staging: lustre: obdclass: Use kzalloc and kfree
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Replace OBD_ALLOC, OBD_ALLOC_WAIT, OBD_ALLOC_PTR, and OBD_ALLOC_PTR_WAIT by
kalloc/kcalloc, and OBD_FREE and OBD_FREE_PTR by kfree.
A simplified version of the semantic patch that makes these changes is as
follows: (http://coccinelle.lip6.fr/)
@@ expression ptr,size; @@
- OBD_ALLOC(ptr,size)
+ ptr = kzalloc(size, GFP_NOFS)
@@ expression ptr, size; @@
- OBD_FREE(ptr, size);
+ kfree(ptr);
Signed-off-by: Julia Lawall
 drivers/staging/lustre/lustre/obdclass/acl.c       | 29 ++++----
 drivers/staging/lustre/lustre/obdclass/capa.c      |  4 +-
 drivers/staging/lustre/lustre/obdclass/cl_io.c     | 13 ++--
 drivers/staging/lustre/lustre/obdclass/cl_page.c   |  2 +-
 drivers/staging/lustre/lustre/obdclass/class_obd.c |  4 +-
 drivers/staging/lustre/lustre/obdclass/genops.c    | 40 +++++-----
 drivers/staging/lustre/lustre/obdclass/llog.c      | 24 +++---
 drivers/staging/lustre/lustre/obdclass/llog_obd.c  |  4 +-
 .../lustre/lustre/obdclass/lprocfs_status.c        | 14 ++--
 drivers/staging/lustre/lustre/obdclass/lu_object.c |  6 +-
 .../lustre/lustre/obdclass/lustre_handles.c        |  2 +-
 .../staging/lustre/lustre/obdclass/lustre_peer.c   |  6 +-
 .../staging/lustre/lustre/obdclass/obd_config.c    | 50 ++++++-------
 drivers/staging/lustre/lustre/obdclass/obd_mount.c | 86 ++++++++++------------
 14 files changed, 138 insertions(+), 146 deletions(-)
diff --git a/drivers/staging/lustre/lustre/obdclass/acl.c b/drivers/staging/lustre/lustre/obdclass/acl.c
index 9a69f6b..194c48a 100644
--- a/drivers/staging/lustre/lustre/obdclass/acl.c
+++ b/drivers/staging/lustre/lustre/obdclass/acl.c
@@ -104,12 +104,12 @@ static int lustre_posix_acl_xattr_reduce_space(posix_acl_xattr_header **header,
 	if (unlikely(old_count <= new_count))
 		return old_size;
-	OBD_ALLOC(new, new_size);
+	new = kzalloc(new_size, GFP_NOFS);
 	if (unlikely(new == NULL))
 		return -ENOMEM;
 	memcpy(new, *header, new_size);
-	OBD_FREE(*header, old_size);
+	kfree(*header);
 	*header = new;
 	return new_size;
@@ -126,12 +126,12 @@ static int lustre_ext_acl_xattr_reduce_space(ext_acl_xattr_header **header,
 	if (unlikely(old_count <= ext_count))
 		return 0;
-	OBD_ALLOC(new, ext_size);
+	new = kzalloc(ext_size, GFP_NOFS);
 		return -ENOMEM;
 	memcpy(new, *header, ext_size);
+	kfree(*header);
 	*header = new;
 	return 0;
@@ -152,7 +152,7 @@ lustre_posix_acl_xattr_2ext(posix_acl_xattr_header *header, int size)
 	else
 		count = CFS_ACL_XATTR_COUNT(size, posix_acl_xattr);
 	esize = CFS_ACL_XATTR_SIZE(count, ext_acl_xattr);
-	OBD_ALLOC(new, esize);
+	new = kzalloc(esize, GFP_NOFS);
 		return ERR_PTR(-ENOMEM);
@@ -183,7 +183,7 @@ int lustre_posix_acl_xattr_filter(posix_acl_xattr_header *header, size_t size,
 	if (size < sizeof(*new))
 		return -EINVAL;
-	OBD_ALLOC(new, size);
+	new = kzalloc(size, GFP_NOFS);
 		return -ENOMEM;
@@ -232,7 +232,7 @@ int lustre_posix_acl_xattr_filter(posix_acl_xattr_header *header, size_t size,
 _out:
 	if (rc) {
-		OBD_FREE(new, size);
+		kfree(new);
 		size = rc;
 	return size;
@@ -244,7 +244,7 @@ EXPORT_SYMBOL(lustre_posix_acl_xattr_filter);
 void lustre_posix_acl_xattr_free(posix_acl_xattr_header *header, int size)
-	OBD_FREE(header, size);
+	kfree(header);
 EXPORT_SYMBOL(lustre_posix_acl_xattr_free);
@@ -253,8 +253,7 @@ EXPORT_SYMBOL(lustre_posix_acl_xattr_free);
 void lustre_ext_acl_xattr_free(ext_acl_xattr_header *header)
-	OBD_FREE(header, CFS_ACL_XATTR_SIZE(le32_to_cpu(header->a_count), \
-					    ext_acl_xattr));
+	kfree(header);
 EXPORT_SYMBOL(lustre_ext_acl_xattr_free);
@@ -309,7 +308,7 @@ int lustre_acl_xattr_merge2posix(posix_acl_xattr_header *posix_header, int size,
 		/* there are only base ACL entries at most. */
 		posix_count = 3;
 		posix_size = CFS_ACL_XATTR_SIZE(posix_count, posix_acl_xattr);
-		OBD_ALLOC(new, posix_size);
+		new = kzalloc(posix_size, GFP_NOFS);
 			return -ENOMEM;
