drivers/staging/hv/BlkVsc.c | 2 +-
drivers/staging/hv/NetVsc.c | 6 +++---
drivers/staging/hv/RndisFilter.c | 4 ++--
drivers/staging/hv/StorVsc.c | 6 +++---
drivers/staging/hv/Vmbus.c | 20 ++++++++++----------
drivers/staging/hv/include/NetVscApi.h | 4 ++--
drivers/staging/hv/include/StorVscApi.h | 6 +++---
drivers/staging/hv/include/VmbusApi.h | 26 ++++++++++----------------
drivers/staging/hv/include/vmbus.h | 4 ++--
drivers/staging/hv/vmbus_drv.c | 2 +-
10 files changed, 37 insertions(+), 43 deletions(-)
diff --git a/drivers/staging/hv/BlkVsc.c b/drivers/staging/hv/BlkVsc.c
index 059b134..d2bde5d 100644
--- a/drivers/staging/hv/BlkVsc.c
+++ b/drivers/staging/hv/BlkVsc.c
@@ -41,7 +41,7 @@ BlkVscOnDeviceAdd(
int
BlkVscInitialize(
- DRIVER_OBJECT *Driver
+ struct hv_driver *Driver
STORVSC_DRIVER_OBJECT* storDriver = (STORVSC_DRIVER_OBJECT*)Driver;
diff --git a/drivers/staging/hv/NetVsc.c b/drivers/staging/hv/NetVsc.c
index e2a75ce..d653f95 100644
--- a/drivers/staging/hv/NetVsc.c
+++ b/drivers/staging/hv/NetVsc.c
@@ -51,7 +51,7 @@ NetVscOnDeviceRemove(
static void
NetVscOnCleanup(
static void
@@ -231,7 +231,7 @@ Description:
int
NetVscInitialize(
- DRIVER_OBJECT *drv
+ struct hv_driver *drv
NETVSC_DRIVER_OBJECT* driver = (NETVSC_DRIVER_OBJECT*)drv;
@@ -983,7 +983,7 @@ Description:
void
NetVscOnCleanup(
DPRINT_ENTER(NETVSC);
diff --git a/drivers/staging/hv/RndisFilter.c b/drivers/staging/hv/RndisFilter.c
index ddeede1..96133a4 100644
--- a/drivers/staging/hv/RndisFilter.c
+++ b/drivers/staging/hv/RndisFilter.c
@@ -168,7 +168,7 @@ RndisFilterOnDeviceRemove(
static void
RndisFilterOnCleanup(
static int
@@ -1032,7 +1032,7 @@ RndisFilterOnDeviceRemove(
static void
diff --git a/drivers/staging/hv/StorVsc.c b/drivers/staging/hv/StorVsc.c
index 4a406f0..bc313a6 100644
--- a/drivers/staging/hv/StorVsc.c
+++ b/drivers/staging/hv/StorVsc.c
@@ -118,7 +118,7 @@ StorVscOnHostReset(
static void
StorVscOnCleanup(
- DRIVER_OBJECT *Device
+ struct hv_driver *Device
static void
@@ -263,7 +263,7 @@ Description:
int
StorVscInitialize(
@@ -807,7 +807,7 @@ Description:
void
StorVscOnCleanup(
DPRINT_ENTER(STORVSC);
diff --git a/drivers/staging/hv/Vmbus.c b/drivers/staging/hv/Vmbus.c
index f6be5b5..60f9afc 100644
--- a/drivers/staging/hv/Vmbus.c
+++ b/drivers/staging/hv/Vmbus.c
@@ -45,7 +45,7 @@ static const GUID gVmbusDeviceId={
.Data = {0xfc, 0x60, 0x37, 0xac, 0xdf, 0x9a, 0xaa, 0x40, 0x94, 0x27, 0xa7, 0x0e, 0xd6, 0xde, 0x95, 0xc5}
-static DRIVER_OBJECT* gDriver; /* vmbus driver object */
+static struct hv_driver *gDriver; /* vmbus driver object */
static struct hv_device* gDevice; /* vmbus root device */
@@ -82,22 +82,22 @@ VmbusOnDeviceRemove(
static void
VmbusOnCleanup(
- DRIVER_OBJECT* drv
static int
VmbusOnISR(
static void
VmbusOnMsgDPC(
static void
VmbusOnEventDPC(
@@ -111,7 +111,7 @@ Description:
int
VmbusInitialize(
VMBUS_DRIVER_OBJECT* driver = (VMBUS_DRIVER_OBJECT*)drv;
@@ -377,7 +377,7 @@ Description:
void
VmbusOnCleanup(
/* VMBUS_DRIVER_OBJECT* driver = (VMBUS_DRIVER_OBJECT*)drv; */
@@ -401,7 +401,7 @@ Description:
void
VmbusOnMsgDPC(
void *page_addr = gHvContext.synICMessagePage[0];
@@ -460,7 +460,7 @@ Description:
void
VmbusOnEventDPC(
+ struct hv_driver* drv
/* TODO: Process any events */
@@ -479,7 +479,7 @@ Description:
int
VmbusOnISR(
diff --git a/drivers/staging/hv/include/NetVscApi.h b/drivers/staging/hv/include/NetVscApi.h
index 56ae23a..83e746d 100644
--- a/drivers/staging/hv/include/NetVscApi.h
