staging: lustre: obdecho: remove unused variable
Author: Aya Mahfouz <mahfouz.saif.elyazal@gmail.com>
This patch removes a variable that was simply used to
store the return value of a function call before
returning it.
The issue was detected and resolved using the following
coccinelle script:
identifier len,f;
-int len;
 ... when != len
     when strict
-len =
+return
        f(...);
-return len;
Signed-off-by: Aya Mahfouz
 drivers/staging/lustre/lustre/obdecho/echo_client.c | 5 +----
 1 file changed, 1 insertion(+), 4 deletions(-)
diff --git a/drivers/staging/lustre/lustre/obdecho/echo_client.c b/drivers/staging/lustre/lustre/obdecho/echo_client.c
index 5f6d944..7f578b4 100644
--- a/drivers/staging/lustre/lustre/obdecho/echo_client.c
+++ b/drivers/staging/lustre/lustre/obdecho/echo_client.c
@@ -2158,7 +2158,6 @@ void echo_client_exit(void)
 static int __init obdecho_init(void)
 	struct lprocfs_static_vars lvars;
-	int rc;
 	LCONSOLE_INFO("Echo OBD driver; http://www.lustre.org/\n");
@@ -2167,9 +2166,7 @@ static int __init obdecho_init(void)
 	lprocfs_echo_init_vars(&lvars);
-	rc = echo_client_init();
-	return rc;
+	return echo_client_init();
 static void /*__exit*/ obdecho_exit(void)
BtrLinux
Privacy Overview
