staging: imx-drm: use true and false for bool variables
Author: Valentina Manea <valentina.manea.m@gmail.com>
This patch fixes coccinelle errors for bool variables
initialized with 1 or 0 instead of true and false.
Signed-off-by: Valentina Manea
Reviewed-by: Rusty Russell
 drivers/staging/imx-drm/imx-tve.c           | 4 ++--
 drivers/staging/imx-drm/ipu-v3/ipu-common.c | 4 ++--
 drivers/staging/imx-drm/ipu-v3/ipu-dc.c     | 4 ++--
 drivers/staging/imx-drm/ipu-v3/ipu-dp.c     | 2 +-
 4 files changed, 7 insertions(+), 7 deletions(-)
diff --git a/drivers/staging/imx-drm/imx-tve.c b/drivers/staging/imx-drm/imx-tve.c
index 59dd4d5..680f4c8 100644
--- a/drivers/staging/imx-drm/imx-tve.c
+++ b/drivers/staging/imx-drm/imx-tve.c
@@ -151,7 +151,7 @@ static void tve_enable(struct imx_tve *tve)
 	spin_lock_irqsave(&tve->enable_lock, flags);
 	if (!tve->enabled) {
-		tve->enabled = 1;
+		tve->enabled = true;
 		clk_prepare_enable(tve->clk);
 		ret = regmap_update_bits(tve->regmap, TVE_COM_CONF_REG,
 					 TVE_IPU_CLK_EN | TVE_EN,
@@ -180,7 +180,7 @@ static void tve_disable(struct imx_tve *tve)
 	if (tve->enabled) {
-		tve->enabled = 0;
+		tve->enabled = false;
 					 TVE_IPU_CLK_EN | TVE_EN, 0);
 		clk_disable_unprepare(tve->clk);
diff --git a/drivers/staging/imx-drm/ipu-v3/ipu-common.c b/drivers/staging/imx-drm/ipu-v3/ipu-common.c
index a0e7fc2..77a0c65 100644
--- a/drivers/staging/imx-drm/ipu-v3/ipu-common.c
+++ b/drivers/staging/imx-drm/ipu-v3/ipu-common.c
@@ -564,7 +564,7 @@ struct ipuv3_channel *ipu_idmac_get(struct ipu_soc *ipu, unsigned num)
 		goto out;
-	channel->busy = 1;
+	channel->busy = true;
 	channel->num = num;
 out:
@@ -582,7 +582,7 @@ void ipu_idmac_put(struct ipuv3_channel *channel)
 	mutex_lock(&ipu->channel_lock);
-	channel->busy = 0;
+	channel->busy = false;
 	mutex_unlock(&ipu->channel_lock);
diff --git a/drivers/staging/imx-drm/ipu-v3/ipu-dc.c b/drivers/staging/imx-drm/ipu-v3/ipu-dc.c
index 1a6e06d..d0e3bc3 100644
--- a/drivers/staging/imx-drm/ipu-v3/ipu-dc.c
+++ b/drivers/staging/imx-drm/ipu-v3/ipu-dc.c
@@ -316,7 +316,7 @@ struct ipu_dc *ipu_dc_get(struct ipu_soc *ipu, int channel)
 		return ERR_PTR(-EBUSY);
-	dc->in_use = 1;
+	dc->in_use = true;
 	mutex_unlock(&priv->mutex);
@@ -329,7 +329,7 @@ void ipu_dc_put(struct ipu_dc *dc)
 	struct ipu_dc_priv *priv = dc->priv;
 	mutex_lock(&priv->mutex);
-	dc->in_use = 0;
+	dc->in_use = false;
 EXPORT_SYMBOL_GPL(ipu_dc_put);
diff --git a/drivers/staging/imx-drm/ipu-v3/ipu-dp.c b/drivers/staging/imx-drm/ipu-v3/ipu-dp.c
index 231afd6..58f87c8 100644
--- a/drivers/staging/imx-drm/ipu-v3/ipu-dp.c
+++ b/drivers/staging/imx-drm/ipu-v3/ipu-dp.c
@@ -325,7 +325,7 @@ int ipu_dp_init(struct ipu_soc *ipu, struct device *dev, unsigned long base)
 	mutex_init(&priv->mutex);
 	for (i = 0; i < IPUV3_NUM_FLOWS; i++) {
-		priv->flow[i].foreground.foreground = 1;
+		priv->flow[i].foreground.foreground = true;
 		priv->flow[i].base = priv->base + ipu_dp_flow_base[i];
 		priv->flow[i].priv = priv;
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