@@ -360,7 +359,7 @@ int lustre_acl_xattr_merge2posix(posix_acl_xattr_header *posix_header, int size,
 		posix_count = ori_posix_count + ext_count;
 		posix_size =
 			return -ENOMEM;
@@ -402,7 +401,7 @@ int lustre_acl_xattr_merge2posix(posix_acl_xattr_header *posix_header, int size,
 _out:
 	if (rc) {
-		OBD_FREE(new, posix_size);
+		kfree(new);
 		posix_size = rc;
 	return posix_size;
@@ -432,7 +431,7 @@ lustre_acl_xattr_merge2ext(posix_acl_xattr_header *posix_header, int size,
 	ext_count = posix_count + ori_ext_count;
 	ext_size = CFS_ACL_XATTR_SIZE(ext_count, ext_acl_xattr);
@@ -538,7 +537,7 @@ lustre_acl_xattr_merge2ext(posix_acl_xattr_header *posix_header, int size,
 out:
 	if (rc) {
-		OBD_FREE(new, ext_size);
+		kfree(new);
 		new = ERR_PTR(rc);
 	return new;
diff --git a/drivers/staging/lustre/lustre/obdclass/capa.c b/drivers/staging/lustre/lustre/obdclass/capa.c
index d206b10..d8d1a66 100644
--- a/drivers/staging/lustre/lustre/obdclass/capa.c
+++ b/drivers/staging/lustre/lustre/obdclass/capa.c
@@ -87,7 +87,7 @@ struct hlist_head *init_capa_hash(void)
 	struct hlist_head *hash;
 	int nr_hash, i;
-	OBD_ALLOC(hash, PAGE_CACHE_SIZE);
+	hash = kzalloc(PAGE_CACHE_SIZE, GFP_NOFS);
 	if (!hash)
 		return NULL;
@@ -129,7 +129,7 @@ void cleanup_capa_hash(struct hlist_head *hash)
 	spin_unlock(&capa_lock);
-	OBD_FREE(hash, PAGE_CACHE_SIZE);
+	kfree(hash);
 EXPORT_SYMBOL(cleanup_capa_hash);
diff --git a/drivers/staging/lustre/lustre/obdclass/cl_io.c b/drivers/staging/lustre/lustre/obdclass/cl_io.c
index 3141b60..fd1a4c5 100644
--- a/drivers/staging/lustre/lustre/obdclass/cl_io.c
+++ b/drivers/staging/lustre/lustre/obdclass/cl_io.c
@@ -612,7 +612,7 @@ EXPORT_SYMBOL(cl_io_lock_add);
 static void cl_free_io_lock_link(const struct lu_env *env,
 				 struct cl_io_lock_link *link)
-	OBD_FREE_PTR(link);
+	kfree(link);
@@ -624,7 +624,7 @@ int cl_io_lock_alloc_add(const struct lu_env *env, struct cl_io *io,
 	struct cl_io_lock_link *link;
 	int result;
-	OBD_ALLOC_PTR(link);
+	link = kzalloc(sizeof(*link), GFP_NOFS);
 	if (link != NULL) {
 		link->cill_descr     = *descr;
 		link->cill_fini      = cl_free_io_lock_link;
@@ -1387,9 +1387,9 @@ static void cl_req_free(const struct lu_env *env, struct cl_req *req)
 				cl_object_put(env, obj);
-		OBD_FREE(req->crq_o, req->crq_nrobjs * sizeof(req->crq_o[0]));
+		kfree(req->crq_o);
-	OBD_FREE_PTR(req);
+	kfree(req);
 static int cl_req_init(const struct lu_env *env, struct cl_req *req,
@@ -1448,7 +1448,7 @@ struct cl_req *cl_req_alloc(const struct lu_env *env, struct cl_page *page,
 	LINVRNT(nr_objects > 0);
-	OBD_ALLOC_PTR(req);
+	req = kzalloc(sizeof(*req), GFP_NOFS);
 	if (req != NULL) {
 		int result;
@@ -1456,7 +1456,8 @@ struct cl_req *cl_req_alloc(const struct lu_env *env, struct cl_page *page,
 		INIT_LIST_HEAD(&req->crq_pages);
 		INIT_LIST_HEAD(&req->crq_layers);
-		OBD_ALLOC(req->crq_o, nr_objects * sizeof(req->crq_o[0]));
+		req->crq_o = kcalloc(nr_objects, sizeof(req->crq_o[0]),
+				     GFP_NOFS);
 		if (req->crq_o != NULL) {
 			req->crq_nrobjs = nr_objects;
 			result = cl_req_init(env, req, page);
diff --git a/drivers/staging/lustre/lustre/obdclass/cl_page.c b/drivers/staging/lustre/lustre/obdclass/cl_page.c
index b7dd048..8873553 100644
--- a/drivers/staging/lustre/lustre/obdclass/cl_page.c
+++ b/drivers/staging/lustre/lustre/obdclass/cl_page.c
@@ -270,7 +270,7 @@ static void cl_page_free(const struct lu_env *env, struct cl_page *page)
 	lu_object_ref_del_at(&obj->co_lu, &page->cp_obj_ref, "cl_page", page);
 	lu_ref_fini(&page->cp_reference);
-	OBD_FREE(page, pagesize);
+	kfree(page);
diff --git a/drivers/staging/lustre/lustre/obdclass/class_obd.c b/drivers/staging/lustre/lustre/obdclass/class_obd.c
index d4b74b6..6e967af 100644
--- a/drivers/staging/lustre/lustre/obdclass/class_obd.c
+++ b/drivers/staging/lustre/lustre/obdclass/class_obd.c
@@ -231,7 +231,7 @@ int class_handle_ioctl(unsigned int cmd, unsigned long arg)
 			err = -EINVAL;
 			goto out;
-		OBD_ALLOC(lcfg, data->ioc_plen1);
