staging: lustre: obdclass: expand the GOTO macro + break
Author: Julia Lawall <Julia.Lawall@lip6.fr>
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
identifier lbl,rc,f;
constant c;
- GOTO(lbl,\(rc\|rc->f\|c\));
- break;
+ goto lbl;
identifier lbl;
expression rc;
- GOTO(lbl,rc);
- break;
+ rc;
+ goto lbl;
Signed-off-by: Julia Lawall
 drivers/staging/lustre/lustre/obdclass/obd_config.c | 16 ++++++++--------
 1 file changed, 8 insertions(+), 8 deletions(-)
diff --git a/drivers/staging/lustre/lustre/obdclass/obd_config.c b/drivers/staging/lustre/lustre/obdclass/obd_config.c
index f41695d..8a9752f 100644
--- a/drivers/staging/lustre/lustre/obdclass/obd_config.c
+++ b/drivers/staging/lustre/lustre/obdclass/obd_config.c
@@ -1226,25 +1226,25 @@ int class_process_config(struct lustre_cfg *lcfg)
 	case LCFG_POOL_NEW: {
 		err = obd_pool_new(obd, lustre_cfg_string(lcfg, 2));
-		GOTO(out, err = 0);
-		break;
+		err = 0;
+		goto out;
 	case LCFG_POOL_ADD: {
 		err = obd_pool_add(obd, lustre_cfg_string(lcfg, 2),
 				   lustre_cfg_string(lcfg, 3));
-		break;
+		err = 0;
+		goto out;
 	case LCFG_POOL_REM: {
 		err = obd_pool_rem(obd, lustre_cfg_string(lcfg, 2),
-		break;
+		err = 0;
+		goto out;
 	case LCFG_POOL_DEL: {
 		err = obd_pool_del(obd, lustre_cfg_string(lcfg, 2));
-		break;
+		err = 0;
+		goto out;
 	default: {
 		err = obd_process_config(obd, sizeof(*lcfg), lcfg);
BtrLinux
Privacy Overview
