staging: lustre: mdc: Use kzalloc and kfree
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Replace OBD_ALLOC, OBD_ALLOC_WAIT, OBD_ALLOC_PTR, and OBD_ALLOC_PTR_WAIT by
kalloc/kcalloc, and OBD_FREE and OBD_FREE_PTR by kfree.
A simplified version of the semantic patch that makes these changes is as
follows: (http://coccinelle.lip6.fr/)
@@ expression ptr,size; @@
- OBD_ALLOC(ptr,size)
+ ptr = kzalloc(size, GFP_NOFS)
@@ expression ptr, size; @@
- OBD_FREE(ptr, size);
+ kfree(ptr);
Signed-off-by: Julia Lawall
 drivers/staging/lustre/lustre/mdc/lproc_mdc.c   |  4 ++--
 drivers/staging/lustre/lustre/mdc/mdc_locks.c   |  2 +-
 drivers/staging/lustre/lustre/mdc/mdc_request.c | 30 ++++++++++++-------------
 3 files changed, 18 insertions(+), 18 deletions(-)
diff --git a/drivers/staging/lustre/lustre/mdc/lproc_mdc.c b/drivers/staging/lustre/lustre/mdc/lproc_mdc.c
index b41e50e..23d22a4 100644
--- a/drivers/staging/lustre/lustre/mdc/lproc_mdc.c
+++ b/drivers/staging/lustre/lustre/mdc/lproc_mdc.c
@@ -106,7 +106,7 @@ static ssize_t mdc_kuc_write(struct file *file,
 	len = sizeof(*lh) + sizeof(*hal) + MTI_NAME_MAXLEN +
 		/* for mockup below */ 2 * cfs_size_round(sizeof(*hai));
-	OBD_ALLOC(lh, len);
+	lh = kzalloc(len, GFP_NOFS);
 	if (!lh)
 		return -ENOMEM;
@@ -141,7 +141,7 @@ static ssize_t mdc_kuc_write(struct file *file,
 		rc = libcfs_kkuc_msg_put(fp, lh);
 		fput(fp);
-	OBD_FREE(lh, len);
+	kfree(lh);
 	if (rc < 0)
 		return rc;
 	return count;
diff --git a/drivers/staging/lustre/lustre/mdc/mdc_locks.c b/drivers/staging/lustre/lustre/mdc/mdc_locks.c
index d1c224e..f935797 100644
--- a/drivers/staging/lustre/lustre/mdc/mdc_locks.c
+++ b/drivers/staging/lustre/lustre/mdc/mdc_locks.c
@@ -1251,7 +1251,7 @@ static int mdc_intent_getattr_async_interpret(const struct lu_env *env,
 	rc = mdc_finish_intent_lock(exp, req, &minfo->mi_data, it, lockh);
 out:
-	OBD_FREE_PTR(einfo);
+	kfree(einfo);
 	minfo->mi_cb(req, minfo, rc);
 	return 0;
diff --git a/drivers/staging/lustre/lustre/mdc/mdc_request.c b/drivers/staging/lustre/lustre/mdc/mdc_request.c
index f8ef5fe..1a4ef9d 100644
--- a/drivers/staging/lustre/lustre/mdc/mdc_request.c
+++ b/drivers/staging/lustre/lustre/mdc/mdc_request.c
@@ -1201,7 +1201,7 @@ static int mdc_ioc_fid2path(struct obd_export *exp, struct getinfo_fid2path *gf)
 	/* Key is KEY_FID2PATH + getinfo_fid2path description */
 	keylen = cfs_size_round(sizeof(KEY_FID2PATH)) + sizeof(*gf);
-	OBD_ALLOC(key, keylen);
+	key = kzalloc(keylen, GFP_NOFS);
 	if (key == NULL)
 		return -ENOMEM;
 	memcpy(key, KEY_FID2PATH, sizeof(KEY_FID2PATH));
@@ -1234,7 +1234,7 @@ static int mdc_ioc_fid2path(struct obd_export *exp, struct getinfo_fid2path *gf)