+		lcfg = kzalloc(data->ioc_plen1, GFP_NOFS);
 		if (lcfg == NULL) {
 			err = -ENOMEM;
 			goto out;
@@ -243,7 +243,7 @@ int class_handle_ioctl(unsigned int cmd, unsigned long arg)
 		if (!err)
 			err = class_process_config(lcfg);
-		OBD_FREE(lcfg, data->ioc_plen1);
+		kfree(lcfg);
 		goto out;
diff --git a/drivers/staging/lustre/lustre/obdclass/genops.c b/drivers/staging/lustre/lustre/obdclass/genops.c
index 66b5678..a107aea 100644
--- a/drivers/staging/lustre/lustre/obdclass/genops.c
+++ b/drivers/staging/lustre/lustre/obdclass/genops.c
@@ -171,13 +171,13 @@ int class_register_type(struct obd_ops *dt_ops, struct md_ops *md_ops,
 	rc = -ENOMEM;
-	OBD_ALLOC(type, sizeof(*type));
+	type = kzalloc(sizeof(*type), GFP_NOFS);
 	if (type == NULL)
 		return rc;
-	OBD_ALLOC_PTR(type->typ_dt_ops);
-	OBD_ALLOC_PTR(type->typ_md_ops);
-	OBD_ALLOC(type->typ_name, strlen(name) + 1);
+	type->typ_dt_ops = kzalloc(sizeof(*type->typ_dt_ops), GFP_NOFS);
+	type->typ_md_ops = kzalloc(sizeof(*type->typ_md_ops), GFP_NOFS);
+	type->typ_name = kzalloc(strlen(name) + 1, GFP_NOFS);
 	if (type->typ_dt_ops == NULL ||
 	    type->typ_md_ops == NULL ||
@@ -214,12 +214,12 @@ int class_register_type(struct obd_ops *dt_ops, struct md_ops *md_ops,
  failed:
 	if (type->typ_name != NULL)
-		OBD_FREE(type->typ_name, strlen(name) + 1);
+		kfree(type->typ_name);
 	if (type->typ_md_ops != NULL)
-		OBD_FREE_PTR(type->typ_md_ops);
+		kfree(type->typ_md_ops);
 	if (type->typ_dt_ops != NULL)
-		OBD_FREE_PTR(type->typ_dt_ops);
-	OBD_FREE(type, sizeof(*type));
+		kfree(type->typ_dt_ops);
+	kfree(type);
 	return rc;
 EXPORT_SYMBOL(class_register_type);
@@ -237,8 +237,8 @@ int class_unregister_type(const char *name)
 		CERROR("type %s has refcount (%d)\n", name, type->typ_refcnt);
 		/* This is a bad situation, let's make the best of it */
 		/* Remove ops, but leave the name for debugging */
 		return -EBUSY;
@@ -252,12 +252,12 @@ int class_unregister_type(const char *name)
 	spin_lock(&obd_types_lock);
 	list_del(&type->typ_chain);
 	spin_unlock(&obd_types_lock);
+	kfree(type);
 	return 0;
 } /* class_unregister_type */
 EXPORT_SYMBOL(class_unregister_type);
@@ -819,7 +819,7 @@ struct obd_export *class_new_export(struct obd_device *obd,
 	struct cfs_hash *hash = NULL;
 	int rc = 0;
-	OBD_ALLOC_PTR(export);
+	export = kzalloc(sizeof(*export), GFP_NOFS);
 	if (!export)
@@ -904,7 +904,7 @@ exit_err:
 	class_handle_unhash(&export->exp_handle);
 	LASSERT(hlist_unhashed(&export->exp_uuid_hash));
 	obd_destroy_export(export);
-	OBD_FREE_PTR(export);
+	kfree(export);
 	return ERR_PTR(rc);
 EXPORT_SYMBOL(class_new_export);
@@ -945,7 +945,7 @@ static void class_import_destroy(struct obd_import *imp)
 					  struct obd_import_conn, oic_item);
 		list_del_init(&imp_conn->oic_item);
 		ptlrpc_put_connection_superhack(imp_conn->oic_conn);
-		OBD_FREE(imp_conn, sizeof(*imp_conn));
+		kfree(imp_conn);
 	LASSERT(imp->imp_sec == NULL);
@@ -1008,7 +1008,7 @@ struct obd_import *class_new_import(struct obd_device *obd)
 	struct obd_import *imp;
-	OBD_ALLOC(imp, sizeof(*imp));
+	imp = kzalloc(sizeof(*imp), GFP_NOFS);
 	if (imp == NULL)
 		return NULL;
@@ -1811,7 +1811,7 @@ void *kuc_alloc(int payload_len, int transport, int type)
 	struct kuc_hdr *lh;
 	int len = kuc_len(payload_len);
-	OBD_ALLOC(lh, len);
+	lh = kzalloc(len, GFP_NOFS);
 	if (lh == NULL)
@@ -1828,6 +1828,6 @@ EXPORT_SYMBOL(kuc_alloc);
 inline void kuc_free(void *p, int payload_len)
 	struct kuc_hdr *lh = kuc_ptr(p);
-	OBD_FREE(lh, kuc_len(payload_len));
+	kfree(lh);
 EXPORT_SYMBOL(kuc_free);
diff --git a/drivers/staging/lustre/lustre/obdclass/llog.c b/drivers/staging/lustre/lustre/obdclass/llog.c
index 114be4a..636df94 100644
--- a/drivers/staging/lustre/lustre/obdclass/llog.c
+++ b/drivers/staging/lustre/lustre/obdclass/llog.c
@@ -60,7 +60,7 @@ static struct llog_handle *llog_alloc_handle(void)
 	struct llog_handle *loghandle;
-	OBD_ALLOC_PTR(loghandle);
+	loghandle = kzalloc(sizeof(*loghandle), GFP_NOFS);
 	if (loghandle == NULL)
