staging: lustre: Deletion of unnecessary checks before three function calls
Author: Markus Elfring <elfring@users.sourceforge.net>
The following functions test whether their argument is NULL and then
return immediately.
* kfree
* ll_file_data_put
* ptlrpc_connection_put
Thus the test around such calls is not needed.
This issue was detected by using the Coccinelle software.
See also a previous update suggestion:
"remove unneeded null test before free" by Julia Lawall
https://lkml.org/lkml/2015/5/1/498
https://www.mail-archive.com/linux-kernel@vger.kernel.org/msg878600.html
Signed-off-by: Markus Elfring
 drivers/staging/lustre/lustre/llite/file.c      | 3 +--
 drivers/staging/lustre/lustre/llite/llite_lib.c | 2 +-
 drivers/staging/lustre/lustre/ptlrpc/import.c   | 6 ++----
 drivers/staging/lustre/lustre/ptlrpc/service.c  | 4 +---
 4 files changed, 5 insertions(+), 10 deletions(-)
diff --git a/drivers/staging/lustre/lustre/llite/file.c b/drivers/staging/lustre/lustre/llite/file.c
index e01a47c..dcd0c6d 100644
--- a/drivers/staging/lustre/lustre/llite/file.c
+++ b/drivers/staging/lustre/lustre/llite/file.c
@@ -702,8 +702,7 @@ out_och_free:
 out_openerr:
 		if (opendir_set != 0)
 			ll_stop_statahead(inode, lli->lli_opendir_key);
-		if (fd != NULL)
-			ll_file_data_put(fd);
+		ll_file_data_put(fd);
 	} else {
 		ll_stats_ops_tally(ll_i2sbi(inode), LPROC_LL_OPEN, 1);
diff --git a/drivers/staging/lustre/lustre/llite/llite_lib.c b/drivers/staging/lustre/lustre/llite/llite_lib.c
index 2513988..ab4839c 100644
--- a/drivers/staging/lustre/lustre/llite/llite_lib.c
+++ b/drivers/staging/lustre/lustre/llite/llite_lib.c
@@ -1114,7 +1114,7 @@ void ll_clear_inode(struct inode *inode)
 	if (lli->lli_mds_read_och)
 		ll_md_real_close(inode, FMODE_READ);
-	if (S_ISLNK(inode->i_mode) && lli->lli_symlink_name) {
+	if (S_ISLNK(inode->i_mode)) {
 		kfree(lli->lli_symlink_name);
 		lli->lli_symlink_name = NULL;
diff --git a/drivers/staging/lustre/lustre/ptlrpc/import.c b/drivers/staging/lustre/lustre/ptlrpc/import.c
index c9b8481..1eae389 100644
--- a/drivers/staging/lustre/lustre/ptlrpc/import.c
+++ b/drivers/staging/lustre/lustre/ptlrpc/import.c
@@ -555,14 +555,12 @@ static int import_select_connection(struct obd_import *imp)
 	imp_conn->oic_last_attempt = cfs_time_current_64();
 	/* switch connection, don't mind if it's same as the current one */
-	if (imp->imp_connection)
-		ptlrpc_connection_put(imp->imp_connection);
+	ptlrpc_connection_put(imp->imp_connection);
 	imp->imp_connection = ptlrpc_connection_addref(imp_conn->oic_conn);
 	dlmexp = class_conn2export(&imp->imp_dlm_handle);
 	LASSERT(dlmexp != NULL);
-	if (dlmexp->exp_connection)
-		ptlrpc_connection_put(dlmexp->exp_connection);
+	ptlrpc_connection_put(dlmexp->exp_connection);
 	dlmexp->exp_connection = ptlrpc_connection_addref(imp_conn->oic_conn);
 	class_export_put(dlmexp);
diff --git a/drivers/staging/lustre/lustre/ptlrpc/service.c b/drivers/staging/lustre/lustre/ptlrpc/service.c
index 56a8631..cf9477d 100644
--- a/drivers/staging/lustre/lustre/ptlrpc/service.c
+++ b/drivers/staging/lustre/lustre/ptlrpc/service.c
@@ -2826,9 +2826,7 @@ void ptlrpc_hr_fini(void)
 	ptlrpc_stop_hr_threads();
 	cfs_percpt_for_each(hrp, i, ptlrpc_hr.hr_partitions) {
-		if (hrp->hrp_thrs != NULL) {
-			kfree(hrp->hrp_thrs);
+		kfree(hrp->hrp_thrs);
 	cfs_percpt_free(ptlrpc_hr.hr_partitions);
