staging: lustre: mgc: Use kzalloc and kfree
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Replace OBD_ALLOC, OBD_ALLOC_WAIT, OBD_ALLOC_PTR, and OBD_ALLOC_PTR_WAIT by
kalloc/kcalloc, and OBD_FREE and OBD_FREE_PTR by kfree.
A simplified version of the semantic patch that makes these changes is as
follows: (http://coccinelle.lip6.fr/)
@@ expression ptr,size; @@
- OBD_ALLOC(ptr,size)
+ ptr = kzalloc(size, GFP_NOFS)
@@ expression ptr, size; @@
- OBD_FREE(ptr, size);
+ kfree(ptr);
Signed-off-by: Julia Lawall
 drivers/staging/lustre/lustre/mgc/mgc_request.c | 20 ++++++++++----------
 1 file changed, 10 insertions(+), 10 deletions(-)
diff --git a/drivers/staging/lustre/lustre/mgc/mgc_request.c b/drivers/staging/lustre/lustre/mgc/mgc_request.c
index 7947aec..f152e5c 100644
--- a/drivers/staging/lustre/lustre/mgc/mgc_request.c
+++ b/drivers/staging/lustre/lustre/mgc/mgc_request.c
@@ -149,7 +149,7 @@ static void config_log_put(struct config_llog_data *cld)
 			sptlrpc_conf_log_stop(cld->cld_logname);
 		class_export_put(cld->cld_mgcexp);
-		OBD_FREE(cld, sizeof(*cld) + strlen(cld->cld_logname) + 1);
+		kfree(cld);
@@ -198,7 +198,7 @@ struct config_llog_data *do_config_log_add(struct obd_device *obd,
 	CDEBUG(D_MGC, "do adding config log %s:%p\n", logname,
 	       cfg ? cfg->cfg_instance : NULL);
-	OBD_ALLOC(cld, sizeof(*cld) + strlen(logname) + 1);
+	cld = kzalloc(sizeof(*cld) + strlen(logname) + 1, GFP_NOFS);
 	if (!cld)
 		return ERR_PTR(-ENOMEM);
@@ -1129,14 +1129,14 @@ static int mgc_apply_recover_logs(struct obd_device *mgc,
 	LASSERT(cfg->cfg_instance != NULL);
 	LASSERT(cfg->cfg_sb == cfg->cfg_instance);
-	OBD_ALLOC(inst, PAGE_CACHE_SIZE);
+	inst = kzalloc(PAGE_CACHE_SIZE, GFP_NOFS);
 	if (inst == NULL)
 		return -ENOMEM;
 	if (!IS_SERVER(lsi)) {
 		pos = snprintf(inst, PAGE_CACHE_SIZE, "%p", cfg->cfg_instance);
 		if (pos >= PAGE_CACHE_SIZE) {
-			OBD_FREE(inst, PAGE_CACHE_SIZE);
+			kfree(inst);
 			return -E2BIG;
 	} else {
@@ -1144,7 +1144,7 @@ static int mgc_apply_recover_logs(struct obd_device *mgc,
 		rc = server_name2svname(lsi->lsi_svname, inst, NULL,
 					PAGE_CACHE_SIZE);
 		if (rc) {
+			kfree(inst);
 			return -EINVAL;
 		pos = strlen(inst);
@@ -1302,7 +1302,7 @@ static int mgc_apply_recover_logs(struct obd_device *mgc,
 		/* continue, even one with error */
+	kfree(inst);
 	return rc;
@@ -1336,7 +1336,7 @@ static int mgc_process_recover_log(struct obd_device *obd,
 	if (cfg->cfg_last_idx == 0) /* the first time */
 		nrpages = CONFIG_READ_NRPAGES_INIT;
-	OBD_ALLOC(pages, sizeof(*pages) * nrpages);
+	pages = kcalloc(nrpages, sizeof(*pages), GFP_NOFS);
 	if (pages == NULL) {
 		rc = -ENOMEM;
 		goto out;
@@ -1466,7 +1466,7 @@ out:
 				break;
 			__free_page(pages[i]);
-		OBD_FREE(pages, sizeof(*pages) * nrpages);
+		kfree(pages);
 	return rc;
@@ -1494,7 +1494,7 @@ static int mgc_process_cfg_log(struct obd_device *mgc,
 	if (cld->cld_cfg.cfg_sb)
 		lsi = s2lsi(cld->cld_cfg.cfg_sb);
-	OBD_ALLOC_PTR(env);
+	env = kzalloc(sizeof(*env), GFP_NOFS);
 	if (env == NULL)
 		return -ENOMEM;
@@ -1540,7 +1540,7 @@ out_pop:
 	lu_env_fini(env);
 out_free:
-	OBD_FREE_PTR(env);
+	kfree(env);
 	return rc;
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
