staging: lustre: ldlm: Use kzalloc and kfree
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Replace OBD_ALLOC, OBD_ALLOC_WAIT, OBD_ALLOC_PTR, and OBD_ALLOC_PTR_WAIT by
kalloc/kcalloc, and OBD_FREE and OBD_FREE_PTR by kfree.
A simplified version of the semantic patch that makes these changes is as
follows: (http://coccinelle.lip6.fr/)
@@ expression ptr,size; @@
- OBD_ALLOC(ptr,size)
+ ptr = kzalloc(size, GFP_NOFS)
@@ expression ptr, size; @@
- OBD_FREE(ptr, size);
+ kfree(ptr);
Signed-off-by: Julia Lawall
 drivers/staging/lustre/lustre/ldlm/ldlm_lib.c      |  6 +++---
 drivers/staging/lustre/lustre/ldlm/ldlm_lock.c     | 10 +++++-----
 drivers/staging/lustre/lustre/ldlm/ldlm_lockd.c    | 14 +++++++-------
 drivers/staging/lustre/lustre/ldlm/ldlm_pool.c     | 10 +++++-----
 drivers/staging/lustre/lustre/ldlm/ldlm_resource.c |  8 ++++----
 5 files changed, 24 insertions(+), 24 deletions(-)
diff --git a/drivers/staging/lustre/lustre/ldlm/ldlm_lib.c b/drivers/staging/lustre/lustre/ldlm/ldlm_lib.c
index c5c86e7..d066771 100644
--- a/drivers/staging/lustre/lustre/ldlm/ldlm_lib.c
+++ b/drivers/staging/lustre/lustre/ldlm/ldlm_lib.c
@@ -73,7 +73,7 @@ static int import_set_conn(struct obd_import *imp, struct obd_uuid *uuid,
 	if (create) {
-		OBD_ALLOC(imp_conn, sizeof(*imp_conn));
+		imp_conn = kzalloc(sizeof(*imp_conn), GFP_NOFS);
 		if (!imp_conn) {
 			rc = -ENOMEM;
 			goto out_put;
@@ -120,7 +120,7 @@ static int import_set_conn(struct obd_import *imp, struct obd_uuid *uuid,
 	return 0;
 out_free:
 	if (imp_conn)
-		OBD_FREE(imp_conn, sizeof(*imp_conn));
+		kfree(imp_conn);
 out_put:
 	ptlrpc_connection_put(ptlrpc_conn);
 	return rc;
@@ -179,7 +179,7 @@ int client_import_del_conn(struct obd_import *imp, struct obd_uuid *uuid)
 		list_del(&imp_conn->oic_item);
 		ptlrpc_connection_put(imp_conn->oic_conn);
+		kfree(imp_conn);
 		CDEBUG(D_HA, "imp %p@%s: remove connection %s\n",
 		       imp, imp->imp_obd->obd_name, uuid->uuid);
 		rc = 0;
diff --git a/drivers/staging/lustre/lustre/ldlm/ldlm_lock.c b/drivers/staging/lustre/lustre/ldlm/ldlm_lock.c
index 84b111e..2c5fe14 100644
--- a/drivers/staging/lustre/lustre/ldlm/ldlm_lock.c
+++ b/drivers/staging/lustre/lustre/ldlm/ldlm_lock.c
@@ -209,7 +209,7 @@ void ldlm_lock_put(struct ldlm_lock *lock)
 		if (lock->l_lvb_data != NULL)
-			OBD_FREE(lock->l_lvb_data, lock->l_lvb_len);
+			kfree(lock->l_lvb_data);
 		ldlm_interval_free(ldlm_interval_detach(lock));
 		lu_ref_fini(&lock->l_reference);
@@ -1527,7 +1527,7 @@ struct ldlm_lock *ldlm_lock_create(struct ldlm_namespace *ns,
 	if (lvb_len) {
 		lock->l_lvb_len = lvb_len;
-		OBD_ALLOC(lock->l_lvb_data, lvb_len);
+		lock->l_lvb_data = kzalloc(lvb_len, GFP_NOFS);
