Staging: iio: Simplify NULL pointer condition
Author: Cristina Opriceana <cristina.opriceana@gmail.com>
Replace NULL comparrison with its shorter form.
Done with coccinelle:
@replace_rule@
expression e;
-e == NULL
+ !e
Signed-off-by: Cristina Opriceana
 drivers/staging/iio/magnetometer/hmc5843_core.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/staging/iio/magnetometer/hmc5843_core.c b/drivers/staging/iio/magnetometer/hmc5843_core.c
index 90cc18b..6befa6f 100644
--- a/drivers/staging/iio/magnetometer/hmc5843_core.c
+++ b/drivers/staging/iio/magnetometer/hmc5843_core.c
@@ -579,7 +579,7 @@ int hmc5843_common_probe(struct device *dev, struct regmap *regmap,
 	int ret;
 	indio_dev = devm_iio_device_alloc(dev, sizeof(*data));
-	if (indio_dev == NULL)
+	if (!indio_dev)
 		return -ENOMEM;
 	dev_set_drvdata(dev, indio_dev);
BtrLinux
Privacy Overview
