staging: iio: meter: remove unused variable
Author: Aya Mahfouz <mahfouz.saif.elyazal@gmail.com>
This patch removes a variable that was simply used to
store the return value of a function call before
returning it.
The issue was detected and resolved using the following
coccinelle script:
identifier len,f;
-int len;
 ... when != len
     when strict
-len =
+return
        f(...);
-return len;
Signed-off-by: Aya Mahfouz
 drivers/staging/iio/meter/ade7759.c | 5 +----
 1 file changed, 1 insertion(+), 4 deletions(-)
diff --git a/drivers/staging/iio/meter/ade7759.c b/drivers/staging/iio/meter/ade7759.c
index b0c7dbc..694e0ce 100644
--- a/drivers/staging/iio/meter/ade7759.c
+++ b/drivers/staging/iio/meter/ade7759.c
@@ -215,18 +215,15 @@ error_ret:
 static int ade7759_reset(struct device *dev)
-	int ret;
 	u16 val;
 	ade7759_spi_read_reg_16(dev,
 			ADE7759_MODE,
 			&val);
 	val |= 1 << 6; /* Software Chip Reset */
-	ret = ade7759_spi_write_reg_16(dev,
+	return ade7759_spi_write_reg_16(dev,
 			ADE7759_MODE,
 			val);
-	return ret;
 static IIO_DEV_ATTR_AENERGY(ade7759_read_40bit, ADE7759_AENERGY);
BtrLinux
Privacy Overview
