drivers/staging/hv/NetVsc.c | 32 ++++++++++++++++----------------
drivers/staging/hv/NetVsc.h | 2 +-
drivers/staging/hv/RndisFilter.c | 16 ++++++++--------
drivers/staging/hv/include/NetVscApi.h | 10 +++++-----
drivers/staging/hv/netvsc_drv.c | 16 ++++++++--------
5 files changed, 38 insertions(+), 38 deletions(-)
diff --git a/drivers/staging/hv/NetVsc.c b/drivers/staging/hv/NetVsc.c
index d653f95..b24a870 100644
--- a/drivers/staging/hv/NetVsc.c
+++ b/drivers/staging/hv/NetVsc.c
@@ -93,7 +93,7 @@ NetVscOnSendCompletion(
static int
NetVscOnSend(
struct hv_device *Device,
- NETVSC_PACKET *Packet
+ struct hv_netvsc_packet *Packet
static void
@@ -239,8 +239,8 @@ NetVscInitialize(
DPRINT_ENTER(NETVSC);
- DPRINT_DBG(NETVSC, "sizeof(NETVSC_PACKET)=%zd, sizeof(NVSP_MESSAGE)=%zd, sizeof(VMTRANSFER_PAGE_PACKET_HEADER)=%zd",
- sizeof(NETVSC_PACKET), sizeof(NVSP_MESSAGE), sizeof(VMTRANSFER_PAGE_PACKET_HEADER));
+ DPRINT_DBG(NETVSC, "sizeof(struct hv_netvsc_packet)=%zd, sizeof(NVSP_MESSAGE)=%zd, sizeof(VMTRANSFER_PAGE_PACKET_HEADER)=%zd",
+ sizeof(struct hv_netvsc_packet), sizeof(NVSP_MESSAGE), sizeof(VMTRANSFER_PAGE_PACKET_HEADER));
/* Make sure we are at least 2 pages since 1 page is used for control */
ASSERT(driver->RingBufferSize >= (PAGE_SIZE << 1));
@@ -802,7 +802,7 @@ NetVscOnDeviceAdd(
int i;
struct NETVSC_DEVICE *netDevice;
- NETVSC_PACKET* packet;
+ struct hv_netvsc_packet *packet;
LIST_ENTRY *entry;
NETVSC_DRIVER_OBJECT *netDriver = (NETVSC_DRIVER_OBJECT*) Device->Driver;;
@@ -828,7 +828,7 @@ NetVscOnDeviceAdd(
for (i=0; i < NETVSC_RECEIVE_PACKETLIST_COUNT; i++)
- packet = kzalloc(sizeof(NETVSC_PACKET) + (NETVSC_RECEIVE_SG_COUNT* sizeof(PAGE_BUFFER)), GFP_KERNEL);
+ packet = kzalloc(sizeof(struct hv_netvsc_packet) + (NETVSC_RECEIVE_SG_COUNT* sizeof(PAGE_BUFFER)), GFP_KERNEL);
if (!packet)
DPRINT_DBG(NETVSC, "unable to allocate netvsc pkts for receive pool (wanted %d got %d)", NETVSC_RECEIVE_PACKETLIST_COUNT, i);
@@ -885,7 +885,7 @@ Cleanup:
while (!IsListEmpty(&netDevice->ReceivePacketList))
entry = REMOVE_HEAD_LIST(&netDevice->ReceivePacketList);
- packet = CONTAINING_RECORD(entry, NETVSC_PACKET, ListEntry);
+ packet = CONTAINING_RECORD(entry, struct hv_netvsc_packet, ListEntry);
kfree(packet);
@@ -915,7 +915,7 @@ NetVscOnDeviceRemove(
- NETVSC_PACKET *netvscPacket;
+ struct hv_netvsc_packet *netvscPacket;
int ret=0;
LIST_ENTRY *entry;
@@ -958,7 +958,7 @@ NetVscOnDeviceRemove(
- netvscPacket = CONTAINING_RECORD(entry, NETVSC_PACKET, ListEntry);
+ netvscPacket = CONTAINING_RECORD(entry, struct hv_netvsc_packet, ListEntry);
kfree(netvscPacket);
@@ -999,7 +999,7 @@ NetVscOnSendCompletion(
NVSP_MESSAGE *nvspPacket;
- NETVSC_PACKET *nvscPacket;
+ struct hv_netvsc_packet *nvscPacket;
@@ -1026,7 +1026,7 @@ NetVscOnSendCompletion(
else if (nvspPacket->Header.MessageType == NvspMessage1TypeSendRNDISPacketComplete)
/* Get the send context */
- nvscPacket = (NETVSC_PACKET *)(unsigned long)Packet->TransactionId;
+ nvscPacket = (struct hv_netvsc_packet *)(unsigned long)Packet->TransactionId;
ASSERT(nvscPacket);
/* Notify the layer above us */
@@ -1048,7 +1048,7 @@ NetVscOnSendCompletion(
static int
NetVscOnSend(
@@ -1118,7 +1118,7 @@ NetVscOnReceive(
VMTRANSFER_PAGE_PACKET_HEADER *vmxferpagePacket;
- NETVSC_PACKET *netvscPacket=NULL;
+ struct hv_netvsc_packet *netvscPacket=NULL;
LIST_ENTRY* entry;
unsigned long start;
unsigned long end, endVirtual;
