staging/lustre/lustre/osc/osc_io.c b/drivers/staging/lustre/lustre/osc/osc_io.c
index add94a2..6bd0a45 100644
--- a/drivers/staging/lustre/lustre/osc/osc_io.c
+++ b/drivers/staging/lustre/lustre/osc/osc_io.c
@@ -803,7 +803,7 @@ int osc_req_init(const struct lu_env *env, struct cl_device *dev,
 	struct osc_req *or;
 	int result;
-	or = kmem_cache_alloc(osc_req_kmem, GFP_NOFS | __GFP_ZERO);
+	or = kmem_cache_zalloc(osc_req_kmem, GFP_NOFS);
 	if (or) {
 		cl_req_slice_add(req, &or->or_cl, dev, &osc_req_ops);
 		result = 0;
diff --git a/drivers/staging/lustre/lustre/osc/osc_lock.c b/drivers/staging/lustre/lustre/osc/osc_lock.c
index 6fcdf91..8a3e872 100644
--- a/drivers/staging/lustre/lustre/osc/osc_lock.c
+++ b/drivers/staging/lustre/lustre/osc/osc_lock.c
@@ -1567,7 +1567,7 @@ int osc_lock_init(const struct lu_env *env,
 	struct osc_lock *clk;
 	int result;
-	clk = kmem_cache_alloc(osc_lock_kmem, GFP_NOFS | __GFP_ZERO);
+	clk = kmem_cache_zalloc(osc_lock_kmem, GFP_NOFS);
 	if (clk) {
 		__u32 enqflags = lock->cll_descr.cld_enq_flags;
diff --git a/drivers/staging/lustre/lustre/osc/osc_object.c b/drivers/staging/lustre/lustre/osc/osc_object.c
index 60d8230..9d474fc 100644
--- a/drivers/staging/lustre/lustre/osc/osc_object.c
+++ b/drivers/staging/lustre/lustre/osc/osc_object.c
@@ -255,7 +255,7 @@ struct lu_object *osc_object_alloc(const struct lu_env *env,
 	struct osc_object *osc;
 	struct lu_object *obj;
-	osc = kmem_cache_alloc(osc_object_kmem, GFP_NOFS | __GFP_ZERO);
+	osc = kmem_cache_zalloc(osc_object_kmem, GFP_NOFS);
 	if (osc) {
 		obj = osc2lu(osc);
 		lu_object_init(obj, NULL, dev);
diff --git a/drivers/staging/lustre/lustre/osc/osc_quota.c b/drivers/staging/lustre/lustre/osc/osc_quota.c
index 208f72b..194d8ed 100644
--- a/drivers/staging/lustre/lustre/osc/osc_quota.c
+++ b/drivers/staging/lustre/lustre/osc/osc_quota.c
@@ -30,7 +30,7 @@ static inline struct osc_quota_info *osc_oqi_alloc(u32 id)
 	struct osc_quota_info *oqi;
-	oqi = kmem_cache_alloc(osc_quota_kmem, GFP_NOFS | __GFP_ZERO);
+	oqi = kmem_cache_zalloc(osc_quota_kmem, GFP_NOFS);
 	if (oqi)
 		oqi->oqi_id = id;
diff --git a/drivers/staging/lustre/lustre/osc/osc_request.c b/drivers/staging/lustre/lustre/osc/osc_request.c
index 770d6fc..2238f92 100644
--- a/drivers/staging/lustre/lustre/osc/osc_request.c
+++ b/drivers/staging/lustre/lustre/osc/osc_request.c
@@ -1896,7 +1896,7 @@ int osc_build_rpc(const struct lu_env *env, struct client_obd *cli,
 		goto out;
-	oa = kmem_cache_alloc(obdo_cachep, GFP_NOFS | __GFP_ZERO);
+	oa = kmem_cache_zalloc(obdo_cachep, GFP_NOFS);
 	if (!oa) {
 		rc = -ENOMEM;
 		goto out;
@@ -2958,7 +2958,7 @@ static int osc_set_info_async(const struct lu_env *env, struct obd_export *exp,
 		CLASSERT(sizeof(*aa) <= sizeof(req->rq_async_args));
 		aa = ptlrpc_req_async_args(req);
 		if (!oa) {
 			ptlrpc_req_finished(req);
 			return -ENOMEM;
BtrLinux
Privacy Overview
