staging: lustre: mgc: remove unused variable
Author: Aya Mahfouz <mahfouz.saif.elyazal@gmail.com>
This patch removes a variable that was simply used to
store the return value of a function call before
returning it.
The issue was detected and resolved using the following
coccinelle script:
identifier len,f;
-int len;
 ... when != len
     when strict
-len =
+return
        f(...);
-return len;
Signed-off-by: Aya Mahfouz
 drivers/staging/lustre/lustre/mgc/mgc_request.c | 5 +----
 1 file changed, 1 insertion(+), 4 deletions(-)
diff --git a/drivers/staging/lustre/lustre/mgc/mgc_request.c b/drivers/staging/lustre/lustre/mgc/mgc_request.c
index 8d3dbdc..b244575 100644
--- a/drivers/staging/lustre/lustre/mgc/mgc_request.c
+++ b/drivers/staging/lustre/lustre/mgc/mgc_request.c
@@ -690,8 +690,6 @@ static int mgc_precleanup(struct obd_device *obd, enum obd_cleanup_stage stage)
 static int mgc_cleanup(struct obd_device *obd)
-	int rc;
 	/* COMPAT_146 - old config logs may have added profiles we don't
 	   know about */
 	if (obd->obd_type->typ_refcnt <= 1)
@@ -701,8 +699,7 @@ static int mgc_cleanup(struct obd_device *obd)
 	lprocfs_obd_cleanup(obd);
 	ptlrpcd_decref();
-	rc = client_obd_cleanup(obd);
-	return rc;
+	return client_obd_cleanup(obd);
 static int mgc_setup(struct obd_device *obd, struct lustre_cfg *lcfg)
BtrLinux
Privacy Overview
