Staging: lustre: fld: Use kzalloc and kfree
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Replace OBD_ALLOC, OBD_ALLOC_WAIT, OBD_ALLOC_PTR, and OBD_ALLOC_PTR_WAIT by
kalloc/kcalloc, and OBD_FREE and OBD_FREE_PTR by kfree.
A simplified version of the semantic patch that makes these changes is as
follows: (http://coccinelle.lip6.fr/)
@@ expression ptr,size; @@
- OBD_ALLOC(ptr,size)
+ ptr = kzalloc(size, GFP_NOFS)
@@ expression ptr, size; @@
- OBD_FREE(ptr, size);
+ kfree(ptr);
Signed-off-by: Julia Lawall
 drivers/staging/lustre/lustre/fld/fld_cache.c   | 16 ++++++++--------
 drivers/staging/lustre/lustre/fld/fld_request.c |  8 ++++----
 2 files changed, 12 insertions(+), 12 deletions(-)
diff --git a/drivers/staging/lustre/lustre/fld/fld_cache.c b/drivers/staging/lustre/lustre/fld/fld_cache.c
index 0d0a737..ec2fc43 100644
--- a/drivers/staging/lustre/lustre/fld/fld_cache.c
+++ b/drivers/staging/lustre/lustre/fld/fld_cache.c
@@ -69,7 +69,7 @@ struct fld_cache *fld_cache_init(const char *name,
 	LASSERT(name != NULL);
 	LASSERT(cache_threshold < cache_size);
-	OBD_ALLOC_PTR(cache);
+	cache = kzalloc(sizeof(*cache), GFP_NOFS);
 	if (cache == NULL)
 		return ERR_PTR(-ENOMEM);
@@ -116,7 +116,7 @@ void fld_cache_fini(struct fld_cache *cache)
 	CDEBUG(D_INFO, "  Cache reqs: %llu\n", cache->fci_stat.fst_cache);
 	CDEBUG(D_INFO, "  Cache hits: %llu%%\n", pct);
-	OBD_FREE_PTR(cache);
+	kfree(cache);
@@ -128,7 +128,7 @@ void fld_cache_entry_delete(struct fld_cache *cache,
 	list_del(&node->fce_list);
 	list_del(&node->fce_lru);
 	cache->fci_cache_count--;
-	OBD_FREE_PTR(node);
+	kfree(node);
@@ -268,7 +268,7 @@ static void fld_cache_punch_hole(struct fld_cache *cache,
 	OBD_ALLOC_GFP(fldt, sizeof(*fldt), GFP_ATOMIC);
 	if (!fldt) {
-		OBD_FREE_PTR(f_new);
+		kfree(f_new);
 		/* overlap is not allowed, so dont mess up list. */
 		return;
@@ -315,7 +315,7 @@ static void fld_cache_overlap_handle(struct fld_cache *cache,
 		f_curr->fce_range.lsr_end = max(f_curr->fce_range.lsr_end,
 						new_end);
+		kfree(f_new);
 		fld_fix_new_list(cache);
 	} else if (new_start <= f_curr->fce_range.lsr_start &&
@@ -324,7 +324,7 @@ static void fld_cache_overlap_handle(struct fld_cache *cache,
 		 *	 e.g. whole range migrated. update fld cache entry */
 		f_curr->fce_range = *range;
+		kfree(f_new);
 	} else if (f_curr->fce_range.lsr_start < new_start &&
@@ -364,7 +364,7 @@ struct fld_cache_entry
 	LASSERT(range_is_sane(range));
-	OBD_ALLOC_PTR(f_new);
+	f_new = kzalloc(sizeof(*f_new), GFP_NOFS);
 	if (!f_new)
@@ -440,7 +440,7 @@ int fld_cache_insert(struct fld_cache *cache,
 	rc = fld_cache_insert_nolock(cache, flde);
 	write_unlock(&cache->fci_lock);
 	if (rc)
-		OBD_FREE_PTR(flde);
+		kfree(flde);
 	return rc;
diff --git a/drivers/staging/lustre/lustre/fld/fld_request.c b/drivers/staging/lustre/lustre/fld/fld_request.c
index 6ac225e..075eb5c 100644
--- a/drivers/staging/lustre/lustre/fld/fld_request.c
+++ b/drivers/staging/lustre/lustre/fld/fld_request.c
@@ -221,7 +221,7 @@ int fld_client_add_target(struct lu_client_fld *fld,
 	CDEBUG(D_INFO, "%s: Adding target %s (idx %llu)\n",
 			fld->lcf_name, name, tar->ft_idx);
-	OBD_ALLOC_PTR(target);
+	target = kzalloc(sizeof(*target), GFP_NOFS);
 	if (target == NULL)
 		return -ENOMEM;
@@ -229,7 +229,7 @@ int fld_client_add_target(struct lu_client_fld *fld,
 	list_for_each_entry(tmp, &fld->lcf_targets, ft_chain) {
 		if (tmp->ft_idx == tar->ft_idx) {
 			spin_unlock(&fld->lcf_lock);
-			OBD_FREE_PTR(target);
+			kfree(target);
 			CERROR("Target %s exists in FLD and known as %s:#%llu\n",
 			       name, fld_target_name(tmp), tmp->ft_idx);
 			return -EEXIST;
@@ -268,7 +268,7 @@ int fld_client_del_target(struct lu_client_fld *fld, __u64 idx)
 			if (target->ft_exp != NULL)
 				class_export_put(target->ft_exp);
+			kfree(target);
 			return 0;
@@ -396,7 +396,7 @@ void fld_client_fini(struct lu_client_fld *fld)
 		list_del(&target->ft_chain);
+		kfree(target);
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
