staging: lustre: libcfs: drop trivially useless initialization
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Remove initialization of a variable that is immediately reassigned.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
type T;
identifier x;
constant C;
expression e;
T x
- = C
x = e;
Signed-off-by: Julia Lawall
drivers/staging/lustre/lustre/libcfs/fail.c | 2 +-
drivers/staging/lustre/lustre/libcfs/libcfs_cpu.c | 2 +-
2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/staging/lustre/lustre/libcfs/fail.c b/drivers/staging/lustre/lustre/libcfs/fail.c
index 7b7fc21..42d615f 100644
--- a/drivers/staging/lustre/lustre/libcfs/fail.c
+++ b/drivers/staging/lustre/lustre/libcfs/fail.c
@@ -123,7 +123,7 @@ EXPORT_SYMBOL(__cfs_fail_check_set);
int __cfs_fail_timeout_set(__u32 id, __u32 value, int ms, int set)
- int ret = 0;
+ int ret;
ret = __cfs_fail_check_set(id, value, set);
if (ret) {
diff --git a/drivers/staging/lustre/lustre/libcfs/libcfs_cpu.c b/drivers/staging/lustre/lustre/libcfs/libcfs_cpu.c
index 31a5581..933525c 100644
--- a/drivers/staging/lustre/lustre/libcfs/libcfs_cpu.c
+++ b/drivers/staging/lustre/lustre/libcfs/libcfs_cpu.c
@@ -78,7 +78,7 @@ EXPORT_SYMBOL(cfs_cpt_table_free);
int
cfs_cpt_table_print(struct cfs_cpt_table *cptab, char *buf, int len)
- int rc = 0;
+ int rc;
rc = snprintf(buf, len, "%d\t: %d\n", 0, 0);
len -= rc; |
- int ret = 0;
+ int ret;
if (ret) {
int
- int rc = 0;
+ int rc;
len -= rc;
