staging: lustre: lclient: Use !x to check for kzalloc failure
Author: Julia Lawall <Julia.Lawall@lip6.fr>
!x is more normal for kzalloc failure in the kernel.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
expression x;
statement S1, S2;
x = kzalloc(...);
if (
- x == NULL
+ !x
) S1 else S2
Signed-off-by: Julia Lawall
drivers/staging/lustre/lustre/lclient/lcommon_cl.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/staging/lustre/lustre/lclient/lcommon_cl.c b/drivers/staging/lustre/lustre/lclient/lcommon_cl.c
index e0c1cca..9053f81 100644
--- a/drivers/staging/lustre/lustre/lclient/lcommon_cl.c
+++ b/drivers/staging/lustre/lustre/lclient/lcommon_cl.c
@@ -203,7 +203,7 @@ struct lu_device *ccc_device_alloc(const struct lu_env *env,
int rc;
vdv = kzalloc(sizeof(*vdv), GFP_NOFS);
- if (vdv == NULL)
+ if (!vdv)
return ERR_PTR(-ENOMEM);
lud = &vdv->cdv_cl.cd_lu_dev; |
int rc;
- if (vdv == NULL)
+ if (!vdv)
