staging: lustre: obdecho: constify lu_device_operations and cl_device_operations structures
Author: Julia Lawall <Julia.Lawall@lip6.fr>
These lu_device_operations and cl_device_operations structures are never
modified, so declare them as const.  Other structures of these types are
already const.
Done with the help of Coccinelle.
Signed-off-by: Julia Lawall
 drivers/staging/lustre/lustre/obdecho/echo_client.c | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/staging/lustre/lustre/obdecho/echo_client.c b/drivers/staging/lustre/lustre/obdecho/echo_client.c
index 7b53f7d..f32f1e7 100644
--- a/drivers/staging/lustre/lustre/obdecho/echo_client.c
+++ b/drivers/staging/lustre/lustre/obdecho/echo_client.c
@@ -582,13 +582,13 @@ static struct lu_object *echo_object_alloc(const struct lu_env *env,
 	return obj;
-static struct lu_device_operations echo_device_lu_ops = {
+static const struct lu_device_operations echo_device_lu_ops = {
 	.ldo_object_alloc   = echo_object_alloc,
 /** @} echo_lu_dev_ops */
-static struct cl_device_operations echo_device_cl_ops = {
+static const struct cl_device_operations echo_device_cl_ops = {
 /** \defgroup echo_init Setup and teardown
