Staging: iio: iio_simple_dummy: Remove explicit NULL comparison
Author: Cristina Opriceana <cristina.opriceana@gmail.com>
This patch removes explicit NULL comparison and writes it in its
simpler form. Done with coccinelle:
@replace_rule@
expression e;
-e == NULL
+ !e
Signed-off-by: Cristina Opriceana
 drivers/staging/iio/iio_simple_dummy.c        | 2 +-
 drivers/staging/iio/iio_simple_dummy_buffer.c | 6 +++---
 2 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/staging/iio/iio_simple_dummy.c b/drivers/staging/iio/iio_simple_dummy.c
index 8341dce..b47bf9f 100644
--- a/drivers/staging/iio/iio_simple_dummy.c
+++ b/drivers/staging/iio/iio_simple_dummy.c
@@ -588,7 +588,7 @@ static int iio_dummy_probe(int index)
 	 * for chip specific state information.
 	indio_dev = iio_device_alloc(sizeof(*st));
-	if (indio_dev == NULL) {
+	if (!indio_dev) {
 		ret = -ENOMEM;
 		goto error_ret;
diff --git a/drivers/staging/iio/iio_simple_dummy_buffer.c b/drivers/staging/iio/iio_simple_dummy_buffer.c
index 360a4c9..a651b89 100644
--- a/drivers/staging/iio/iio_simple_dummy_buffer.c
+++ b/drivers/staging/iio/iio_simple_dummy_buffer.c
@@ -50,7 +50,7 @@ static irqreturn_t iio_simple_dummy_trigger_h(int irq, void *p)
 	u16 *data;
 	data = kmalloc(indio_dev->scan_bytes, GFP_KERNEL);
-	if (data == NULL)
+	if (!data)
 		goto done;
 	if (!bitmap_empty(indio_dev->active_scan_mask, indio_dev->masklength)) {
@@ -122,7 +122,7 @@ int iio_simple_dummy_configure_buffer(struct iio_dev *indio_dev)
 	/* Allocate a buffer to use - here a kfifo */
 	buffer = iio_kfifo_allocate();
-	if (buffer == NULL) {
+	if (!buffer) {
 		ret = -ENOMEM;
 		goto error_ret;
@@ -161,7 +161,7 @@ int iio_simple_dummy_configure_buffer(struct iio_dev *indio_dev)
 						 "iio_simple_dummy_consumer%d",
 						 indio_dev->id);
-	if (indio_dev->pollfunc == NULL) {
+	if (!indio_dev->pollfunc) {
 		ret = -ENOMEM;
 		goto error_free_buffer;
BtrLinux
Privacy Overview
