staging: lustre: libcfs: Use list_for_each_entry_safe
Author: Bhaktipriya Shridhar <bhaktipriya96@gmail.com>
Doubly linked lists which are  iterated  using list_empty
and list_entry macros have been replaced with list_for_each_entry_safe
macro.
This makes the iteration simpler and more readable.
This patch replaces the while loop containing list_empty and list_entry
with list_for_each_entry_safe.
This was done with Coccinelle.
expression E1;
identifier I1, I2;
type T;
iterator name list_for_each_entry_safe;
T *I1;
+ T *tmp;
- while (list_empty(&E1) == 0)
+ list_for_each_entry_safe (I1, tmp, &E1, I2)
...when != T *I1;
- I1 = list_entry(E1.next, T, I2);
Signed-off-by: Bhaktipriya Shridhar
 drivers/staging/lustre/lnet/libcfs/workitem.c | 5 ++---
 1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/drivers/staging/lustre/lnet/libcfs/workitem.c b/drivers/staging/lustre/lnet/libcfs/workitem.c
index f2ebed8..c72fe00 100644
--- a/drivers/staging/lustre/lnet/libcfs/workitem.c
+++ b/drivers/staging/lustre/lnet/libcfs/workitem.c
@@ -436,6 +436,7 @@ void
 cfs_wi_shutdown(void)
 	struct cfs_wi_sched	*sched;
+	struct cfs_wi_sched *temp;
 	spin_lock(&cfs_wi_data.wi_glock);
 	cfs_wi_data.wi_stopping = 1;
@@ -458,9 +459,7 @@ cfs_wi_shutdown(void)
 		spin_unlock(&cfs_wi_data.wi_glock);
-	while (!list_empty(&cfs_wi_data.wi_scheds)) {
-		sched = list_entry(cfs_wi_data.wi_scheds.next,
-				   struct cfs_wi_sched, ws_list);
+	list_for_each_entry_safe(sched, temp, &cfs_wi_data.wi_scheds, ws_list) {
 		list_del(&sched->ws_list);
 		LIBCFS_FREE(sched, sizeof(*sched));
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
