Staging: iio: meter: Prefer using the BIT macro
Author: Shraddha Barke <shraddha.6596@gmail.com>
This patch replaces bit shifting on 1 with the BIT(x) macro
This was done with coccinelle:
@@ int g; @@
-(1 << g)
+BIT(g)
Signed-off-by: Shraddha Barke
Signed-off-by: Jonathan Cameron
 drivers/staging/iio/meter/ade7753.c      | 8 ++++----
 drivers/staging/iio/meter/ade7754.c      | 6 +++---
 drivers/staging/iio/meter/ade7758_core.c | 6 +++---
 drivers/staging/iio/meter/ade7759.c      | 8 ++++----
 drivers/staging/iio/meter/ade7854.c      | 6 +++---
 5 files changed, 17 insertions(+), 17 deletions(-)
diff --git a/drivers/staging/iio/meter/ade7753.c b/drivers/staging/iio/meter/ade7753.c
index ffc7f0d..3d2e50c 100644
--- a/drivers/staging/iio/meter/ade7753.c
+++ b/drivers/staging/iio/meter/ade7753.c
@@ -219,7 +219,7 @@ static int ade7753_reset(struct device *dev)
 	u16 val;
 	ade7753_spi_read_reg_16(dev, ADE7753_MODE, &val);
-	val |= 1 << 6; /* Software Chip Reset */
+	val |= BIT(6); /* Software Chip Reset */
 	return ade7753_spi_write_reg_16(dev, ADE7753_MODE, val);
@@ -328,10 +328,10 @@ static int ade7753_set_irq(struct device *dev, bool enable)
 		goto error_ret;
 	if (enable)
-		irqen |= 1 << 3; /* Enables an interrupt when a data is
+		irqen |= BIT(3); /* Enables an interrupt when a data is
 				    present in the waveform register */
 	else
-		irqen &= ~(1 << 3);
+		irqen &= ~BIT(3);
 	ret = ade7753_spi_write_reg_8(dev, ADE7753_IRQEN, irqen);
@@ -345,7 +345,7 @@ static int ade7753_stop_device(struct device *dev)
 	u16 val;
-	val |= 1 << 4;  /* AD converters can be turned off */
+	val |= BIT(4);  /* AD converters can be turned off */
diff --git a/drivers/staging/iio/meter/ade7754.c b/drivers/staging/iio/meter/ade7754.c
index f12b2e5..8552c76 100644
--- a/drivers/staging/iio/meter/ade7754.c
+++ b/drivers/staging/iio/meter/ade7754.c
@@ -223,7 +223,7 @@ static int ade7754_reset(struct device *dev)
 	if (ret < 0)
 		return ret;
 	return ade7754_spi_write_reg_8(dev, ADE7754_OPMODE, val);
@@ -350,10 +350,10 @@ static int ade7754_set_irq(struct device *dev, bool enable)
 		goto error_ret;
 	if (enable)
-		irqen |= 1 << 14; /* Enables an interrupt when a data is
+		irqen |= BIT(14); /* Enables an interrupt when a data is
 	else
-		irqen &= ~(1 << 14);
+		irqen &= ~BIT(14);
 	ret = ade7754_spi_write_reg_16(dev, ADE7754_IRQEN, irqen);
 	if (ret)
diff --git a/drivers/staging/iio/meter/ade7758_core.c b/drivers/staging/iio/meter/ade7758_core.c
index 77141ae..3883808 100644
--- a/drivers/staging/iio/meter/ade7758_core.c
+++ b/drivers/staging/iio/meter/ade7758_core.c
@@ -308,7 +308,7 @@ static int ade7758_reset(struct device *dev)
 		dev_err(dev, "Failed to read opmode reg\n");
 		return ret;
 	ret = ade7758_spi_write_reg_8(dev, ADE7758_OPMODE, val);
 	if (ret < 0)
 		dev_err(dev, "Failed to write opmode reg\n");
@@ -426,10 +426,10 @@ int ade7758_set_irq(struct device *dev, bool enable)
 		goto error_ret;
 	if (enable)
-		irqen |= 1 << 16; /* Enables an interrupt when a data is
+		irqen |= BIT(16); /* Enables an interrupt when a data is
 	else
-		irqen &= ~(1 << 16);
+		irqen &= ~BIT(16);
 	ret = ade7758_spi_write_reg_24(dev, ADE7758_MASK, irqen);
 	if (ret)
diff --git a/drivers/staging/iio/meter/ade7759.c b/drivers/staging/iio/meter/ade7759.c
index dbceda1..23e7392 100644
--- a/drivers/staging/iio/meter/ade7759.c
+++ b/drivers/staging/iio/meter/ade7759.c
@@ -224,7 +224,7 @@ static int ade7759_reset(struct device *dev)
 	if (ret < 0)
 		return ret;
 	return ade7759_spi_write_reg_16(dev,
 			ADE7759_MODE,
 			val);
@@ -288,10 +288,10 @@ static int ade7759_set_irq(struct device *dev, bool enable)
 		goto error_ret;
 	if (enable)
 	else
+		irqen &= ~BIT(3);
 	ret = ade7759_spi_write_reg_8(dev, ADE7759_IRQEN, irqen);
@@ -314,7 +314,7 @@ static int ade7759_stop_device(struct device *dev)
 		return ret;
 	return ade7759_spi_write_reg_16(dev, ADE7759_MODE, val);
diff --git a/drivers/staging/iio/meter/ade7854.c b/drivers/staging/iio/meter/ade7854.c
index d620bbd..a838835 100644
--- a/drivers/staging/iio/meter/ade7854.c
+++ b/drivers/staging/iio/meter/ade7854.c
@@ -181,7 +181,7 @@ static int ade7854_reset(struct device *dev)
 	u16 val;
 	st->read_reg_16(dev, ADE7854_CONFIG, &val);
-	val |= 1 << 7; /* Software Chip Reset */
+	val |= BIT(7); /* Software Chip Reset */
 	return st->write_reg_16(dev, ADE7854_CONFIG, val);
@@ -420,10 +420,10 @@ static int ade7854_set_irq(struct device *dev, bool enable)
 		goto error_ret;
 	if (enable)
-		irqen |= 1 << 17; /* 1: interrupt enabled when all periodical
+		irqen |= BIT(17); /* 1: interrupt enabled when all periodical
 				     (at 8 kHz rate) DSP computations finish. */
 	else
-		irqen &= ~(1 << 17);
+		irqen &= ~BIT(17);
 	ret = st->write_reg_32(dev, ADE7854_MASK0, irqen);
 	if (ret)
BtrLinux
Privacy Overview
