Staging: lustre: libcfs: libcfs_mem.c: Remove explicit NULL comparison
Author: Shraddha Barke <shraddha.6596@gmail.com>
Remove explicit NULL comparison and write it in its simpler form.
Replacement done with coccinelle:
@replace_rule@
expression e;
-e == NULL
+ !e
Signed-off-by: Shraddha Barke
 drivers/staging/lustre/lustre/libcfs/libcfs_mem.c | 10 +++++-----
 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/drivers/staging/lustre/lustre/libcfs/libcfs_mem.c b/drivers/staging/lustre/lustre/libcfs/libcfs_mem.c
index 1debdda..f4e08da 100644
--- a/drivers/staging/lustre/lustre/libcfs/libcfs_mem.c
+++ b/drivers/staging/lustre/lustre/libcfs/libcfs_mem.c
@@ -84,7 +84,7 @@ cfs_percpt_alloc(struct cfs_cpt_table *cptab, unsigned int size)
 	count = cfs_cpt_number(cptab);
 	LIBCFS_ALLOC(arr, offsetof(struct cfs_var_array, va_ptrs[count]));
-	if (arr == NULL)
+	if (!arr)
 		return NULL;
 	arr->va_size	= size = L1_CACHE_ALIGN(size);
@@ -93,7 +93,7 @@ cfs_percpt_alloc(struct cfs_cpt_table *cptab, unsigned int size)
 	for (i = 0; i < count; i++) {
 		LIBCFS_CPT_ALLOC(arr->va_ptrs[i], cptab, i, size);
-		if (arr->va_ptrs[i] == NULL) {
+		if (!arr->va_ptrs[i]) {
 			cfs_percpt_free((void *)&arr->va_ptrs[0]);
 			return NULL;
@@ -160,7 +160,7 @@ cfs_array_free(void *vars)
 	arr = container_of(vars, struct cfs_var_array, va_ptrs[0]);
 	for (i = 0; i < arr->va_count; i++) {
 			continue;
 		LIBCFS_FREE(arr->va_ptrs[i], arr->va_size);
@@ -182,7 +182,7 @@ cfs_array_alloc(int count, unsigned int size)
 	int			i;
-	if (arr == NULL)
+	if (!arr)
 		return NULL;
 	arr->va_count	= count;
@@ -191,7 +191,7 @@ cfs_array_alloc(int count, unsigned int size)
 		LIBCFS_ALLOC(arr->va_ptrs[i], size);
 			cfs_array_free((void *)&arr->va_ptrs[0]);
 			return NULL;
BtrLinux
Privacy Overview
