staging: lustre: lmv: Use kzalloc and kfree
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Replace OBD_ALLOC, OBD_ALLOC_WAIT, OBD_ALLOC_PTR, and OBD_ALLOC_PTR_WAIT by
kalloc/kcalloc, and OBD_FREE and OBD_FREE_PTR by kfree.
A simplified version of the semantic patch that makes these changes is as
follows: (http://coccinelle.lip6.fr/)
@@ expression ptr,size; @@
- OBD_ALLOC(ptr,size)
+ ptr = kzalloc(size, GFP_NOFS)
@@ expression ptr, size; @@
- OBD_FREE(ptr, size);
+ kfree(ptr);
Signed-off-by: Julia Lawall
 drivers/staging/lustre/lustre/lmv/lmv_intent.c |  4 ++--
 drivers/staging/lustre/lustre/lmv/lmv_obd.c    | 28 +++++++++++++-------------
 2 files changed, 16 insertions(+), 16 deletions(-)
diff --git a/drivers/staging/lustre/lustre/lmv/lmv_intent.c b/drivers/staging/lustre/lustre/lmv/lmv_intent.c
index d22d57b..cb35f63 100644
--- a/drivers/staging/lustre/lustre/lmv/lmv_intent.c
+++ b/drivers/staging/lustre/lustre/lmv/lmv_intent.c
@@ -99,7 +99,7 @@ static int lmv_intent_remote(struct obd_export *exp, void *lmm,
 		goto out;
-	OBD_ALLOC_PTR(op_data);
+	op_data = kzalloc(sizeof(*op_data), GFP_NOFS);
 	if (op_data == NULL) {
 		rc = -ENOMEM;
 		goto out;
@@ -142,7 +142,7 @@ static int lmv_intent_remote(struct obd_export *exp, void *lmm,
 	it->d.lustre.it_lock_mode = pmode;
 out_free_op_data:
-	OBD_FREE_PTR(op_data);
+	kfree(op_data);
 out:
 	if (rc && pmode)
 		ldlm_lock_decref(&plock, pmode);
diff --git a/drivers/staging/lustre/lustre/lmv/lmv_obd.c b/drivers/staging/lustre/lustre/lmv/lmv_obd.c
index b9459fa..59b8fac 100644
--- a/drivers/staging/lustre/lustre/lmv/lmv_obd.c
+++ b/drivers/staging/lustre/lustre/lmv/lmv_obd.c
@@ -442,7 +442,7 @@ static void lmv_del_target(struct lmv_obd *lmv, int index)
 	if (lmv->tgts[index] == NULL)
 		return;
-	OBD_FREE_PTR(lmv->tgts[index]);
+	kfree(lmv->tgts[index]);
 	lmv->tgts[index] = NULL;
 	return;
@@ -488,7 +488,7 @@ static int lmv_add_target(struct obd_device *obd, struct obd_uuid *uuidp,
 		while (newsize < index + 1)
 			newsize <<= 1;
-		OBD_ALLOC(newtgts, sizeof(*newtgts) * newsize);
+		newtgts = kcalloc(newsize, sizeof(*newtgts), GFP_NOFS);
 		if (newtgts == NULL) {
 			lmv_init_unlock(lmv);
 			return -ENOMEM;
@@ -505,13 +505,13 @@ static int lmv_add_target(struct obd_device *obd, struct obd_uuid *uuidp,
 		lmv->tgts_size = newsize;
 		smp_rmb();
 		if (old)
-			OBD_FREE(old, sizeof(*old) * oldsize);
+			kfree(old);
 		CDEBUG(D_CONFIG, "tgts: %p size: %d\n", lmv->tgts,
 		       lmv->tgts_size);
-	OBD_ALLOC_PTR(tgt);
+	tgt = kzalloc(sizeof(*tgt), GFP_NOFS);
 	if (!tgt) {
 		return -ENOMEM;
@@ -750,7 +750,7 @@ repeat_fid2path:
 	/* sigh, has to go to another MDT to do path building further */
 	if (remote_gf == NULL) {
 		remote_gf_size = sizeof(*remote_gf) + PATH_MAX;
-		OBD_ALLOC(remote_gf, remote_gf_size);
+		remote_gf = kzalloc(remote_gf_size, GFP_NOFS);
 			rc = -ENOMEM;
 			goto out_fid2path;
@@ -781,7 +781,7 @@ repeat_fid2path:
 out_fid2path:
 	if (remote_gf != NULL)
-		OBD_FREE(remote_gf, remote_gf_size);
+		kfree(remote_gf);
 	return rc;
@@ -984,7 +984,7 @@ static int lmv_iocontrol(unsigned int cmd, struct obd_export *exp,
 			return -EAGAIN;
 		LASSERT(tgt && tgt->ltd_exp);
-		OBD_ALLOC_PTR(oqctl);
+		oqctl = kzalloc(sizeof(*oqctl), GFP_NOFS);
 		if (!oqctl)
 			return -ENOMEM;
@@ -995,7 +995,7 @@ static int lmv_iocontrol(unsigned int cmd, struct obd_export *exp,
 			qctl->qc_valid = QC_MDTIDX;
 			qctl->obd_uuid = tgt->ltd_uuid;
-		OBD_FREE_PTR(oqctl);
+		kfree(oqctl);
 		break;
 	case OBD_IOC_CHANGELOG_SEND:
@@ -1327,7 +1327,7 @@ static int lmv_setup(struct obd_device *obd, struct lustre_cfg *lcfg)
 		return -EINVAL;
-	OBD_ALLOC(lmv->tgts, sizeof(*lmv->tgts) * 32);
+	lmv->tgts = kcalloc(32, sizeof(*lmv->tgts), GFP_NOFS);
 	if (lmv->tgts == NULL)
 		return -ENOMEM;
 	lmv->tgts_size = 32;
@@ -1380,7 +1380,7 @@ static int lmv_cleanup(struct obd_device *obd)
 				continue;
 			lmv_del_target(lmv, i);
-		OBD_FREE(lmv->tgts, sizeof(*lmv->tgts) * lmv->tgts_size);
+		kfree(lmv->tgts);
 		lmv->tgts_size = 0;
 	return 0;
@@ -1437,7 +1437,7 @@ static int lmv_statfs(const struct lu_env *env, struct obd_export *exp,
 	if (rc)
 		return rc;
-	OBD_ALLOC(temp, sizeof(*temp));
+	temp = kzalloc(sizeof(*temp), GFP_NOFS);
 	if (temp == NULL)
 		return -ENOMEM;
@@ -1473,7 +1473,7 @@ static int lmv_statfs(const struct lu_env *env, struct obd_export *exp,
 out_free_temp:
-	OBD_FREE(temp, sizeof(*temp));
+	kfree(temp);
 	return rc;
@@ -1769,7 +1769,7 @@ lmv_enqueue_remote(struct obd_export *exp, struct ldlm_enqueue_info *einfo,
 		goto out;
-	OBD_ALLOC_PTR(rdata);
+	rdata = kzalloc(sizeof(*rdata), GFP_NOFS);
 	if (rdata == NULL) {
 		rc = -ENOMEM;
 		goto out;
@@ -1780,7 +1780,7 @@ lmv_enqueue_remote(struct obd_export *exp, struct ldlm_enqueue_info *einfo,
 	rc = md_enqueue(tgt->ltd_exp, einfo, it, rdata, lockh,
 			lmm, lmmsize, NULL, extra_lock_flags);
-	OBD_FREE_PTR(rdata);
+	kfree(rdata);
 out:
 	return rc;
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