@@ -1183,7 +1183,7 @@ NetVscOnReceive(
INSERT_TAIL_LIST(&listHead, &netvscPacket->ListEntry);
@@ -1206,7 +1206,7 @@ NetVscOnReceive(
for (i=count; i != 0; i--)
entry = REMOVE_HEAD_LIST(&listHead);
INSERT_TAIL_LIST(&netDevice->ReceivePacketList, &netvscPacket->ListEntry);
@@ -1233,7 +1233,7 @@ NetVscOnReceive(
for (i=0; i < (count - 1); i++)
/* Initialize the netvsc packet */
netvscPacket->XferPagePacket = xferpagePacket;
@@ -1357,7 +1357,7 @@ static void
NetVscOnReceiveCompletion(
void * Context)
- NETVSC_PACKET *packet = (NETVSC_PACKET*)Context;
+ struct hv_netvsc_packet *packet = (struct hv_netvsc_packet*)Context;
struct hv_device *device = (struct hv_device*)packet->Device;
u64 transactionId=0;
diff --git a/drivers/staging/hv/NetVsc.h b/drivers/staging/hv/NetVsc.h
index 7636654..0389318 100644
--- a/drivers/staging/hv/NetVsc.h
+++ b/drivers/staging/hv/NetVsc.h
@@ -60,7 +60,7 @@ struct NETVSC_DEVICE {
int RefCount;
int NumOutstandingSends;
- /* List of free preallocated NETVSC_PACKET to represent receive packet */
+ /* List of free preallocated hv_netvsc_packet to represent receive packet */
LIST_ENTRY ReceivePacketList;
spinlock_t receive_packet_list_lock;
diff --git a/drivers/staging/hv/RndisFilter.c b/drivers/staging/hv/RndisFilter.c
index 96133a4..a6bbb1c 100644
--- a/drivers/staging/hv/RndisFilter.c
+++ b/drivers/staging/hv/RndisFilter.c
@@ -68,7 +68,7 @@ typedef struct _RNDIS_REQUEST {
RNDIS_MESSAGE ResponseMessage;
/* Simplify allocation by having a netvsc packet inline */
- NETVSC_PACKET Packet;
+ struct hv_netvsc_packet Packet;
PAGE_BUFFER Buffer;
/* FIXME: We assumed a fixed size request here. */
RNDIS_MESSAGE RequestMessage;
@@ -107,13 +107,13 @@ static void
RndisFilterReceiveData(
RNDIS_DEVICE *Device,
RNDIS_MESSAGE *Message,
static int
RndisFilterOnReceive(
static int
@@ -184,7 +184,7 @@ RndisFilterOnClose(
static int
RndisFilterOnSend(
static void
@@ -345,7 +345,7 @@ RndisFilterSendRequest(
int ret=0;
- NETVSC_PACKET *packet;
@@ -458,7 +458,7 @@ static void
RNDIS_PACKET *rndisPacket;
@@ -491,7 +491,7 @@ RndisFilterReceiveData(
static int
struct NETVSC_DEVICE *netDevice = (struct NETVSC_DEVICE*)Device->Extension;
@@ -1080,7 +1080,7 @@ RndisFilterOnClose(
static int
RndisFilterOnSend(
int ret=0;
diff --git a/drivers/staging/hv/include/NetVscApi.h b/drivers/staging/hv/include/NetVscApi.h
index 83e746d..79b9e4b 100644
--- a/drivers/staging/hv/include/NetVscApi.h
+++ b/drivers/staging/hv/include/NetVscApi.h
@@ -37,7 +37,7 @@
/* Fwd declaration */
-typedef struct _NETVSC_PACKET *PNETVSC_PACKET;
+struct hv_netvsc_packet;
@@ -48,10 +48,10 @@ typedef int (*PFN_ON_OPEN)(struct hv_device *Device);
typedef int (*PFN_ON_CLOSE)(struct hv_device *Device);
typedef void (*PFN_QUERY_LINKSTATUS)(struct hv_device *Device);
-typedef int (*PFN_ON_SEND)(struct hv_device *dev, PNETVSC_PACKET packet);
+typedef int (*PFN_ON_SEND)(struct hv_device *dev, struct hv_netvsc_packet *packet);
typedef void (*PFN_ON_SENDRECVCOMPLETION)(void * Context);
-typedef int (*PFN_ON_RECVCALLBACK)(struct hv_device *dev, PNETVSC_PACKET packet);
+typedef int (*PFN_ON_RECVCALLBACK)(struct hv_device *dev, struct hv_netvsc_packet *packet);
typedef void (*PFN_ON_LINKSTATUS_CHANGED)(struct hv_device *dev, u32 Status);
/* Represent the xfer page packet which contains 1 or more netvsc packet */
@@ -70,7 +70,7 @@ typedef struct _XFERPAGE_PACKET {
