staging: lustre: lnet: lib-move: Use list_for_each_entry_safe
Author: Bhaktipriya Shridhar <bhaktipriya96@gmail.com>
Doubly linked lists which are  iterated  using list_empty
and list_entry macros have been replaced with list_for_each_entry_safe
macro.
This makes the iteration simpler and more readable.
This patch replaces the while loop containing list_empty and list_entry
with list_for_each_entry_safe.
This was done with Coccinelle.
expression E1;
identifier I1, I2;
type T;
iterator name list_for_each_entry_safe;
T *I1;
+ T *tmp;
- while (list_empty(&E1) == 0)
+ list_for_each_entry_safe (I1, tmp, &E1, I2)
...when != T *I1;
- I1 = list_entry(E1.next, T, I2);
Signed-off-by: Bhaktipriya Shridhar
 drivers/staging/lustre/lnet/lnet/lib-move.c | 9 ++++-----
 1 file changed, 4 insertions(+), 5 deletions(-)
diff --git a/drivers/staging/lustre/lnet/lnet/lib-move.c b/drivers/staging/lustre/lnet/lnet/lib-move.c
index b821704..0009a8d 100644
--- a/drivers/staging/lustre/lnet/lnet/lib-move.c
+++ b/drivers/staging/lustre/lnet/lnet/lib-move.c
@@ -50,6 +50,7 @@ int
 lnet_fail_nid(lnet_nid_t nid, unsigned int threshold)
 	lnet_test_peer_t *tp;
+	lnet_test_peer_t *temp;
 	struct list_head *el;
 	struct list_head *next;
 	struct list_head cull;
@@ -88,9 +89,7 @@ lnet_fail_nid(lnet_nid_t nid, unsigned int threshold)
 	lnet_net_unlock(0);
-	while (!list_empty(&cull)) {
-		tp = list_entry(cull.next, lnet_test_peer_t, tp_list);
+	list_for_each_entry_safe(tp, temp, &cull, tp_list) {
 		list_del(&tp->tp_list);
 		LIBCFS_FREE(tp, sizeof(*tp));
@@ -101,6 +100,7 @@ static int
 fail_peer(lnet_nid_t nid, int outgoing)
@@ -147,8 +147,7 @@ fail_peer(lnet_nid_t nid, int outgoing)
 	lnet_net_unlock(0);
BtrLinux
Privacy Overview
