Staging: lustre: lnet: Remove braces for single statement blocks
Author: Shraddha Barke <shraddha.6596@gmail.com>
The linux kernel coding style discourages use of braces for single
statement blocks. This patch removes the unnecessary braces.
The warning was detected using checkpatch.pl. Coccinelle was used
to make the change.
Signed-off-by: Shraddha Barke
 drivers/staging/lustre/lnet/klnds/o2iblnd/o2iblnd_cb.c | 5 ++---
 1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/drivers/staging/lustre/lnet/klnds/o2iblnd/o2iblnd_cb.c b/drivers/staging/lustre/lnet/klnds/o2iblnd/o2iblnd_cb.c
index a23a6d9..345ed4d 100644
--- a/drivers/staging/lustre/lnet/klnds/o2iblnd/o2iblnd_cb.c
+++ b/drivers/staging/lustre/lnet/klnds/o2iblnd/o2iblnd_cb.c
@@ -253,11 +253,10 @@ kiblnd_handle_completion(kib_conn_t *conn, int txtype, int status, __u64 cookie)
 	if (tx->tx_status == 0) {	       /* success so far */
-		if (status < 0) {	       /* failed? */
+		if (status < 0) /* failed? */
 			tx->tx_status = status;
-		} else if (txtype == IBLND_MSG_GET_REQ) {
+		else if (txtype == IBLND_MSG_GET_REQ)
 			lnet_set_reply_msg_len(ni, tx->tx_lntmsg[1], status);
 	tx->tx_waiting = 0;
BtrLinux
Privacy Overview