 		return NULL;
@@ -88,9 +88,9 @@ static void llog_free_handle(struct llog_handle *loghandle)
 	else if (loghandle->lgh_hdr->llh_flags & LLOG_F_IS_CAT)
 		LASSERT(list_empty(&loghandle->u.chd.chd_head));
 	LASSERT(sizeof(*(loghandle->lgh_hdr)) == LLOG_CHUNK_SIZE);
-	OBD_FREE(loghandle->lgh_hdr, LLOG_CHUNK_SIZE);
+	kfree(loghandle->lgh_hdr);
 out:
-	OBD_FREE_PTR(loghandle);
+	kfree(loghandle);
 void llog_handle_get(struct llog_handle *loghandle)
@@ -207,7 +207,7 @@ int llog_init_handle(const struct lu_env *env, struct llog_handle *handle,
 	LASSERT(handle->lgh_hdr == NULL);
-	OBD_ALLOC_PTR(llh);
+	llh = kzalloc(sizeof(*llh), GFP_NOFS);
 	if (llh == NULL)
 		return -ENOMEM;
 	handle->lgh_hdr = llh;
@@ -261,7 +261,7 @@ int llog_init_handle(const struct lu_env *env, struct llog_handle *handle,
 out:
 	if (rc) {
-		OBD_FREE_PTR(llh);
+		kfree(llh);
 		handle->lgh_hdr = NULL;
 	return rc;
@@ -283,7 +283,7 @@ static int llog_process_thread(void *arg)
 	LASSERT(llh);
-	OBD_ALLOC(buf, LLOG_CHUNK_SIZE);
+	buf = kzalloc(LLOG_CHUNK_SIZE, GFP_NOFS);
 	if (!buf) {
 		lpi->lpi_rc = -ENOMEM;
 		return 0;
@@ -400,7 +400,7 @@ out:
 	if (cd != NULL)
 		cd->lpcd_last_idx = last_called_index;
-	OBD_FREE(buf, LLOG_CHUNK_SIZE);
+	kfree(buf);
 	lpi->lpi_rc = rc;
 	return 0;
@@ -434,7 +434,7 @@ int llog_process_or_fork(const struct lu_env *env,
 	struct llog_process_info *lpi;
 	int		      rc;
-	OBD_ALLOC_PTR(lpi);
+	lpi = kzalloc(sizeof(*lpi), GFP_NOFS);
 	if (lpi == NULL) {
 		CERROR("cannot alloc pointer\n");
 		return -ENOMEM;
@@ -454,7 +454,7 @@ int llog_process_or_fork(const struct lu_env *env,
 		if (IS_ERR_VALUE(rc)) {
 			CERROR("%s: cannot start thread: rc = %d\n",
 			       loghandle->lgh_ctxt->loc_obd->obd_name, rc);
-			OBD_FREE_PTR(lpi);
+			kfree(lpi);
 			return rc;
 		wait_for_completion(&lpi->lpi_completion);
@@ -463,7 +463,7 @@ int llog_process_or_fork(const struct lu_env *env,
 		llog_process_thread(lpi);
 	rc = lpi->lpi_rc;
+	kfree(lpi);
 	return rc;
 EXPORT_SYMBOL(llog_process_or_fork);
@@ -484,7 +484,7 @@ int llog_reverse_process(const struct lu_env *env,
 	void *buf;
 	int rc = 0, first_index = 1, index, idx;
 	if (!buf)
 		return -ENOMEM;
@@ -564,7 +564,7 @@ int llog_reverse_process(const struct lu_env *env,
 out:
 	if (buf)
+		kfree(buf);
 	return rc;
 EXPORT_SYMBOL(llog_reverse_process);
diff --git a/drivers/staging/lustre/lustre/obdclass/llog_obd.c b/drivers/staging/lustre/lustre/obdclass/llog_obd.c
index 978d886..81ab27e 100644
--- a/drivers/staging/lustre/lustre/obdclass/llog_obd.c
+++ b/drivers/staging/lustre/lustre/obdclass/llog_obd.c
@@ -46,7 +46,7 @@ static struct llog_ctxt *llog_new_ctxt(struct obd_device *obd)
 	struct llog_ctxt *ctxt;
-	OBD_ALLOC_PTR(ctxt);
+	ctxt = kzalloc(sizeof(*ctxt), GFP_NOFS);
 	if (!ctxt)
 		return NULL;
@@ -66,7 +66,7 @@ static void llog_ctxt_destroy(struct llog_ctxt *ctxt)
 		class_import_put(ctxt->loc_imp);
 		ctxt->loc_imp = NULL;
-	OBD_FREE_PTR(ctxt);
+	kfree(ctxt);
 int __llog_ctxt_put(const struct lu_env *env, struct llog_ctxt *ctxt)
diff --git a/drivers/staging/lustre/lustre/obdclass/lprocfs_status.c b/drivers/staging/lustre/lustre/obdclass/lprocfs_status.c
index c171c6c..57c6ddd 100644
--- a/drivers/staging/lustre/lustre/obdclass/lprocfs_status.c
+++ b/drivers/staging/lustre/lustre/obdclass/lprocfs_status.c
@@ -276,7 +276,7 @@ struct proc_dir_entry *lprocfs_add_symlink(const char *name,
 	if (parent == NULL || format == NULL)
 		return NULL;
-	OBD_ALLOC_WAIT(dest, MAX_STRING_SIZE + 1);
+	dest = kzalloc(MAX_STRING_SIZE + 1, GFP_KERNEL);
 	if (dest == NULL)
 		return NULL;
@@ -289,7 +289,7 @@ struct proc_dir_entry *lprocfs_add_symlink(const char *name,
 		CERROR("LprocFS: Could not create symbolic link from %s to %s",
 			name, dest);
-	OBD_FREE(dest, MAX_STRING_SIZE + 1);
+	kfree(dest);
 	return entry;
 EXPORT_SYMBOL(lprocfs_add_symlink);
@@ -1006,7 +1006,7 @@ static void lprocfs_free_client_stats(struct nid_stat *client_stat)
 	if (client_stat->nid_ldlm_stats)
