Staging: i2o: Move assignment out of if statement
Author: Somya Anand <somyaanand214@gmail.com>
Checkpatch.pl suggest to avoid assignment in if statement.
This patch moves assignments out of the if statement and place
it before the if statement. This is done using following coccinelle
script.
expression E1;
identifier p;
statement S;
- if ((p = E1))
+ p = E1;
+ if (p)
	S
Signed-off-by: Somya Anand
 drivers/staging/i2o/bus-osm.c |  3 ++-
 drivers/staging/i2o/iop.c     | 24 ++++++++++++++++--------
 drivers/staging/i2o/pci.c     |  9 ++++++---
 3 files changed, 24 insertions(+), 12 deletions(-)
diff --git a/drivers/staging/i2o/bus-osm.c b/drivers/staging/i2o/bus-osm.c
index 7aa0339..43e357e 100644
--- a/drivers/staging/i2o/bus-osm.c
+++ b/drivers/staging/i2o/bus-osm.c
@@ -69,7 +69,8 @@ static ssize_t i2o_bus_store_scan(struct device *d,
 	struct i2o_device *i2o_dev = to_i2o_device(d);
 	int rc;
-	if ((rc = i2o_bus_scan(i2o_dev)))
+	rc = i2o_bus_scan(i2o_dev);
+	if (rc)
 		osm_warn("bus scan failed %d\n", rc);
 	return count;
diff --git a/drivers/staging/i2o/iop.c b/drivers/staging/i2o/iop.c
index 6cae63c..23bdbe4 100644
--- a/drivers/staging/i2o/iop.c
+++ b/drivers/staging/i2o/iop.c
@@ -1096,7 +1096,8 @@ int i2o_iop_add(struct i2o_controller *c)
 	int rc;
-	if ((rc = device_add(&c->device))) {
+	rc = device_add(&c->device);
+	if (rc) {
 		osm_err("%s: could not add controller\n", c->name);
 		goto iop_reset;
@@ -1105,24 +1106,28 @@ int i2o_iop_add(struct i2o_controller *c)
 	osm_info("%s: This may take a few minutes if there are many devices\n",
 		 c->name);
-	if ((rc = i2o_iop_activate(c))) {
+	rc = i2o_iop_activate(c);
+	if (rc) {
 		osm_err("%s: could not activate controller\n", c->name);
 		goto device_del;
 	osm_debug("%s: building sys table...\n", c->name);
-	if ((rc = i2o_systab_build()))
+	rc = i2o_systab_build();
+	if (rc)
 		goto device_del;
 	osm_debug("%s: online controller...\n", c->name);
-	if ((rc = i2o_iop_online(c)))
+	rc = i2o_iop_online(c);
+	if (rc)
 		goto device_del;
 	osm_debug("%s: getting LCT...\n", c->name);
-	if ((rc = i2o_exec_lct_get(c)))
+	rc = i2o_exec_lct_get(c);
+	if (rc)
 		goto device_del;
 	list_add(&c->list, &i2o_controllers);
@@ -1192,13 +1197,16 @@ static int __init i2o_iop_init(void)
 	printk(KERN_INFO OSM_DESCRIPTION " v" OSM_VERSION "\n");
-	if ((rc = i2o_driver_init()))
+	rc = i2o_driver_init();
+	if (rc)
 		goto exit;
-	if ((rc = i2o_exec_init()))
+	rc = i2o_exec_init();
+	if (rc)
 		goto driver_exit;
-	if ((rc = i2o_pci_init()))
+	rc = i2o_pci_init();
+	if (rc)
 		goto exec_exit;
 	return 0;
diff --git a/drivers/staging/i2o/pci.c b/drivers/staging/i2o/pci.c
index b3b8a61..49804c9 100644
--- a/drivers/staging/i2o/pci.c
+++ b/drivers/staging/i2o/pci.c
@@ -329,7 +329,8 @@ static int i2o_pci_probe(struct pci_dev *pdev, const struct pci_device_id *id)
 		return -ENODEV;
-	if ((rc = pci_enable_device(pdev))) {
+	rc = pci_enable_device(pdev);
+	if (rc) {
 		printk(KERN_WARNING "i2o: couldn't enable device %s\n",
 		       pci_name(pdev));
 		return rc;
@@ -410,7 +411,8 @@ static int i2o_pci_probe(struct pci_dev *pdev, const struct pci_device_id *id)
 #endif
-	if ((rc = i2o_pci_alloc(c))) {
+	rc = i2o_pci_alloc(c);
+	if (rc) {
 		printk(KERN_ERR "%s: DMA / IO allocation for I2O controller "
 		       "failed\n", c->name);
 		goto free_controller;
@@ -422,7 +424,8 @@ static int i2o_pci_probe(struct pci_dev *pdev, const struct pci_device_id *id)
 		goto free_pci;
-	if ((rc = i2o_iop_add(c)))
+	rc = i2o_iop_add(c);
+	if (rc)
 		goto uninstall;
 	if (i960)
BtrLinux
Privacy Overview
