staging: lustre: obdecho: Use kzalloc and kfree
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Replace OBD_ALLOC, OBD_ALLOC_WAIT, OBD_ALLOC_PTR, and OBD_ALLOC_PTR_WAIT by
kalloc/kcalloc, and OBD_FREE and OBD_FREE_PTR by kfree.
A simplified version of the semantic patch that makes these changes is as
follows: (http://coccinelle.lip6.fr/)
@@ expression ptr,size; @@
- OBD_ALLOC(ptr,size)
+ ptr = kzalloc(size, GFP_NOFS)
@@ expression ptr, size; @@
- OBD_FREE(ptr, size);
+ kfree(ptr);
Signed-off-by: Julia Lawall
 .../staging/lustre/lustre/obdecho/echo_client.c    | 42 +++++++++++-----------
 1 file changed, 21 insertions(+), 21 deletions(-)
diff --git a/drivers/staging/lustre/lustre/obdecho/echo_client.c b/drivers/staging/lustre/lustre/obdecho/echo_client.c
index d542e06..cf64538 100644
--- a/drivers/staging/lustre/lustre/obdecho/echo_client.c
+++ b/drivers/staging/lustre/lustre/obdecho/echo_client.c
@@ -479,13 +479,13 @@ static int echo_alloc_memmd(struct echo_device *ed,
 	lsm_size = lov_stripe_md_size(1);
 	LASSERT(*lsmp == NULL);
-	OBD_ALLOC(*lsmp, lsm_size);
+	*lsmp = kzalloc(lsm_size, GFP_NOFS);
 	if (*lsmp == NULL)
 		return -ENOMEM;
-	OBD_ALLOC((*lsmp)->lsm_oinfo[0], sizeof(struct lov_oinfo));
+	(*lsmp)->lsm_oinfo[0] = kzalloc(sizeof(struct lov_oinfo), GFP_NOFS);
 	if ((*lsmp)->lsm_oinfo[0] == NULL) {
-		OBD_FREE(*lsmp, lsm_size);
+		kfree(*lsmp);
 		return -ENOMEM;
@@ -507,8 +507,8 @@ static int echo_free_memmd(struct echo_device *ed, struct lov_stripe_md **lsmp)
 	LASSERT(*lsmp != NULL);
-	OBD_FREE((*lsmp)->lsm_oinfo[0], sizeof(struct lov_oinfo));
+	kfree((*lsmp)->lsm_oinfo[0]);
+	kfree(*lsmp);
 	*lsmp = NULL;
 	return 0;
@@ -700,7 +700,7 @@ static struct lu_device *echo_device_alloc(const struct lu_env *env,
 	int rc;
 	int cleanup = 0;
-	OBD_ALLOC_PTR(ed);
+	ed = kzalloc(sizeof(*ed), GFP_NOFS);
 	if (ed == NULL) {
 		rc = -ENOMEM;
 		goto out;
@@ -798,7 +798,7 @@ out:
 	case 2:
 		cl_device_fini(&ed->ed_cl);
 	case 1:
-		OBD_FREE_PTR(ed);
+		kfree(ed);
 	case 0:
 	default:
 		break;
@@ -895,7 +895,7 @@ static struct lu_device *echo_device_free(const struct lu_env *env,
 	LASSERT(ed->ed_site == lu2cl_site(d->ld_site));
 	echo_site_fini(env, ed);
-	OBD_FREE_PTR(ed);
+	kfree(ed);
 	return NULL;
@@ -1577,13 +1577,13 @@ static int echo_client_kbrw(struct echo_device *ed, int rw, struct obdo *oa,
 	if (rw == OBD_BRW_WRITE)
 		brw_flags = OBD_BRW_ASYNC;
-	OBD_ALLOC(pga, npages * sizeof(*pga));
+	pga = kcalloc(npages, sizeof(*pga), GFP_NOFS);
 	if (pga == NULL)
 		return -ENOMEM;
-	OBD_ALLOC(pages, npages * sizeof(*pages));
+	pages = kcalloc(npages, sizeof(*pages), GFP_NOFS);
 	if (pages == NULL) {
-		OBD_FREE(pga, npages * sizeof(*pga));
+		kfree(pga);
 		return -ENOMEM;
@@ -1632,8 +1632,8 @@ static int echo_client_kbrw(struct echo_device *ed, int rw, struct obdo *oa,
 		OBD_PAGE_FREE(pgp->pg);
-	OBD_FREE(pages, npages * sizeof(*pages));
+	kfree(pga);
+	kfree(pages);
 	return rc;
@@ -1659,8 +1659,8 @@ static int echo_client_prep_commit(const struct lu_env *env,
 	npages = batch >> PAGE_CACHE_SHIFT;
 	tot_pages = count >> PAGE_CACHE_SHIFT;
-	OBD_ALLOC(lnb, npages * sizeof(struct niobuf_local));
-	OBD_ALLOC(rnb, npages * sizeof(struct niobuf_remote));
+	lnb = kcalloc(npages, sizeof(struct niobuf_local), GFP_NOFS);
+	rnb = kcalloc(npages, sizeof(struct niobuf_remote), GFP_NOFS);
 	if (lnb == NULL || rnb == NULL) {
 		ret = -ENOMEM;
@@ -1738,9 +1738,9 @@ static int echo_client_prep_commit(const struct lu_env *env,
 out:
 	if (lnb)
-		OBD_FREE(lnb, npages * sizeof(struct niobuf_local));
+		kfree(lnb);
 	if (rnb)
-		OBD_FREE(rnb, npages * sizeof(struct niobuf_remote));
+		kfree(rnb);
 	return ret;
@@ -1879,7 +1879,7 @@ echo_client_iocontrol(unsigned int cmd, struct obd_export *exp, int len,
 	if (rc < 0)
 		return rc;
-	OBD_ALLOC_PTR(env);
+	env = kzalloc(sizeof(*env), GFP_NOFS);
 	if (env == NULL)
 		return -ENOMEM;
@@ -2010,7 +2010,7 @@ echo_client_iocontrol(unsigned int cmd, struct obd_export *exp, int len,
 out:
 	lu_env_fini(env);
-	OBD_FREE_PTR(env);
+	kfree(env);
 	/* XXX this should be in a helper also called by target_send_reply */
 	for (ack_lock = dummy_oti.oti_ack_locks, i = 0; i < 4;
@@ -2050,7 +2050,7 @@ static int echo_client_setup(const struct lu_env *env,
 	ec->ec_unique = 0;
 	ec->ec_nstripes = 0;
-	OBD_ALLOC(ocd, sizeof(*ocd));
+	ocd = kzalloc(sizeof(*ocd), GFP_NOFS);
 	if (ocd == NULL) {
 		CERROR("Can't alloc ocd connecting to %s\n",
 		       lustre_cfg_string(lcfg, 1));
@@ -2074,7 +2074,7 @@ static int echo_client_setup(const struct lu_env *env,
 		spin_unlock(&tgt->obd_dev_lock);
-	OBD_FREE(ocd, sizeof(*ocd));
+	kfree(ocd);
 	if (rc != 0) {
 		CERROR("fail to connect to device %s\n",
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