 		lprocfs_free_stats(&client_stat->nid_ldlm_stats);
-	OBD_FREE_PTR(client_stat);
+	kfree(client_stat);
 	return;
@@ -1681,7 +1681,7 @@ int lprocfs_exp_setup(struct obd_export *exp, lnet_nid_t *nid, int *newnid)
 	CDEBUG(D_CONFIG, "using hash %p\n", obd->obd_nid_stats_hash);
-	OBD_ALLOC_PTR(new_stat);
+	new_stat = kzalloc(sizeof(*new_stat), GFP_NOFS);
 	if (new_stat == NULL)
 		return -ENOMEM;
@@ -1711,7 +1711,7 @@ int lprocfs_exp_setup(struct obd_export *exp, lnet_nid_t *nid, int *newnid)
 		goto destroy_new;
 	/* not found - create */
-	OBD_ALLOC(buffer, LNET_NIDSTR_SIZE);
+	buffer = kzalloc(LNET_NIDSTR_SIZE, GFP_NOFS);
 	if (buffer == NULL) {
 		rc = -ENOMEM;
 		goto destroy_new;
@@ -1721,7 +1721,7 @@ int lprocfs_exp_setup(struct obd_export *exp, lnet_nid_t *nid, int *newnid)
 	new_stat->nid_proc = lprocfs_register(buffer,
 					      obd->obd_proc_exports_entry,
 					      NULL, NULL);
-	OBD_FREE(buffer, LNET_NIDSTR_SIZE);
+	kfree(buffer);
 	if (IS_ERR(new_stat->nid_proc)) {
 		CERROR("Error making export directory for nid %s\n",
@@ -1763,7 +1763,7 @@ destroy_new_ns:
 destroy_new:
 	nidstat_putref(new_stat);
-	OBD_FREE_PTR(new_stat);
+	kfree(new_stat);
 	return rc;
 EXPORT_SYMBOL(lprocfs_exp_setup);
diff --git a/drivers/staging/lustre/lustre/obdclass/lu_object.c b/drivers/staging/lustre/lustre/obdclass/lu_object.c
index 20c0779..4458faa 100644
--- a/drivers/staging/lustre/lustre/obdclass/lu_object.c
+++ b/drivers/staging/lustre/lustre/obdclass/lu_object.c
@@ -1532,7 +1532,7 @@ static void keys_fini(struct lu_context *ctx)
 	for (i = 0; i < ARRAY_SIZE(lu_keys); ++i)
 		key_fini(ctx, i);
-	OBD_FREE(ctx->lc_value, ARRAY_SIZE(lu_keys) * sizeof(ctx->lc_value[0]));
+	kfree(ctx->lc_value);
 	ctx->lc_value = NULL;
@@ -1581,8 +1581,8 @@ static int keys_fill(struct lu_context *ctx)
 static int keys_init(struct lu_context *ctx)
-	OBD_ALLOC(ctx->lc_value,
-		  ARRAY_SIZE(lu_keys) * sizeof(ctx->lc_value[0]));
+	ctx->lc_value = kcalloc(ARRAY_SIZE(lu_keys), sizeof(ctx->lc_value[0]),
+				GFP_NOFS);
 	if (likely(ctx->lc_value != NULL))
 		return keys_fill(ctx);
diff --git a/drivers/staging/lustre/lustre/obdclass/lustre_handles.c b/drivers/staging/lustre/lustre/obdclass/lustre_handles.c
index f720e31..1cfaabf 100644
--- a/drivers/staging/lustre/lustre/obdclass/lustre_handles.c
+++ b/drivers/staging/lustre/lustre/obdclass/lustre_handles.c
@@ -186,7 +186,7 @@ void class_handle_free_cb(struct rcu_head *rcu)
 	if (h->h_ops->hop_free != NULL)
 		h->h_ops->hop_free(ptr, h->h_size);
 	else
-		OBD_FREE(ptr, h->h_size);
+		kfree(ptr);
 EXPORT_SYMBOL(class_handle_free_cb);
diff --git a/drivers/staging/lustre/lustre/obdclass/lustre_peer.c b/drivers/staging/lustre/lustre/obdclass/lustre_peer.c
index 64b2f35..5cc6435 100644
--- a/drivers/staging/lustre/lustre/obdclass/lustre_peer.c
+++ b/drivers/staging/lustre/lustre/obdclass/lustre_peer.c
@@ -104,7 +104,7 @@ int class_add_uuid(const char *uuid, __u64 nid)
 	if (strlen(uuid) > UUID_MAX - 1)
 		return -EOVERFLOW;
-	OBD_ALLOC_PTR(data);
+	data = kzalloc(sizeof(*data), GFP_NOFS);
 	if (data == NULL)
 		return -ENOMEM;
@@ -136,7 +136,7 @@ int class_add_uuid(const char *uuid, __u64 nid)
 	if (found) {
 		CDEBUG(D_INFO, "found uuid %s %s cnt=%d\n", uuid,
 		       libcfs_nid2str(nid), entry->un_nid_count);
-		OBD_FREE(data, sizeof(*data));
+		kfree(data);
 	} else {
 		CDEBUG(D_INFO, "add uuid %s %s\n", uuid, libcfs_nid2str(nid));
@@ -180,7 +180,7 @@ int class_del_uuid(const char *uuid)
 		       libcfs_nid2str(data->un_nids[0]),
 		       data->un_nid_count);
+		kfree(data);
 	return 0;
diff --git a/drivers/staging/lustre/lustre/obdclass/obd_config.c b/drivers/staging/lustre/lustre/obdclass/obd_config.c
index 6ce9adc..687fbbd 100644
--- a/drivers/staging/lustre/lustre/obdclass/obd_config.c
+++ b/drivers/staging/lustre/lustre/obdclass/obd_config.c
@@ -860,13 +860,13 @@ int class_add_profile(int proflen, char *prof, int osclen, char *osc,
 	CDEBUG(D_CONFIG, "Add profile %s\n", prof);
-	OBD_ALLOC(lprof, sizeof(*lprof));
