drivers/staging/lustre/lustre/lov/lov_dev.c | 2 +-
drivers/staging/lustre/lustre/lov/lov_io.c | 2 +-
drivers/staging/lustre/lustre/lov/lov_obd.c | 2 +-
drivers/staging/lustre/lustre/lov/lov_pool.c | 2 +-
drivers/staging/lustre/lustre/lov/lov_request.c | 18 +++++++++---------
5 files changed, 13 insertions(+), 13 deletions(-)
diff --git a/drivers/staging/lustre/lustre/lov/lov_dev.c b/drivers/staging/lustre/lustre/lov/lov_dev.c
index 504b24a..8c3bbe5 100644
--- a/drivers/staging/lustre/lustre/lov/lov_dev.c
+++ b/drivers/staging/lustre/lustre/lov/lov_dev.c
@@ -478,7 +478,7 @@ static struct lu_device *lov_device_alloc(const struct lu_env *env,
int rc;
ld = kzalloc(sizeof(*ld), GFP_NOFS);
- if (ld == NULL)
+ if (!ld)
return ERR_PTR(-ENOMEM);
cl_device_init(&ld->ld_cl, t);
diff --git a/drivers/staging/lustre/lustre/lov/lov_io.c b/drivers/staging/lustre/lustre/lov/lov_io.c
index 11c1081..bf36291 100644
--- a/drivers/staging/lustre/lustre/lov/lov_io.c
+++ b/drivers/staging/lustre/lustre/lov/lov_io.c
@@ -181,7 +181,7 @@ static int lov_io_sub_init(const struct lu_env *env, struct lov_io *lio,
} else {
sub->sub_io = kzalloc(sizeof(*sub->sub_io),
GFP_NOFS);
- if (sub->sub_io == NULL)
+ if (!sub->sub_io)
result = -ENOMEM;
diff --git a/drivers/staging/lustre/lustre/lov/lov_obd.c b/drivers/staging/lustre/lustre/lov/lov_obd.c
index 96c55ac..cd6ed58 100644
--- a/drivers/staging/lustre/lustre/lov/lov_obd.c
+++ b/drivers/staging/lustre/lustre/lov/lov_obd.c
@@ -976,7 +976,7 @@ static int lov_recreate(struct obd_export *exp, struct obdo *src_oa,
src_oa->o_flags & OBD_FL_RECREATE_OBJS);
obj_mdp = kzalloc(sizeof(*obj_mdp), GFP_NOFS);
- if (obj_mdp == NULL)
+ if (!obj_mdp)
return -ENOMEM;
ost_idx = src_oa->o_nlink;
diff --git a/drivers/staging/lustre/lustre/lov/lov_pool.c b/drivers/staging/lustre/lustre/lov/lov_pool.c
index 1e4d3fb..c59b140 100644
--- a/drivers/staging/lustre/lustre/lov/lov_pool.c
+++ b/drivers/staging/lustre/lustre/lov/lov_pool.c
@@ -431,7 +431,7 @@ int lov_pool_new(struct obd_device *obd, char *poolname)
return -ENAMETOOLONG;
new_pool = kzalloc(sizeof(*new_pool), GFP_NOFS);
- if (new_pool == NULL)
+ if (!new_pool)
return -ENOMEM;
strncpy(new_pool->pool_name, poolname, LOV_MAXPOOLNAME);
diff --git a/drivers/staging/lustre/lustre/lov/lov_request.c b/drivers/staging/lustre/lustre/lov/lov_request.c
index f4de8b8..416e42e 100644
--- a/drivers/staging/lustre/lustre/lov/lov_request.c
+++ b/drivers/staging/lustre/lustre/lov/lov_request.c
@@ -275,7 +275,7 @@ int lov_prep_getattr_set(struct obd_export *exp, struct obd_info *oinfo,
int rc = 0, i;
set = kzalloc(sizeof(*set), GFP_NOFS);
- if (set == NULL)
+ if (!set)
return -ENOMEM;
lov_init_set(set);
@@ -301,7 +301,7 @@ int lov_prep_getattr_set(struct obd_export *exp, struct obd_info *oinfo,
req = kzalloc(sizeof(*req), GFP_NOFS);
- if (req == NULL) {
+ if (!req) {
rc = -ENOMEM;
goto out_set;
@@ -358,7 +358,7 @@ int lov_prep_destroy_set(struct obd_export *exp, struct obd_info *oinfo,
int rc = 0, i;
- if (set == NULL)
+ if (!set)
return -ENOMEM;
lov_init_set(set);
@@ -384,7 +384,7 @@ int lov_prep_destroy_set(struct obd_export *exp, struct obd_info *oinfo,
+ if (!req) {
rc = -ENOMEM;
goto out_set;
@@ -477,7 +477,7 @@ int lov_prep_setattr_set(struct obd_export *exp, struct obd_info *oinfo,
int rc = 0, i;
- if (set == NULL)
+ if (!set)
return -ENOMEM;
lov_init_set(set);
@@ -500,7 +500,7 @@ int lov_prep_setattr_set(struct obd_export *exp, struct obd_info *oinfo,
+ if (!req) {
rc = -ENOMEM;
goto out_set;
@@ -704,7 +704,7 @@ int lov_prep_statfs_set(struct obd_device *obd, struct obd_info *oinfo,
int rc = 0, i;
- if (set == NULL)
+ if (!set)
return -ENOMEM;
lov_init_set(set);
@@ -730,14 +730,14 @@ int lov_prep_statfs_set(struct obd_device *obd, struct obd_info *oinfo,
+ if (!req) {
rc = -ENOMEM;
goto out_set;
req->rq_oi.oi_osfs = kzalloc(sizeof(*req->rq_oi.oi_osfs),
GFP_NOFS);
- if (req->rq_oi.oi_osfs == NULL) {
+ if (!req->rq_oi.oi_osfs) {
kfree(req);
rc = -ENOMEM;
goto out_set; |
