staging: iio: light: remove unused variable
Author: Aya Mahfouz <mahfouz.saif.elyazal@gmail.com>
This patch removes a variable that was simply used to
store the return value of a function call before
returning it.
The issue was detected and resolved using the following
coccinelle script:
identifier len,f;
-int len;
 ... when != len
     when strict
-len =
+return
        f(...);
-return len;
Signed-off-by: Aya Mahfouz
 drivers/staging/iio/light/tsl2583.c | 4 +---
 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/drivers/staging/iio/light/tsl2583.c b/drivers/staging/iio/light/tsl2583.c
index 8afae8e..b5e1b8b 100644
--- a/drivers/staging/iio/light/tsl2583.c
+++ b/drivers/staging/iio/light/tsl2583.c
@@ -471,14 +471,12 @@ static int taos_chip_on(struct iio_dev *indio_dev)
 static int taos_chip_off(struct iio_dev *indio_dev)
 	struct tsl2583_chip *chip = iio_priv(indio_dev);
-	int ret;
 	/* turn device off */
 	chip->taos_chip_status = TSL258X_CHIP_SUSPENDED;
-	ret = i2c_smbus_write_byte_data(chip->client,
+	return i2c_smbus_write_byte_data(chip->client,
 					TSL258X_CMD_REG | TSL258X_CNTRL,
 					0x00);
-	return ret;
 /* Sysfs Interface Functions */
BtrLinux
Privacy Overview
