Staging: iio: meter: Prefer using the BIT macro
Author: Shraddha Barke <shraddha.6596@gmail.com>
This patch replaces bit shifting on 1 with the BIT(x) macro
This was done with coccinelle:
@@ int g; @@
-(1 << g)
+BIT(g)
Signed-off-by: Shraddha Barke
 drivers/staging/iio/meter/ade7753.c      | 8 ++++----
 drivers/staging/iio/meter/ade7754.c      | 6 +++---
 drivers/staging/iio/meter/ade7758_core.c | 6 +++---
 drivers/staging/iio/meter/ade7759.c      | 8 ++++----
 drivers/staging/iio/meter/ade7854.c      | 6 +++---
 5 files changed, 17 insertions(+), 17 deletions(-)
diff --git a/drivers/staging/iio/meter/ade7753.c b/drivers/staging/iio/meter/ade7753.c
index ffc7f0d..3d2e50c 100644
--- a/drivers/staging/iio/meter/ade7753.c
+++ b/drivers/staging/iio/meter/ade7753.c
@@ -219,7 +219,7 @@ static int ade7753_reset(struct device *dev)
 	u16 val;
 	ade7753_spi_read_reg_16(dev, ADE7753_MODE, &val);
-	val |= 1 << 6; /* Software Chip Reset */
+	val |= BIT(6); /* Software Chip Reset */
 	return ade7753_spi_write_reg_16(dev, ADE7753_MODE, val);
@@ -328,10 +328,10 @@ static int ade7753_set_irq(struct device *dev, bool enable)
 		goto error_ret;
 	if (enable)
-		irqen |= 1 << 3; /* Enables an interrupt when a data is
+		irqen |= BIT(3); /* Enables an interrupt when a data is
 				    present in the waveform register */
 	else
-		irqen &= ~(1 << 3);
+		irqen &= ~BIT(3);
 	ret = ade7753_spi_write_reg_8(dev, ADE7753_IRQEN, irqen);
@@ -345,7 +345,7 @@ static int ade7753_stop_device(struct device *dev)
 	u16 val;
-	val |= 1 << 4;  /* AD converters can be turned off */
+	val |= BIT(4);  /* AD converters can be turned off */
diff --git a/drivers/staging/iio/meter/ade7754.c b/drivers/staging/iio/meter/ade7754.c
index f12b2e5..8552c76 100644
--- a/drivers/staging/iio/meter/ade7754.c
+++ b/drivers/staging/iio/meter/ade7754.c
@@ -223,7 +223,7 @@ static int ade7754_reset(struct device *dev)
 	if (ret < 0)
 		return ret;
 	return ade7754_spi_write_reg_8(dev, ADE7754_OPMODE, val);
@@ -350,10 +350,10 @@ static int ade7754_set_irq(struct device *dev, bool enable)
 		goto error_ret;
 	if (enable)
-		irqen |= 1 << 14; /* Enables an interrupt when a data is
+		irqen |= BIT(14); /* Enables an interrupt when a data is
 	else
-		irqen &= ~(1 << 14);
+		irqen &= ~BIT(14);
 	ret = ade7754_spi_write_reg_16(dev, ADE7754_IRQEN, irqen);
 	if (ret)
diff --git a/drivers/staging/iio/meter/ade7758_core.c b/drivers/staging/iio/meter/ade7758_core.c
index 77141ae..3883808 100644
--- a/drivers/staging/iio/meter/ade7758_core.c
+++ b/drivers/staging/iio/meter/ade7758_core.c
@@ -308,7 +308,7 @@ static int ade7758_reset(struct device *dev)
 		dev_err(dev, "Failed to read opmode reg\n");
 		return ret;
 	ret = ade7758_spi_write_reg_8(dev, ADE7758_OPMODE, val);
 	if (ret < 0)
 		dev_err(dev, "Failed to write opmode reg\n");
@@ -426,10 +426,10 @@ int ade7758_set_irq(struct device *dev, bool enable)
 		goto error_ret;
 	if (enable)
-		irqen |= 1 << 16; /* Enables an interrupt when a data is
+		irqen |= BIT(16); /* Enables an interrupt when a data is
 	else
-		irqen &= ~(1 << 16);
+		irqen &= ~BIT(16);
 	ret = ade7758_spi_write_reg_24(dev, ADE7758_MASK, irqen);
 	if (ret)
diff --git a/drivers/staging/iio/meter/ade7759.c b/drivers/staging/iio/meter/ade7759.c
index dbceda1..23e7392 100644
--- a/drivers/staging/iio/meter/ade7759.c
+++ b/drivers/staging/iio/meter/ade7759.c
@@ -224,7 +224,7 @@ static int ade7759_reset(struct device *dev)
 	if (ret < 0)
 		return ret;
 	return ade7759_spi_write_reg_16(dev,
 			ADE7759_MODE,
 			val);
@@ -288,10 +288,10 @@ static int ade7759_set_irq(struct device *dev, bool enable)
 		goto error_ret;
 	if (enable)
 	else
+		irqen &= ~BIT(3);
 	ret = ade7759_spi_write_reg_8(dev, ADE7759_IRQEN, irqen);
@@ -314,7 +314,7 @@ static int ade7759_stop_device(struct device *dev)
 		return ret;
 	return ade7759_spi_write_reg_16(dev, ADE7759_MODE, val);
diff --git a/drivers/staging/iio/meter/ade7854.c b/drivers/staging/iio/meter/ade7854.c
index d620bbd..a838835 100644
--- a/drivers/staging/iio/meter/ade7854.c
+++ b/drivers/staging/iio/meter/ade7854.c
@@ -181,7 +181,7 @@ static int ade7854_reset(struct device *dev)
 	u16 val;
 	st->read_reg_16(dev, ADE7854_CONFIG, &val);
-	val |= 1 << 7; /* Software Chip Reset */
+	val |= BIT(7); /* Software Chip Reset */
 	return st->write_reg_16(dev, ADE7854_CONFIG, val);
@@ -420,10 +420,10 @@ static int ade7854_set_irq(struct device *dev, bool enable)
 		goto error_ret;
 	if (enable)
-		irqen |= 1 << 17; /* 1: interrupt enabled when all periodical
+		irqen |= BIT(17); /* 1: interrupt enabled when all periodical
 				     (at 8 kHz rate) DSP computations finish. */
 	else
-		irqen &= ~(1 << 17);
+		irqen &= ~BIT(17);
 	ret = st->write_reg_32(dev, ADE7854_MASK0, irqen);
 	if (ret)
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
