staging: lustre: mgc: Use !x to check for kzalloc failure
Author: Julia Lawall <Julia.Lawall@lip6.fr>
!x is more normal for kzalloc failure in the kernel.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
expression x;
statement S1, S2;
x = kzalloc(...);
if (
- x == NULL
+ !x
) S1 else S2
Signed-off-by: Julia Lawall
drivers/staging/lustre/lustre/mgc/mgc_request.c | 4 ++--
1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/staging/lustre/lustre/mgc/mgc_request.c b/drivers/staging/lustre/lustre/mgc/mgc_request.c
index 174dfc3..562bd95 100644
--- a/drivers/staging/lustre/lustre/mgc/mgc_request.c
+++ b/drivers/staging/lustre/lustre/mgc/mgc_request.c
@@ -1128,7 +1128,7 @@ static int mgc_apply_recover_logs(struct obd_device *mgc,
LASSERT(cfg->cfg_sb == cfg->cfg_instance);
inst = kzalloc(PAGE_CACHE_SIZE, GFP_NOFS);
- if (inst == NULL)
+ if (!inst)
return -ENOMEM;
if (!IS_SERVER(lsi)) {
@@ -1493,7 +1493,7 @@ static int mgc_process_cfg_log(struct obd_device *mgc,
lsi = s2lsi(cld->cld_cfg.cfg_sb);
env = kzalloc(sizeof(*env), GFP_NOFS);
- if (env == NULL)
+ if (!env)
return -ENOMEM;
rc = lu_env_init(env, LCT_MG_THREAD); |
- if (inst == NULL)
+ if (!inst)
return -ENOMEM;
- if (env == NULL)
+ if (!env)
return -ENOMEM;
