Staging: iio: use !x instead of x == NULL
Author: Somya Anand <somyaanand214@gmail.com>
Functions like devm_kzalloc, kmalloc_array, devm_ioremap,
usb_alloc_urb, alloc_netdev return NULL as a return value on failure.
Generally, When NULL represents failure, !x is commonly used.
This patch cleans up the tests on the results of these functions, thereby
using !x instead of x == NULL or NULL == x. This is done via following
coccinelle script:
@prob_7@
identifier x;
statement S;
x = devm_kzalloc(...);
x = usb_alloc_urb(...);
x = kmalloc_array(...);
x = devm_ioremap(...);
x = alloc_netdev(...);
- if(NULL == x)
+ if(!x)
S
Further we have used isomorphism characteristics of coccinelle to
indicate x == NULL and NULL == x are equivalent. This is done via
following iso script.
Expression
@ is_null @ expression X; @@
X == NULL <=> NULL == X
Signed-off-by: Somya Anand
drivers/staging/iio/trigger/iio-trig-bfin-timer.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/staging/iio/trigger/iio-trig-bfin-timer.c b/drivers/staging/iio/trigger/iio-trig-bfin-timer.c
index 2af8d67..3c1c8c6 100644
--- a/drivers/staging/iio/trigger/iio-trig-bfin-timer.c
+++ b/drivers/staging/iio/trigger/iio-trig-bfin-timer.c
@@ -183,7 +183,7 @@ static int iio_bfin_tmr_trigger_probe(struct platform_device *pdev)
int ret;
st = devm_kzalloc(&pdev->dev, sizeof(*st), GFP_KERNEL);
- if (st == NULL)
+ if (!st)
return -ENOMEM;
st->irq = platform_get_irq(pdev, 0); |
int ret;
- if (st == NULL)
+ if (!st)
return -ENOMEM;