* Represent netvsc packet which contains 1 RNDIS and 1 ethernet frame
* within the RNDIS
-typedef struct _NETVSC_PACKET {
+struct hv_netvsc_packet {
/* Bookkeeping stuff */
DLIST_ENTRY ListEntry;
@@ -104,7 +104,7 @@ typedef struct _NETVSC_PACKET {
u32 PageBufferCount;
PAGE_BUFFER PageBuffers[NETVSC_PACKET_MAXPAGE];
-} NETVSC_PACKET;
/* Represents the net vsc driver */
diff --git a/drivers/staging/hv/netvsc_drv.c b/drivers/staging/hv/netvsc_drv.c
index 9010f0e..02b200b 100644
--- a/drivers/staging/hv/netvsc_drv.c
+++ b/drivers/staging/hv/netvsc_drv.c
@@ -51,7 +51,7 @@ static int netvsc_remove(struct device *device);
static int netvsc_open(struct net_device *net);
static void netvsc_xmit_completion(void *context);
static int netvsc_start_xmit (struct sk_buff *skb, struct net_device *net);
-static int netvsc_recv_callback(struct hv_device *device_obj, NETVSC_PACKET* Packet);
+static int netvsc_recv_callback(struct hv_device *device_obj, struct hv_netvsc_packet *Packet);
static int netvsc_close(struct net_device *net);
static struct net_device_stats *netvsc_get_stats(struct net_device *net);
static void netvsc_linkstatus_callback(struct hv_device *device_obj, unsigned int status);
@@ -371,7 +371,7 @@ Desc: Send completion processing
- NETVSC_PACKET *packet = (NETVSC_PACKET *)context;
+ struct hv_netvsc_packet *packet = (struct hv_netvsc_packet *)context;
struct sk_buff *skb = (struct sk_buff *)(unsigned long)packet->Completion.Send.SendCompletionTid;
struct net_device* net;
@@ -412,7 +412,7 @@ static int netvsc_start_xmit (struct sk_buff *skb, struct net_device *net)
NETVSC_DRIVER_OBJECT *net_drv_obj = &net_drv_ctx->drv_obj;
int i=0;
int num_frags;
int retries=0;
@@ -428,14 +428,14 @@ static int netvsc_start_xmit (struct sk_buff *skb, struct net_device *net)
num_frags = skb_shinfo(skb)->nr_frags + 1 + net_drv_obj->AdditionalRequestPageBufferCount;
/* Allocate a netvsc packet based on # of frags. */
- packet = kzalloc(sizeof(NETVSC_PACKET) + (num_frags * sizeof(PAGE_BUFFER)) + net_drv_obj->RequestExtSize, GFP_ATOMIC);
+ packet = kzalloc(sizeof(struct hv_netvsc_packet) + (num_frags * sizeof(PAGE_BUFFER)) + net_drv_obj->RequestExtSize, GFP_ATOMIC);
if (!packet)
- DPRINT_ERR(NETVSC_DRV, "unable to allocate NETVSC_PACKET");
+ DPRINT_ERR(NETVSC_DRV, "unable to allocate hv_netvsc_packet");
return -1;
- packet->Extension = (void*)(unsigned long)packet + sizeof(NETVSC_PACKET) + (num_frags * sizeof(PAGE_BUFFER)) ;
+ packet->Extension = (void*)(unsigned long)packet + sizeof(struct hv_netvsc_packet) + (num_frags * sizeof(PAGE_BUFFER)) ;
/* Setup the rndis header */
packet->PageBufferCount = num_frags;
@@ -549,7 +549,7 @@ Name: netvsc_recv_callback()
Desc: Callback when we receive a packet from the "wire" on the specify device
-static int netvsc_recv_callback(struct hv_device *device_obj, NETVSC_PACKET* packet)
+static int netvsc_recv_callback(struct hv_device *device_obj, struct hv_netvsc_packet *packet)
int ret=0;
struct device_context *device_ctx = to_device_context(device_obj);
@@ -581,7 +581,7 @@ static int netvsc_recv_callback(struct hv_device *device_obj, NETVSC_PACKET* pac
/* for kmap_atomic */
local_irq_save(flags);
- /* Copy to skb. This copy is needed here since the memory pointed by NETVSC_PACKET */
+ /* Copy to skb. This copy is needed here since the memory pointed by hv_netvsc_packet */
/* cannot be deallocated */
for (i=0; i<packet->PageBufferCount; i++)