+	lprof = kzalloc(sizeof(*lprof), GFP_NOFS);
 	if (lprof == NULL)
 		return -ENOMEM;
 	INIT_LIST_HEAD(&lprof->lp_list);
 	LASSERT(proflen == (strlen(prof) + 1));
-	OBD_ALLOC(lprof->lp_profile, proflen);
+	lprof->lp_profile = kzalloc(proflen, GFP_NOFS);
 	if (lprof->lp_profile == NULL) {
 		err = -ENOMEM;
 		goto out;
@@ -874,7 +874,7 @@ int class_add_profile(int proflen, char *prof, int osclen, char *osc,
 	memcpy(lprof->lp_profile, prof, proflen);
 	LASSERT(osclen == (strlen(osc) + 1));
-	OBD_ALLOC(lprof->lp_dt, osclen);
+	lprof->lp_dt = kzalloc(osclen, GFP_NOFS);
 	if (lprof->lp_dt == NULL) {
 		err = -ENOMEM;
 		goto out;
@@ -883,7 +883,7 @@ int class_add_profile(int proflen, char *prof, int osclen, char *osc,
 	if (mdclen > 0) {
 		LASSERT(mdclen == (strlen(mdc) + 1));
-		OBD_ALLOC(lprof->lp_md, mdclen);
+		lprof->lp_md = kzalloc(mdclen, GFP_NOFS);
 		if (lprof->lp_md == NULL) {
 			err = -ENOMEM;
 			goto out;
@@ -896,12 +896,12 @@ int class_add_profile(int proflen, char *prof, int osclen, char *osc,
 out:
 	if (lprof->lp_md)
-		OBD_FREE(lprof->lp_md, mdclen);
+		kfree(lprof->lp_md);
 	if (lprof->lp_dt)
-		OBD_FREE(lprof->lp_dt, osclen);
+		kfree(lprof->lp_dt);
 	if (lprof->lp_profile)
-		OBD_FREE(lprof->lp_profile, proflen);
-	OBD_FREE(lprof, sizeof(*lprof));
+		kfree(lprof->lp_profile);
+	kfree(lprof);
 	return err;
@@ -914,11 +914,11 @@ void class_del_profile(const char *prof)
 	lprof = class_get_profile(prof);
 	if (lprof) {
 		list_del(&lprof->lp_list);
-		OBD_FREE(lprof->lp_profile, strlen(lprof->lp_profile) + 1);
-		OBD_FREE(lprof->lp_dt, strlen(lprof->lp_dt) + 1);
 		if (lprof->lp_md)
-			OBD_FREE(lprof->lp_md, strlen(lprof->lp_md) + 1);
+		kfree(lprof);
 EXPORT_SYMBOL(class_del_profile);
@@ -930,11 +930,11 @@ void class_del_profiles(void)
 	list_for_each_entry_safe(lprof, n, &lustre_profile_list, lp_list) {
 		if (lprof->lp_md)
+		kfree(lprof);
 EXPORT_SYMBOL(class_del_profiles);
@@ -1011,7 +1011,7 @@ struct lustre_cfg *lustre_cfg_rename(struct lustre_cfg *cfg,
 	new_len = LUSTRE_CFG_BUFLEN(cfg, 1) + strlen(new_name) - name_len;
-	OBD_ALLOC(new_param, new_len);
+	new_param = kzalloc(new_len, GFP_NOFS);
 	if (new_param == NULL)
@@ -1019,9 +1019,9 @@ struct lustre_cfg *lustre_cfg_rename(struct lustre_cfg *cfg,
 	if (value != NULL)
 		strcat(new_param, value);
-	OBD_ALLOC_PTR(bufs);
+	bufs = kzalloc(sizeof(*bufs), GFP_NOFS);
 	if (bufs == NULL) {
-		OBD_FREE(new_param, new_len);
+		kfree(new_param);
@@ -1031,8 +1031,8 @@ struct lustre_cfg *lustre_cfg_rename(struct lustre_cfg *cfg,
 	new_cfg = lustre_cfg_new(cfg->lcfg_command, bufs);
-	OBD_FREE_PTR(bufs);
+	kfree(new_param);
+	kfree(bufs);
 	if (new_cfg == NULL)
@@ -1493,7 +1493,7 @@ int class_config_llog_handler(const struct lu_env *env,
 			inst = 1;
 			inst_len = LUSTRE_CFG_BUFLEN(lcfg, 0) +
 				   sizeof(clli->cfg_instance) * 2 + 4;
-			OBD_ALLOC(inst_name, inst_len);
+			inst_name = kzalloc(inst_len, GFP_NOFS);
 			if (inst_name == NULL) {
 				rc = -ENOMEM;
 				goto out;
@@ -1556,7 +1556,7 @@ int class_config_llog_handler(const struct lu_env *env,
 		lustre_cfg_free(lcfg_new);
 		if (inst)
-			OBD_FREE(inst_name, inst_len);
+			kfree(inst_name);
 		break;
 	default:
@@ -1671,7 +1671,7 @@ int class_config_dump_handler(const struct lu_env *env,
 	char	*outstr;
 	int	 rc = 0;
-	OBD_ALLOC(outstr, 256);
+	outstr = kzalloc(256, GFP_NOFS);
 	if (outstr == NULL)
 		return -ENOMEM;
@@ -1683,7 +1683,7 @@ int class_config_dump_handler(const struct lu_env *env,
 		rc = -EINVAL;
-	OBD_FREE(outstr, 256);
+	kfree(outstr);
 	return rc;
diff --git a/drivers/staging/lustre/lustre/obdclass/obd_mount.c b/drivers/staging/lustre/lustre/obdclass/obd_mount.c
index 3437b2e..04a22169 100644
--- a/drivers/staging/lustre/lustre/obdclass/obd_mount.c
+++ b/drivers/staging/lustre/lustre/obdclass/obd_mount.c
@@ -84,7 +84,7 @@ int lustre_process_log(struct super_block *sb, char *logname,
 	LASSERT(mgc);
 	LASSERT(cfg);
 	if (bufs == NULL)
 		return -ENOMEM;