 		if (lock->l_lvb_data == NULL)
 			goto out;
@@ -1791,7 +1791,7 @@ int ldlm_work_gl_ast_lock(struct ptlrpc_request_set *rqset, void *opaq)
 	LDLM_LOCK_RELEASE(lock);
 	if ((gl_work->gl_flags & LDLM_GL_WORK_NOFREE) == 0)
-		OBD_FREE_PTR(gl_work);
+		kfree(gl_work);
 	return rc;
@@ -1812,7 +1812,7 @@ int ldlm_run_ast_work(struct ldlm_namespace *ns, struct list_head *rpc_list,
 	if (list_empty(rpc_list))
 		return 0;
-	OBD_ALLOC_PTR(arg);
+	arg = kzalloc(sizeof(*arg), GFP_NOFS);
 	if (arg == NULL)
 		return -ENOMEM;
@@ -1857,7 +1857,7 @@ int ldlm_run_ast_work(struct ldlm_namespace *ns, struct list_head *rpc_list,
 	rc = atomic_read(&arg->restart) ? -ERESTART : 0;
 	goto out;
 out:
-	OBD_FREE_PTR(arg);
+	kfree(arg);
 	return rc;
diff --git a/drivers/staging/lustre/lustre/ldlm/ldlm_lockd.c b/drivers/staging/lustre/lustre/ldlm/ldlm_lockd.c
index 08a91f5..6d731d3 100644
--- a/drivers/staging/lustre/lustre/ldlm/ldlm_lockd.c
+++ b/drivers/staging/lustre/lustre/ldlm/ldlm_lockd.c
@@ -220,7 +220,7 @@ static void ldlm_handle_cp_callback(struct ptlrpc_request *req,
 						     * variable length */
 			void *lvb_data;
-			OBD_ALLOC(lvb_data, lvb_len);
+			lvb_data = kzalloc(lvb_len, GFP_NOFS);
 			if (lvb_data == NULL) {
 				LDLM_ERROR(lock, "No memory: %d.\n", lvb_len);
 				rc = -ENOMEM;
@@ -448,7 +448,7 @@ static int ldlm_bl_to_thread(struct ldlm_namespace *ns,
 	if (cancel_flags & LCF_ASYNC) {
 		struct ldlm_bl_work_item *blwi;
-		OBD_ALLOC(blwi, sizeof(*blwi));
+		blwi = kzalloc(sizeof(*blwi), GFP_NOFS);
 		if (blwi == NULL)
 			return -ENOMEM;
 		init_blwi(blwi, ns, ld, cancels, count, lock, cancel_flags);
@@ -849,7 +849,7 @@ static int ldlm_bl_thread_main(void *arg)
 			memory_pressure_clr();
 		if (blwi->blwi_flags & LCF_ASYNC)
-			OBD_FREE(blwi, sizeof(*blwi));
+			kfree(blwi);
 		else
 			complete(&blwi->blwi_comp);
@@ -1012,7 +1012,7 @@ static int ldlm_setup(void)
 	if (ldlm_state != NULL)
 		return -EALREADY;
-	OBD_ALLOC(ldlm_state, sizeof(*ldlm_state));
+	ldlm_state = kzalloc(sizeof(*ldlm_state), GFP_NOFS);
 	if (ldlm_state == NULL)
 		return -ENOMEM;
@@ -1059,7 +1059,7 @@ static int ldlm_setup(void)
-	OBD_ALLOC(blp, sizeof(*blp));
+	blp = kzalloc(sizeof(*blp), GFP_NOFS);
 	if (blp == NULL) {
 		rc = -ENOMEM;
 		goto out;
@@ -1129,7 +1129,7 @@ static int ldlm_cleanup(void)
 			wait_for_completion(&blp->blp_comp);
-		OBD_FREE(blp, sizeof(*blp));
+		kfree(blp);
 	if (ldlm_state->ldlm_cb_service != NULL)
@@ -1138,7 +1138,7 @@ static int ldlm_cleanup(void)
 	ldlm_proc_cleanup();
-	OBD_FREE(ldlm_state, sizeof(*ldlm_state));
+	kfree(ldlm_state);
 	ldlm_state = NULL;
 	return 0;
diff --git a/drivers/staging/lustre/lustre/ldlm/ldlm_pool.c b/drivers/staging/lustre/lustre/ldlm/ldlm_pool.c
