staging: lustre: ldlm: Use !x to check for kzalloc failure
Author: Julia Lawall <Julia.Lawall@lip6.fr>
!x is more normal for kzalloc failure in the kernel.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
expression x;
statement S1, S2;
x = kzalloc(...);
if (
- x == NULL
+ !x
 ) S1 else S2
Signed-off-by: Julia Lawall
 drivers/staging/lustre/lustre/ldlm/ldlm_lock.c  | 4 ++--
 drivers/staging/lustre/lustre/ldlm/ldlm_lockd.c | 8 ++++----
 drivers/staging/lustre/lustre/ldlm/ldlm_pool.c  | 2 +-
 3 files changed, 7 insertions(+), 7 deletions(-)
diff --git a/drivers/staging/lustre/lustre/ldlm/ldlm_lock.c b/drivers/staging/lustre/lustre/ldlm/ldlm_lock.c
index bb2246d..cd340fc 100644
--- a/drivers/staging/lustre/lustre/ldlm/ldlm_lock.c
+++ b/drivers/staging/lustre/lustre/ldlm/ldlm_lock.c
@@ -1528,7 +1528,7 @@ struct ldlm_lock *ldlm_lock_create(struct ldlm_namespace *ns,
 	if (lvb_len) {
 		lock->l_lvb_len = lvb_len;
 		lock->l_lvb_data = kzalloc(lvb_len, GFP_NOFS);
-		if (lock->l_lvb_data == NULL)
+		if (!lock->l_lvb_data)
 			goto out;
@@ -1813,7 +1813,7 @@ int ldlm_run_ast_work(struct ldlm_namespace *ns, struct list_head *rpc_list,
 		return 0;
 	arg = kzalloc(sizeof(*arg), GFP_NOFS);
-	if (arg == NULL)
+	if (!arg)
 		return -ENOMEM;
 	atomic_set(&arg->restart, 0);
diff --git a/drivers/staging/lustre/lustre/ldlm/ldlm_lockd.c b/drivers/staging/lustre/lustre/ldlm/ldlm_lockd.c
index b7b6ca1..941eb4e 100644
--- a/drivers/staging/lustre/lustre/ldlm/ldlm_lockd.c
+++ b/drivers/staging/lustre/lustre/ldlm/ldlm_lockd.c
@@ -225,7 +225,7 @@ static void ldlm_handle_cp_callback(struct ptlrpc_request *req,
 			void *lvb_data;
-			if (lvb_data == NULL) {
+			if (!lvb_data) {
 				LDLM_ERROR(lock, "No memory: %d.\n", lvb_len);
 				rc = -ENOMEM;
 				goto out;
@@ -453,7 +453,7 @@ static int ldlm_bl_to_thread(struct ldlm_namespace *ns,
 		struct ldlm_bl_work_item *blwi;
 		blwi = kzalloc(sizeof(*blwi), GFP_NOFS);
-		if (blwi == NULL)
+		if (!blwi)
 			return -ENOMEM;
 		init_blwi(blwi, ns, ld, cancels, count, lock, cancel_flags);
@@ -1053,7 +1053,7 @@ static int ldlm_setup(void)
 		return -EALREADY;
 	ldlm_state = kzalloc(sizeof(*ldlm_state), GFP_NOFS);
-	if (ldlm_state == NULL)
+	if (!ldlm_state)
 		return -ENOMEM;
 	ldlm_kobj = kobject_create_and_add("ldlm", lustre_kobj);
@@ -1123,7 +1123,7 @@ static int ldlm_setup(void)
 	blp = kzalloc(sizeof(*blp), GFP_NOFS);
-	if (blp == NULL) {
+	if (!blp) {
 		rc = -ENOMEM;
 		goto out;
diff --git a/drivers/staging/lustre/lustre/ldlm/ldlm_pool.c b/drivers/staging/lustre/lustre/ldlm/ldlm_pool.c
index 1605b9c..4519d77 100644
--- a/drivers/staging/lustre/lustre/ldlm/ldlm_pool.c
+++ b/drivers/staging/lustre/lustre/ldlm/ldlm_pool.c
@@ -1422,7 +1422,7 @@ static int ldlm_pools_thread_start(void)
 		return -EALREADY;
 	ldlm_pools_thread = kzalloc(sizeof(*ldlm_pools_thread), GFP_NOFS);
-	if (ldlm_pools_thread == NULL)
+	if (!ldlm_pools_thread)
 		return -ENOMEM;
 	init_completion(&ldlm_pools_comp);
