Staging: iio: Prefer using the BIT macro
Author: Cristina Opriceana <cristina.opriceana@gmail.com>
This patch replaces bit shifting on 1 with the BIT(x) macro
as it's extensively used by other function in this driver.
This was done with coccinelle:
@@ int g; @@
-(1 << g)
+BIT(g)
Signed-off-by: Cristina Opriceana
Reviewed-by: Daniel Baluta
 drivers/staging/iio/frequency/ad9832.c |  2 +-
 drivers/staging/iio/frequency/ad9832.h | 12 ++++++------
 drivers/staging/iio/frequency/ad9834.c |  4 ++--
 drivers/staging/iio/frequency/ad9834.h | 36 +++++++++++++++++-----------------
 4 files changed, 27 insertions(+), 27 deletions(-)
diff --git a/drivers/staging/iio/frequency/ad9832.c b/drivers/staging/iio/frequency/ad9832.c
index 8ecc0bc..a861fe0 100644
--- a/drivers/staging/iio/frequency/ad9832.c
+++ b/drivers/staging/iio/frequency/ad9832.c
@@ -59,7 +59,7 @@ static int ad9832_write_frequency(struct ad9832_state *st,
 static int ad9832_write_phase(struct ad9832_state *st,
 			      unsigned long addr, unsigned long phase)
-	if (phase > (1 << AD9832_PHASE_BITS))
+	if (phase > BIT(AD9832_PHASE_BITS))
 		return -EINVAL;
 	st->phase_data[0] = cpu_to_be16((AD9832_CMD_PHA8BITSW << CMD_SHIFT) |
diff --git a/drivers/staging/iio/frequency/ad9832.h b/drivers/staging/iio/frequency/ad9832.h
index 386f4dc..d32323b 100644
--- a/drivers/staging/iio/frequency/ad9832.h
+++ b/drivers/staging/iio/frequency/ad9832.h
@@ -42,13 +42,13 @@
 #define AD9832_CMD_SYNCSELSRC	0x8
 #define AD9832_CMD_SLEEPRESCLR	0xC
-#define AD9832_FREQ		(1 << 11)
+#define AD9832_FREQ		BIT(11)
 #define AD9832_PHASE(x)		(((x) & 3) << 9)
-#define AD9832_SYNC		(1 << 13)
-#define AD9832_SELSRC		(1 << 12)
-#define AD9832_SLEEP		(1 << 13)
-#define AD9832_RESET		(1 << 12)
-#define AD9832_CLR		(1 << 11)
+#define AD9832_SYNC		BIT(13)
+#define AD9832_SELSRC		BIT(12)
+#define AD9832_SLEEP		BIT(13)
+#define AD9832_RESET		BIT(12)
+#define AD9832_CLR		BIT(11)
 #define CMD_SHIFT		12
 #define ADD_SHIFT		8
 #define AD9832_FREQ_BITS	32
diff --git a/drivers/staging/iio/frequency/ad9834.c b/drivers/staging/iio/frequency/ad9834.c
index efea560..342c713 100644
--- a/drivers/staging/iio/frequency/ad9834.c
+++ b/drivers/staging/iio/frequency/ad9834.c
@@ -27,7 +27,7 @@
 static unsigned int ad9834_calc_freqreg(unsigned long mclk, unsigned long fout)
-	unsigned long long freqreg = (u64)fout * (u64)(1 << AD9834_FREQ_BITS);
+	unsigned long long freqreg = (u64)fout * (u64)BIT(AD9834_FREQ_BITS);
 	do_div(freqreg, mclk);
 	return freqreg;
@@ -55,7 +55,7 @@ static int ad9834_write_frequency(struct ad9834_state *st,
 static int ad9834_write_phase(struct ad9834_state *st,
-	if (phase > (1 << AD9834_PHASE_BITS))
+	if (phase > BIT(AD9834_PHASE_BITS))
 		return -EINVAL;
 	st->data = cpu_to_be16(addr | phase);
diff --git a/drivers/staging/iio/frequency/ad9834.h b/drivers/staging/iio/frequency/ad9834.h
index 8ca6e52..0a0de4c 100644
--- a/drivers/staging/iio/frequency/ad9834.h
+++ b/drivers/staging/iio/frequency/ad9834.h
@@ -10,31 +10,31 @@
 /* Registers */
-#define AD9834_REG_CMD		(0 << 14)
-#define AD9834_REG_FREQ0	(1 << 14)
-#define AD9834_REG_FREQ1	(2 << 14)
-#define AD9834_REG_PHASE0	(6 << 13)
-#define AD9834_REG_PHASE1	(7 << 13)
+#define AD9834_REG_CMD		0
+#define AD9834_REG_FREQ0	BIT(14)
+#define AD9834_REG_FREQ1	BIT(15)
+#define AD9834_REG_PHASE0	(BIT(15) | BIT(14))
+#define AD9834_REG_PHASE1	(BIT(15) | BIT(14) | BIT(13))
 /* Command Control Bits */
-#define AD9834_B28		(1 << 13)
-#define AD9834_HLB		(1 << 12)
-#define AD9834_FSEL		(1 << 11)
-#define AD9834_PSEL		(1 << 10)
-#define AD9834_PIN_SW		(1 << 9)
-#define AD9834_RESET		(1 << 8)
-#define AD9834_SLEEP1		(1 << 7)
-#define AD9834_SLEEP12		(1 << 6)
-#define AD9834_OPBITEN		(1 << 5)
-#define AD9834_SIGN_PIB		(1 << 4)
-#define AD9834_DIV2		(1 << 3)
-#define AD9834_MODE		(1 << 1)
+#define AD9834_B28		BIT(13)
+#define AD9834_HLB		BIT(12)
+#define AD9834_FSEL		BIT(11)
+#define AD9834_PSEL		BIT(10)
+#define AD9834_PIN_SW		BIT(9)
+#define AD9834_RESET		BIT(8)
+#define AD9834_SLEEP1		BIT(7)
+#define AD9834_SLEEP12		BIT(6)
+#define AD9834_OPBITEN		BIT(5)
+#define AD9834_SIGN_PIB		BIT(4)
+#define AD9834_DIV2		BIT(3)
+#define AD9834_MODE		BIT(1)
 #define AD9834_FREQ_BITS	28
 #define AD9834_PHASE_BITS	12
-#define RES_MASK(bits)	((1 << (bits)) - 1)
+#define RES_MASK(bits)	(BIT(bits) - 1)
  * struct ad9834_state - driver instance specific data
BtrLinux
Privacy Overview