 	       PFID(&gf->gf_fid), gf->gf_recno, gf->gf_linkno, gf->gf_path);
 out:
-	OBD_FREE(key, keylen);
+	kfree(key);
 	return rc;
@@ -1604,7 +1604,7 @@ static int mdc_changelog_send_thread(void *csdata)
 	CDEBUG(D_CHANGELOG, "changelog to fp=%p start %llu\n",
 	       cs->cs_fp, cs->cs_startrec);
-	OBD_ALLOC(cs->cs_buf, KUC_CHANGELOG_MSG_MAXSIZE);
+	cs->cs_buf = kzalloc(KUC_CHANGELOG_MSG_MAXSIZE, GFP_NOFS);
 	if (cs->cs_buf == NULL) {
 		rc = -ENOMEM;
 		goto out;
@@ -1645,8 +1645,8 @@ out:
 	if (ctxt)
 		llog_ctxt_put(ctxt);
 	if (cs->cs_buf)
-		OBD_FREE(cs->cs_buf, KUC_CHANGELOG_MSG_MAXSIZE);
-	OBD_FREE_PTR(cs);
+		kfree(cs->cs_buf);
+	kfree(cs);
 	return rc;
@@ -1657,7 +1657,7 @@ static int mdc_ioc_changelog_send(struct obd_device *obd,
 	int rc;
 	/* Freed in mdc_changelog_send_thread */
-	OBD_ALLOC_PTR(cs);
+	cs = kzalloc(sizeof(*cs), GFP_NOFS);
 	if (!cs)
 		return -ENOMEM;
@@ -1679,7 +1679,7 @@ static int mdc_ioc_changelog_send(struct obd_device *obd,
 	CERROR("Failed to start changelog thread: %d\n", rc);
-	OBD_FREE_PTR(cs);
+	kfree(cs);
 	return rc;
@@ -1937,7 +1937,7 @@ static int mdc_iocontrol(unsigned int cmd, struct obd_export *exp, int len,
 		struct if_quotactl *qctl = karg;
 		struct obd_quotactl *oqctl;
-		OBD_ALLOC_PTR(oqctl);
+		oqctl = kzalloc(sizeof(*oqctl), GFP_NOFS);
 		if (oqctl == NULL) {
 			rc = -ENOMEM;
 			goto out;
@@ -1951,7 +1951,7 @@ static int mdc_iocontrol(unsigned int cmd, struct obd_export *exp, int len,
 			qctl->obd_uuid = obd->u.cli.cl_target_uuid;
-		OBD_FREE_PTR(oqctl);
+		kfree(oqctl);
 		goto out;
 	case LL_IOC_GET_CONNECT_FLAGS:
@@ -2430,14 +2430,14 @@ static int mdc_setup(struct obd_device *obd, struct lustre_cfg *cfg)
 	struct lprocfs_static_vars lvars = { NULL };
 	int rc;
-	OBD_ALLOC(cli->cl_rpc_lock, sizeof(*cli->cl_rpc_lock));
+	cli->cl_rpc_lock = kzalloc(sizeof(*cli->cl_rpc_lock), GFP_NOFS);
 	if (!cli->cl_rpc_lock)
 		return -ENOMEM;
 	mdc_init_rpc_lock(cli->cl_rpc_lock);
 	ptlrpcd_addref();
-	OBD_ALLOC(cli->cl_close_lock, sizeof(*cli->cl_close_lock));
+	cli->cl_close_lock = kzalloc(sizeof(*cli->cl_close_lock), GFP_NOFS);
 	if (!cli->cl_close_lock) {
 		rc = -ENOMEM;
 		goto err_rpc_lock;
@@ -2465,9 +2465,9 @@ static int mdc_setup(struct obd_device *obd, struct lustre_cfg *cfg)
 	return rc;
 err_close_lock:
-	OBD_FREE(cli->cl_close_lock, sizeof(*cli->cl_close_lock));
+	kfree(cli->cl_close_lock);
 err_rpc_lock:
-	OBD_FREE(cli->cl_rpc_lock, sizeof(*cli->cl_rpc_lock));
+	kfree(cli->cl_rpc_lock);
 	ptlrpcd_decref();
 	return rc;
@@ -2525,8 +2525,8 @@ static int mdc_cleanup(struct obd_device *obd)
 	struct client_obd *cli = &obd->u.cli;
 	ptlrpcd_decref();
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
