staging: iio: Documentation: rewrite the right hand side of an assignment
Author: Aya Mahfouz <mahfouz.saif.elyazal@gmail.com>
This patch rewrites the right hand side of an assignment for
expressions of the form:
a = (a  b);
to be:
a = b;
where  = << | >>.
This issue was detected and resolved using the following
coccinelle script:
identifier i;
expression e;
-i = (i >> e);
+i >>= e;
identifier i;
expression e;
-i = (i << e);
+i <<= e;
Signed-off-by: Aya Mahfouz
 drivers/staging/iio/Documentation/generic_buffer.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/staging/iio/Documentation/generic_buffer.c b/drivers/staging/iio/Documentation/generic_buffer.c
index de4647e..59b2505 100644
--- a/drivers/staging/iio/Documentation/generic_buffer.c
+++ b/drivers/staging/iio/Documentation/generic_buffer.c
@@ -72,7 +72,7 @@ void print2byte(int input, struct iio_channel_info *info)
 	 * Shift before conversion to avoid sign extension
 	 * of left aligned data
-	input = input >> info->shift;
+	input >>= info->shift;
 	if (info->is_signed) {
 		int16_t val = input;
BtrLinux
Privacy Overview
