Staging: lustre: libcfs: libcfs_lock.c: Remove explicit NULL comparison
Author: Shraddha Barke <shraddha.6596@gmail.com>
Remove explicit NULL comparison and write it in its simpler form.
Replacement done with coccinelle:
@replace_rule@
expression e;
-e == NULL
+ !e
Signed-off-by: Shraddha Barke
 drivers/staging/lustre/lustre/libcfs/libcfs_lock.c | 6 +++---
 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/staging/lustre/lustre/libcfs/libcfs_lock.c b/drivers/staging/lustre/lustre/libcfs/libcfs_lock.c
index 2c199c7..29308ba 100644
--- a/drivers/staging/lustre/lustre/libcfs/libcfs_lock.c
+++ b/drivers/staging/lustre/lustre/libcfs/libcfs_lock.c
@@ -63,12 +63,12 @@ cfs_percpt_lock_alloc(struct cfs_cpt_table *cptab)
 	/* NB: cptab can be NULL, pcl will be for HW CPUs on that case */
 	LIBCFS_ALLOC(pcl, sizeof(*pcl));
-	if (pcl == NULL)
+	if (!pcl)
 		return NULL;
 	pcl->pcl_cptab = cptab;
 	pcl->pcl_locks = cfs_percpt_alloc(cptab, sizeof(*lock));
-	if (pcl->pcl_locks == NULL) {
+	if (!pcl->pcl_locks) {
 		LIBCFS_FREE(pcl, sizeof(*pcl));
 		return NULL;
@@ -164,7 +164,7 @@ cfs_percpt_atomic_alloc(struct cfs_cpt_table *cptab, int init_val)
 	int		i;
 	refs = cfs_percpt_alloc(cptab, sizeof(*ref));
-	if (refs == NULL)
+	if (!refs)
 		return NULL;
 	cfs_percpt_for_each(ref, i, refs)
BtrLinux
Privacy Overview
