Staging: iio: introduce missing kfree
Error handling code following a kmalloc or kzalloc should free the
allocated data.
The semantic match that finds the problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@r exists@
local idexpression x;
statement S;
expression E;
identifier f,f1,l;
position p1,p2;
expression *ptr != NULL;
x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...);
if (x == NULL) S
<... when != x
     when != if (...) { <+...x...+> }
x->f1 = E
 (x->f1 == NULL || ...)
 f(...,x->f1,...)
 return \(0\|<+...x...+>\|ptr\);
 return@p2 ...;
@script:python@
p1 << r.p1;
p2 << r.p2;
print "* file: %s kmalloc %s return %s" % (p1[0].file,p1[0].line,p2[0].line)
Signed-off-by: Julia Lawall
 drivers/staging/iio/accel/lis3l02dq_ring.c | 1 +
 1 file changed, 1 insertion(+)
diff --git a/drivers/staging/iio/accel/lis3l02dq_ring.c b/drivers/staging/iio/accel/lis3l02dq_ring.c
index c21198d..a6b7c72 100644
--- a/drivers/staging/iio/accel/lis3l02dq_ring.c
+++ b/drivers/staging/iio/accel/lis3l02dq_ring.c
@@ -286,6 +286,7 @@ static void lis3l02dq_trigger_bh_to_ring(struct work_struct *work_s)
 	rx_array = kmalloc(4 * (st->indio_dev->scan_count), GFP_KERNEL);
 	if (rx_array == NULL) {
 		dev_err(&st->us->dev, "memory alloc failed in ring bh");
+		kfree(data);
 		return;
BtrLinux
Privacy Overview