@@ -97,7 +97,7 @@ int lustre_process_log(struct super_block *sb, char *logname,
 	rc = obd_process_config(mgc, sizeof(*lcfg), lcfg);
 	lustre_cfg_free(lcfg);
+	kfree(bufs);
 	if (rc == -EINVAL)
 		LCONSOLE_ERROR_MSG(0x15b, "%s: The configuration from log '%s' failed from the MGS (%d).  Make sure this client and the MGS are running compatible versions of Lustre.\n",
@@ -247,8 +247,8 @@ int lustre_start_mgc(struct super_block *sb)
 	mutex_lock(&mgc_start_lock);
 	len = strlen(LUSTRE_MGC_OBDNAME) + strlen(libcfs_nid2str(nid)) + 1;
-	OBD_ALLOC(mgcname, len);
-	OBD_ALLOC(niduuid, len + 2);
+	mgcname = kzalloc(len, GFP_NOFS);
+	niduuid = kzalloc(len + 2, GFP_NOFS);
 	if (!mgcname || !niduuid) {
 		rc = -ENOMEM;
 		goto out_free;
@@ -257,7 +257,7 @@ int lustre_start_mgc(struct super_block *sb)
 	mgssec = lsi->lsi_lmd->lmd_mgssec ? lsi->lsi_lmd->lmd_mgssec : "";
 	if (data == NULL) {
 		rc = -ENOMEM;
 		goto out_free;
@@ -375,7 +375,7 @@ int lustre_start_mgc(struct super_block *sb)
 	lsi->lsi_lmd->lmd_mgs_failnodes = 1;
 	/* Random uuid for MGC allows easier reconnects */
-	OBD_ALLOC_PTR(uuid);
+	uuid = kzalloc(sizeof(*uuid), GFP_NOFS);
 	if (!uuid) {
 		rc = -ENOMEM;
 		goto out_free;
@@ -388,7 +388,7 @@ int lustre_start_mgc(struct super_block *sb)
 	rc = lustre_start_simple(mgcname, LUSTRE_MGC_NAME,
 				 (char *)uuid->uuid, LUSTRE_MGS_OBDNAME,
 				 niduuid, NULL, NULL);
-	OBD_FREE_PTR(uuid);
+	kfree(uuid);
 	if (rc)
 		goto out_free;
@@ -465,11 +465,11 @@ out_free:
 	mutex_unlock(&mgc_start_lock);
 	if (data)
-		OBD_FREE_PTR(data);
+		kfree(data);
 	if (mgcname)
-		OBD_FREE(mgcname, len);
+		kfree(mgcname);
 	if (niduuid)
-		OBD_FREE(niduuid, len + 2);
+		kfree(niduuid);
 	return rc;
@@ -513,7 +513,7 @@ static int lustre_stop_mgc(struct super_block *sb)
 	/* Save the obdname for cleaning the nid uuids, which are
 	   obdname_XX */
 	len = strlen(obd->obd_name) + 6;
-	OBD_ALLOC(niduuid, len);
+	niduuid = kzalloc(len, GFP_NOFS);
 	if (niduuid) {
 		strcpy(niduuid, obd->obd_name);
 		ptr = niduuid + strlen(niduuid);
@@ -539,7 +539,7 @@ static int lustre_stop_mgc(struct super_block *sb)
 out:
 	if (niduuid)
-		OBD_FREE(niduuid, len);
+		kfree(niduuid);
 	/* class_import_put will get rid of the additional connections */
@@ -552,12 +552,12 @@ struct lustre_sb_info *lustre_init_lsi(struct super_block *sb)
 	struct lustre_sb_info *lsi;
-	OBD_ALLOC_PTR(lsi);
+	lsi = kzalloc(sizeof(*lsi), GFP_NOFS);
 	if (!lsi)
 		return NULL;
-	OBD_ALLOC_PTR(lsi->lsi_lmd);
+	lsi->lsi_lmd = kzalloc(sizeof(*lsi->lsi_lmd), GFP_NOFS);
 	if (!lsi->lsi_lmd) {
-		OBD_FREE_PTR(lsi);
+		kfree(lsi);
 		return NULL;
@@ -586,35 +586,27 @@ static int lustre_free_lsi(struct super_block *sb)
 	if (lsi->lsi_lmd != NULL) {
 		if (lsi->lsi_lmd->lmd_dev != NULL)
-			OBD_FREE(lsi->lsi_lmd->lmd_dev,
-				 strlen(lsi->lsi_lmd->lmd_dev) + 1);
+			kfree(lsi->lsi_lmd->lmd_dev);
 		if (lsi->lsi_lmd->lmd_profile != NULL)
-			OBD_FREE(lsi->lsi_lmd->lmd_profile,
-				 strlen(lsi->lsi_lmd->lmd_profile) + 1);
+			kfree(lsi->lsi_lmd->lmd_profile);
 		if (lsi->lsi_lmd->lmd_mgssec != NULL)
-			OBD_FREE(lsi->lsi_lmd->lmd_mgssec,
-				 strlen(lsi->lsi_lmd->lmd_mgssec) + 1);
+			kfree(lsi->lsi_lmd->lmd_mgssec);
 		if (lsi->lsi_lmd->lmd_opts != NULL)
-			OBD_FREE(lsi->lsi_lmd->lmd_opts,
-				 strlen(lsi->lsi_lmd->lmd_opts) + 1);
+			kfree(lsi->lsi_lmd->lmd_opts);
 		if (lsi->lsi_lmd->lmd_exclude_count)
-			OBD_FREE(lsi->lsi_lmd->lmd_exclude,
-				 sizeof(lsi->lsi_lmd->lmd_exclude[0]) *
-				 lsi->lsi_lmd->lmd_exclude_count);
+			kfree(lsi->lsi_lmd->lmd_exclude);
 		if (lsi->lsi_lmd->lmd_mgs != NULL)
-			OBD_FREE(lsi->lsi_lmd->lmd_mgs,
-				 strlen(lsi->lsi_lmd->lmd_mgs) + 1);
+			kfree(lsi->lsi_lmd->lmd_mgs);
 		if (lsi->lsi_lmd->lmd_osd_type != NULL)
-			OBD_FREE(lsi->lsi_lmd->lmd_osd_type,
-				 strlen(lsi->lsi_lmd->lmd_osd_type) + 1);
+			kfree(lsi->lsi_lmd->lmd_osd_type);
 		if (lsi->lsi_lmd->lmd_params != NULL)
-			OBD_FREE(lsi->lsi_lmd->lmd_params, 4096);
+			kfree(lsi->lsi_lmd->lmd_params);
