Staging: lustre: llite: llite_lib: remove unneeded null test before free
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Kfree can cope with a null argument, so drop null tests.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
@@ expression ptr; @@
- if (ptr != NULL)
  kfree(ptr);
Signed-off-by: Julia Lawall
 drivers/staging/lustre/lustre/llite/llite_lib.c | 12 ++++--------
 1 file changed, 4 insertions(+), 8 deletions(-)
diff --git a/drivers/staging/lustre/lustre/llite/llite_lib.c b/drivers/staging/lustre/lustre/llite/llite_lib.c
index e5bac94..c6611b1 100644
--- a/drivers/staging/lustre/lustre/llite/llite_lib.c
+++ b/drivers/staging/lustre/lustre/llite/llite_lib.c
@@ -574,10 +574,8 @@ static int client_common_fill_super(struct super_block *sb, char *md, char *dt,
 		get_uuid2fsid(uuid->uuid, strlen(uuid->uuid), &sbi->ll_fsid);
-	if (data != NULL)
-		kfree(data);
-	if (osfs != NULL)
-		kfree(osfs);
+	kfree(data);
+	kfree(osfs);
 	return err;
 out_root:
@@ -595,10 +593,8 @@ out_md:
 	obd_disconnect(sbi->ll_md_exp);
 	sbi->ll_md_exp = NULL;
 out:
-	if (data != NULL)
-		kfree(data);
-	if (osfs != NULL)
-		kfree(osfs);
+	kfree(data);
+	kfree(osfs);
 	lprocfs_unregister_mountpoint(sbi);
 	return err;
BtrLinux
Privacy Overview
