Staging: lustre: libcfs: Prefer using the BIT macro
Author: Shraddha Barke <shraddha.6596@gmail.com>
This patch replaces bit shifting on 1 with the BIT(x) macro
This was done with coccinelle:
@@ int g; @@
-(1 << g)
+BIT(g)
Signed-off-by: Shraddha Barke
 drivers/staging/lustre/lustre/libcfs/hash.c | 8 ++++----
 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/staging/lustre/lustre/libcfs/hash.c b/drivers/staging/lustre/lustre/libcfs/hash.c
index 08f0b48..286641b 100644
--- a/drivers/staging/lustre/lustre/libcfs/hash.c
+++ b/drivers/staging/lustre/lustre/libcfs/hash.c
@@ -588,13 +588,13 @@ EXPORT_SYMBOL(cfs_hash_bd_move_locked);
 enum {
 	/** always set, for sanity (avoid ZERO intent) */
-	CFS_HS_LOOKUP_MASK_FIND     = 1 << 0,
+	CFS_HS_LOOKUP_MASK_FIND     = BIT(0),
 	/** return entry with a ref */
-	CFS_HS_LOOKUP_MASK_REF      = 1 << 1,
+	CFS_HS_LOOKUP_MASK_REF      = BIT(1),
 	/** add entry if not existing */
-	CFS_HS_LOOKUP_MASK_ADD      = 1 << 2,
+	CFS_HS_LOOKUP_MASK_ADD      = BIT(2),
 	/** delete entry, ignore other masks */
-	CFS_HS_LOOKUP_MASK_DEL      = 1 << 3,
+	CFS_HS_LOOKUP_MASK_DEL      = BIT(3),
 typedef enum cfs_hash_lookup_intent {
BtrLinux
Privacy Overview