index a9f4833..53e1377 100644
--- a/drivers/staging/lustre/lustre/ldlm/ldlm_pool.c
+++ b/drivers/staging/lustre/lustre/ldlm/ldlm_pool.c
@@ -746,7 +746,7 @@ static int ldlm_pool_proc_init(struct ldlm_pool *pl)
 	char *var_name = NULL;
 	int rc = 0;
-	OBD_ALLOC(var_name, MAX_STRING_SIZE + 1);
+	var_name = kzalloc(MAX_STRING_SIZE + 1, GFP_NOFS);
 	if (!var_name)
 		return -ENOMEM;
@@ -828,7 +828,7 @@ static int ldlm_pool_proc_init(struct ldlm_pool *pl)
 	rc = lprocfs_register_stats(pl->pl_proc_dir, "stats", pl->pl_stats);
 out_free_name:
-	OBD_FREE(var_name, MAX_STRING_SIZE + 1);
+	kfree(var_name);
 	return rc;
@@ -1383,7 +1383,7 @@ static int ldlm_pools_thread_start(void)
 	if (ldlm_pools_thread != NULL)
 		return -EALREADY;
-	OBD_ALLOC_PTR(ldlm_pools_thread);
+	ldlm_pools_thread = kzalloc(sizeof(*ldlm_pools_thread), GFP_NOFS);
 	if (ldlm_pools_thread == NULL)
 		return -ENOMEM;
@@ -1394,7 +1394,7 @@ static int ldlm_pools_thread_start(void)
 			   "ldlm_poold");
 	if (IS_ERR(task)) {
 		CERROR("Can't start pool thread, error %ld\n", PTR_ERR(task));
-		OBD_FREE(ldlm_pools_thread, sizeof(*ldlm_pools_thread));
+		kfree(ldlm_pools_thread);
 		ldlm_pools_thread = NULL;
 		return PTR_ERR(task);
@@ -1417,7 +1417,7 @@ static void ldlm_pools_thread_stop(void)
 	 * in pools thread.
 	wait_for_completion(&ldlm_pools_comp);
-	OBD_FREE_PTR(ldlm_pools_thread);
diff --git a/drivers/staging/lustre/lustre/ldlm/ldlm_resource.c b/drivers/staging/lustre/lustre/ldlm/ldlm_resource.c
index f750d42..5922069 100644
--- a/drivers/staging/lustre/lustre/ldlm/ldlm_resource.c
+++ b/drivers/staging/lustre/lustre/ldlm/ldlm_resource.c
@@ -590,7 +590,7 @@ struct ldlm_namespace *ldlm_namespace_new(struct obd_device *obd, char *name,
 			break;
-	OBD_ALLOC_PTR(ns);
+	ns = kzalloc(sizeof(*ns), GFP_NOFS);
 	if (!ns)
 		goto out_ref;
@@ -657,7 +657,7 @@ out_proc:
 out_hash:
 	cfs_hash_putref(ns->ns_rs_hash);
 out_ns:
-	OBD_FREE_PTR(ns);
+	kfree(ns);
 out_ref:
 	ldlm_put_ref();
 	return NULL;
@@ -904,7 +904,7 @@ void ldlm_namespace_free_post(struct ldlm_namespace *ns)
 	 * this will cause issues related to using freed \a ns in poold
 	 * thread. */
 	LASSERT(list_empty(&ns->ns_list_chain));
-	OBD_FREE_PTR(ns);
+	kfree(ns);
 	ldlm_put_ref();
@@ -1138,7 +1138,7 @@ ldlm_resource_get(struct ldlm_namespace *ns, struct ldlm_resource *parent,
 			       ns->ns_obd->obd_name, name->name[0],
 			       name->name[1], rc);
 			if (res->lr_lvb_data) {
-				OBD_FREE(res->lr_lvb_data, res->lr_lvb_len);
+				kfree(res->lr_lvb_data);
 				res->lr_lvb_data = NULL;
 			res->lr_lvb_len = rc;
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
