Staging: line6: Use kmemdup rather than duplicating its implementation
Author: Thomas Meyer <thomas@m3y3r.de>
 The semantic patch that makes this change is available
 in scripts/coccinelle/api/memdup.cocci.
 More information about semantic patching is available at
 http://coccinelle.lip6.fr/
Signed-off-by: Thomas Meyer
 drivers/staging/line6/midi.c | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/staging/line6/midi.c b/drivers/staging/line6/midi.c
index ed5577f..7f1e90e 100644
--- a/drivers/staging/line6/midi.c
+++ b/drivers/staging/line6/midi.c
@@ -135,7 +135,7 @@ static int send_midi_async(struct usb_line6 *line6, unsigned char *data,
 	line6_write_hexdump(line6, 'S', data, length);
 #endif
-	transfer_buffer = kmalloc(length, GFP_ATOMIC);
+	transfer_buffer = kmemdup(data, length, GFP_ATOMIC);
 	if (transfer_buffer == NULL) {
 		usb_free_urb(urb);
@@ -143,7 +143,6 @@ static int send_midi_async(struct usb_line6 *line6, unsigned char *data,
 		return -ENOMEM;
-	memcpy(transfer_buffer, data, length);
 	usb_fill_int_urb(urb, line6->usbdev,
 			 usb_sndbulkpipe(line6->usbdev,
 					 line6->ep_control_write),
BtrLinux
Privacy Overview
