Staging: lustre: lustre: mgc: Remove variable that is not very useful.
Author: Heena Sirwani <heenasirwani@gmail.com>
The following patch removes a variable that is not very useful using
coccinelle.
The semantic patch used was:
identifier ret;
-int ret = 0;
... when != ret
when strict
-return ret;
+return 0;
Signed-off-by: Heena Sirwani
drivers/staging/lustre/lustre/mgc/mgc_request.c | 8 ++------
1 file changed, 2 insertions(+), 6 deletions(-)
diff --git a/drivers/staging/lustre/lustre/mgc/mgc_request.c b/drivers/staging/lustre/lustre/mgc/mgc_request.c
index bc263ad..bbef5c9 100644
--- a/drivers/staging/lustre/lustre/mgc/mgc_request.c
+++ b/drivers/staging/lustre/lustre/mgc/mgc_request.c
@@ -510,8 +510,6 @@ static void do_requeue(struct config_llog_data *cld)
static int mgc_requeue_thread(void *data)
- int rc = 0;
CDEBUG(D_MGC, "Starting requeue thread\n");
/* Keep trying failed locks periodically */
@@ -592,7 +590,7 @@ static int mgc_requeue_thread(void *data)
complete(&rq_exit);
CDEBUG(D_MGC, "Ending requeue thread\n");
- return rc;
+ return 0;
/* Add a cld to the list to requeue. Start the requeue thread if needed.
@@ -1055,8 +1053,6 @@ static int mgc_import_event(struct obd_device *obd,
struct obd_import *imp,
enum obd_import_event event)
- int rc = 0;
LASSERT(imp->imp_obd == obd);
CDEBUG(D_MGC, "import event %#x\n", event);
@@ -1090,7 +1086,7 @@ static int mgc_import_event(struct obd_device *obd,
CERROR("Unknown import event %#x\n", event);
LBUG();
- return rc;
+ return 0;
enum { |
- int rc = 0;
complete(&rq_exit);
- return rc;
+ return 0;
- int rc = 0;
LBUG();
- return rc;
+ return 0;
enum {
