staging: lustre: include: replace OBD_CHECK_DEV_ACTIVE by obd_check_dev_active
Author: Aya Mahfouz <mahfouz.saif.elyazal@gmail.com>
Static inline functions are preferred over macros. The inline function
obd_check_dev_active is introduced to replace OBD_CHECK_DEV_ACTIVE.
All functions that call obd_check_dev_active store the return values
and return them if they represent an error code.
Some of the changes were carried out manually while others were done
using coccinelle.
Signed-off-by: Aya Mahfouz
 drivers/staging/lustre/lustre/include/obd_class.h | 29 +++++++++++++++++++----
 1 file changed, 25 insertions(+), 4 deletions(-)
diff --git a/drivers/staging/lustre/lustre/include/obd_class.h b/drivers/staging/lustre/lustre/include/obd_class.h
index 9167164..e533cff 100644
--- a/drivers/staging/lustre/lustre/include/obd_class.h
+++ b/drivers/staging/lustre/lustre/include/obd_class.h
@@ -361,6 +361,19 @@ do {							    \
 } while (0)
+static inline int obd_check_dev_active(struct obd_device *obd)
+	int rc;
+	rc = obd_check_dev(obd);
+	if (rc)
+		return rc;
+	if (!obd->obd_set_up || obd->obd_stopping) {
+		CERROR("Device %d not setup\n", obd->obd_minor);
+		return -ENODEV;
+	return rc;
 #if defined (CONFIG_PROC_FS)
 #define OBD_COUNTER_OFFSET(op)				  \
@@ -901,7 +914,9 @@ static inline int obd_add_conn(struct obd_import *imp, struct obd_uuid *uuid,
 	struct obd_device *obd = imp->imp_obd;
 	int rc;
-	OBD_CHECK_DEV_ACTIVE(obd);
+	rc = obd_check_dev_active(obd);
+	if (rc)
+		return rc;
 	OBD_CHECK_DT_OP(obd, add_conn, -EOPNOTSUPP);
 	OBD_COUNTER_INCREMENT(obd, add_conn);
@@ -914,7 +929,9 @@ static inline int obd_del_conn(struct obd_import *imp, struct obd_uuid *uuid)
 	int rc;
+	if (rc)
+		return rc;
 	OBD_CHECK_DT_OP(obd, del_conn, -EOPNOTSUPP);
 	OBD_COUNTER_INCREMENT(obd, del_conn);
@@ -948,7 +965,9 @@ static inline int obd_connect(const struct lu_env *env,
 	__u64 ocf = data ? data->ocd_connect_flags : 0; /* for post-condition
 						   * check */
+	if (rc)
+		return rc;
 	OBD_CHECK_DT_OP(obd, connect, -EOPNOTSUPP);
 	OBD_COUNTER_INCREMENT(obd, connect);
@@ -970,7 +989,9 @@ static inline int obd_reconnect(const struct lu_env *env,
 	__u64 ocf = d ? d->ocd_connect_flags : 0; /* for post-condition
 						   * check */
+	if (rc)
+		return rc;
 	OBD_CHECK_DT_OP(obd, reconnect, 0);
 	OBD_COUNTER_INCREMENT(obd, reconnect);
BtrLinux
Privacy Overview
