Staging: lustre: obdclass: Remove typedefs for struct
Author: Shraddha Barke <shraddha.6596@gmail.com>
The Linux kernel coding style guidelines suggest not using typedefs for
structure and enum types. This patch gets rid of the typedefs for
lu_site_stats_t.
The following Coccinelle semantic patch detects the cases for struct type:
@tn@
identifier i;
type td;
-typedef
struct i { ... }
-td
type tn.td;
identifier tn.i;
-td
+ struct i
Signed-off-by: Shraddha Barke
drivers/staging/lustre/lustre/obdclass/lu_object.c | 10 +++++-----
1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/drivers/staging/lustre/lustre/obdclass/lu_object.c b/drivers/staging/lustre/lustre/obdclass/lu_object.c
index 55d4523..48d5436 100644
--- a/drivers/staging/lustre/lustre/obdclass/lu_object.c
+++ b/drivers/staging/lustre/lustre/obdclass/lu_object.c
@@ -1784,15 +1784,15 @@ int lu_env_refill_by_tags(struct lu_env *env, __u32 ctags,
EXPORT_SYMBOL(lu_env_refill_by_tags);
-typedef struct lu_site_stats{
+struct lu_site_stats {
unsigned lss_populated;
unsigned lss_max_search;
unsigned lss_total;
unsigned lss_busy;
-} lu_site_stats_t;
static void lu_site_stats_get(struct cfs_hash *hs,
- lu_site_stats_t *stats, int populated)
+ struct lu_site_stats *stats, int populated)
struct cfs_hash_bd bd;
int i;
@@ -1841,7 +1841,7 @@ static void lu_site_stats_get(struct cfs_hash *hs,
static unsigned long lu_cache_shrink_count(struct shrinker *sk,
struct shrink_control *sc)
- lu_site_stats_t stats;
+ struct lu_site_stats stats;
struct lu_site *s;
struct lu_site *tmp;
unsigned long cached = 0;
@@ -2001,7 +2001,7 @@ static __u32 ls_stats_read(struct lprocfs_stats *stats, int idx)
int lu_site_stats_print(const struct lu_site *s, struct seq_file *m)
memset(&stats, 0, sizeof(stats));
lu_site_stats_get(s->ls_obj_hash, &stats, 1); |
unsigned lss_total;
unsigned lss_busy;
-} lu_site_stats_t;
int i;
struct lu_site *s;