-		OBD_FREE(lsi->lsi_lmd, sizeof(*lsi->lsi_lmd));
+		kfree(lsi->lsi_lmd);
 	LASSERT(lsi->lsi_llsbi == NULL);
-	OBD_FREE(lsi, sizeof(*lsi));
+	kfree(lsi);
 	s2lsi_nocast(sb) = NULL;
 	return 0;
@@ -846,7 +838,7 @@ static int lmd_make_exclusion(struct lustre_mount_data *lmd, const char *ptr)
 	devmax = strlen(ptr) / 8 + 1;
 	/* temp storage until we figure out how many we have */
-	OBD_ALLOC(exclude_list, sizeof(index) * devmax);
+	exclude_list = kcalloc(devmax, sizeof(index), GFP_NOFS);
 	if (!exclude_list)
 		return -ENOMEM;
@@ -875,8 +867,8 @@ static int lmd_make_exclusion(struct lustre_mount_data *lmd, const char *ptr)
 	if (lmd->lmd_exclude_count) {
 		/* permanent, freed in lustre_free_lsi */
-		OBD_ALLOC(lmd->lmd_exclude, sizeof(index) *
-			  lmd->lmd_exclude_count);
+		lmd->lmd_exclude = kcalloc(lmd->lmd_exclude_count,
+					   sizeof(index), GFP_NOFS);
 		if (lmd->lmd_exclude) {
 			memcpy(lmd->lmd_exclude, exclude_list,
 			       sizeof(index) * lmd->lmd_exclude_count);
@@ -885,7 +877,7 @@ static int lmd_make_exclusion(struct lustre_mount_data *lmd, const char *ptr)
 			lmd->lmd_exclude_count = 0;
-	OBD_FREE(exclude_list, sizeof(index) * devmax);
+	kfree(exclude_list);
 	return rc;
@@ -895,7 +887,7 @@ static int lmd_parse_mgssec(struct lustre_mount_data *lmd, char *ptr)
 	int     length;
 	if (lmd->lmd_mgssec != NULL) {
-		OBD_FREE(lmd->lmd_mgssec, strlen(lmd->lmd_mgssec) + 1);
+		kfree(lmd->lmd_mgssec);
 		lmd->lmd_mgssec = NULL;
@@ -905,7 +897,7 @@ static int lmd_parse_mgssec(struct lustre_mount_data *lmd, char *ptr)
 	else
 		length = tail - ptr;
-	OBD_ALLOC(lmd->lmd_mgssec, length + 1);
+	lmd->lmd_mgssec = kzalloc(length + 1, GFP_NOFS);
 	if (lmd->lmd_mgssec == NULL)
 		return -ENOMEM;
@@ -923,7 +915,7 @@ static int lmd_parse_string(char **handle, char *ptr)
 		return -EINVAL;
 	if (*handle != NULL) {
-		OBD_FREE(*handle, strlen(*handle) + 1);
+		kfree(*handle);
 		*handle = NULL;
@@ -933,7 +925,7 @@ static int lmd_parse_string(char **handle, char *ptr)
 	else
-	OBD_ALLOC(*handle, length + 1);
+	*handle = kzalloc(length + 1, GFP_NOFS);
 	if (*handle == NULL)
 		return -ENOMEM;
@@ -963,7 +955,7 @@ static int lmd_parse_mgs(struct lustre_mount_data *lmd, char **ptr)
 	if (lmd->lmd_mgs != NULL)
 		oldlen = strlen(lmd->lmd_mgs) + 1;
-	OBD_ALLOC(mgsnid, oldlen + length + 1);
+	mgsnid = kzalloc(oldlen + length + 1, GFP_NOFS);
 	if (mgsnid == NULL)
 		return -ENOMEM;
@@ -971,7 +963,7 @@ static int lmd_parse_mgs(struct lustre_mount_data *lmd, char **ptr)
 		/* Multiple mgsnid= are taken to mean failover locations */
 		memcpy(mgsnid, lmd->lmd_mgs, oldlen);
 		mgsnid[oldlen - 1] = ':';
-		OBD_FREE(lmd->lmd_mgs, oldlen);
+		kfree(lmd->lmd_mgs);
 	memcpy(mgsnid + oldlen, *ptr, length);
 	mgsnid[oldlen + length] = '\0';
@@ -1005,7 +997,7 @@ static int lmd_parse(char *options, struct lustre_mount_data *lmd)
 	lmd->lmd_magic = LMD_MAGIC;
-	OBD_ALLOC(lmd->lmd_params, 4096);
+	lmd->lmd_params = kzalloc(4096, GFP_NOFS);
 	if (lmd->lmd_params == NULL)
 		return -ENOMEM;
 	lmd->lmd_params[0] = '\0';
@@ -1143,14 +1135,14 @@ static int lmd_parse(char *options, struct lustre_mount_data *lmd)
 		/* Remove leading /s from fsname */
 		while (*++s1 == '/') ;
 		/* Freed in lustre_free_lsi */
-		OBD_ALLOC(lmd->lmd_profile, strlen(s1) + 8);
+		lmd->lmd_profile = kzalloc(strlen(s1) + 8, GFP_NOFS);
 		if (!lmd->lmd_profile)
 			return -ENOMEM;
 		sprintf(lmd->lmd_profile, "%s-client", s1);
-	OBD_ALLOC(lmd->lmd_dev, strlen(devname) + 1);
+	lmd->lmd_dev = kzalloc(strlen(devname) + 1, GFP_NOFS);
 	if (!lmd->lmd_dev)
 		return -ENOMEM;
 	strcpy(lmd->lmd_dev, devname);
@@ -1161,7 +1153,7 @@ static int lmd_parse(char *options, struct lustre_mount_data *lmd)
 		*s1-- = 0;
 	if (*options != 0) {
-		OBD_ALLOC(lmd->lmd_opts, strlen(options) + 1);
+		lmd->lmd_opts = kzalloc(strlen(options) + 1, GFP_NOFS);
 		if (!lmd->lmd_opts)
 			return -ENOMEM;
 		strcpy(lmd->lmd_opts, options);
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