+++ b/drivers/staging/hv/include/NetVscApi.h
@@ -109,7 +109,7 @@ typedef struct _NETVSC_PACKET {
/* Represents the net vsc driver */
typedef struct _NETVSC_DRIVER_OBJECT {
- DRIVER_OBJECT Base; /* Must be the first field */
+ struct hv_driver Base; /* Must be the first field */
u32 RingBufferSize;
u32 RequestExtSize;
@@ -147,7 +147,7 @@ typedef struct _NETVSC_DEVICE_INFO {
int
NetVscInitialize(
#endif /* _NETVSC_API_H_ */
diff --git a/drivers/staging/hv/include/StorVscApi.h b/drivers/staging/hv/include/StorVscApi.h
index bd09409..f6c9742 100644
--- a/drivers/staging/hv/include/StorVscApi.h
+++ b/drivers/staging/hv/include/StorVscApi.h
@@ -98,7 +98,7 @@ typedef struct _STORVSC_REQUEST {
/* Represents the block vsc driver */
typedef struct _STORVSC_DRIVER_OBJECT {
/* Set by caller (in bytes) */
u32 RingBufferSize;
@@ -129,11 +129,11 @@ typedef struct _STORVSC_DEVICE_INFO {
int
StorVscInitialize(
int
BlkVscInitialize(
#endif /* _STORVSC_API_H_ */
diff --git a/drivers/staging/hv/include/VmbusApi.h b/drivers/staging/hv/include/VmbusApi.h
index c09f589..0a87085 100644
--- a/drivers/staging/hv/include/VmbusApi.h
+++ b/drivers/staging/hv/include/VmbusApi.h
@@ -34,13 +34,6 @@
#define MAX_PAGE_BUFFER_COUNT 16
#define MAX_MULTIPAGE_BUFFER_COUNT 32 /* 128K */
-/* Fwd declarations */
-typedef struct _DRIVER_OBJECT *PDRIVER_OBJECT;
/* Data types */
@@ -68,19 +61,20 @@ typedef struct _MULTIPAGE_BUFFER {
#pragma pack(pop)
+struct hv_driver;
struct hv_device;
/* All drivers */
typedef int (*PFN_ON_DEVICEADD)(struct hv_device *Device, void* AdditionalInfo);
typedef int (*PFN_ON_DEVICEREMOVE)(struct hv_device *Device);
typedef char** (*PFN_ON_GETDEVICEIDS)(void);
-typedef void (*PFN_ON_CLEANUP)(PDRIVER_OBJECT Driver);
+typedef void (*PFN_ON_CLEANUP)(struct hv_driver *Driver);
/* Vmbus extensions */
-/* typedef int (*PFN_ON_MATCH)(struct hv_device *dev, PDRIVER_OBJECT drv); */
+/* typedef int (*PFN_ON_MATCH)(struct hv_device *dev, struct hv_driver *drv); */
/* typedef int (*PFN_ON_PROBE)(struct hv_device *dev); */
-typedef int (*PFN_ON_ISR)(PDRIVER_OBJECT drv);
-typedef void (*PFN_ON_DPC)(PDRIVER_OBJECT drv);
+typedef int (*PFN_ON_ISR)(struct hv_driver *drv);
+typedef void (*PFN_ON_DPC)(struct hv_driver *drv);
typedef void (*PFN_GET_CHANNEL_OFFERS)(void);
typedef struct hv_device *(*PFN_ON_CHILDDEVICE_CREATE)(GUID DeviceType, GUID DeviceInstance, void *Context);
@@ -205,7 +199,7 @@ typedef struct _VMBUS_CHANNEL_INTERFACE {
typedef void (*VMBUS_GET_CHANNEL_INTERFACE)(VMBUS_CHANNEL_INTERFACE *Interface);
/* Base driver object */
-typedef struct _DRIVER_OBJECT {
+struct hv_driver {
const char* name;
GUID deviceType; /* the device type supported by this driver */
@@ -215,12 +209,12 @@ typedef struct _DRIVER_OBJECT {
PFN_ON_CLEANUP OnCleanup;
VMBUS_CHANNEL_INTERFACE VmbusChannelInterface;
-} DRIVER_OBJECT;
/* Base device object */
struct hv_device {
- DRIVER_OBJECT* Driver; /* the driver for this device */
+ struct hv_driver *Driver; /* the driver for this device */
char name[64];
GUID deviceType; /* the device type id of this device */
GUID deviceInstance; /* the device instance id of this device */
@@ -231,7 +225,7 @@ struct hv_device {
/* Vmbus driver object */
typedef struct _VMBUS_DRIVER_OBJECT {
- DRIVER_OBJECT Base; /* !! Must be the 1st field !! */
+ struct hv_driver Base; /* !! Must be the 1st field !! */
/* Set by the caller */
PFN_ON_CHILDDEVICE_CREATE OnChildDeviceCreate;
@@ -257,7 +251,7 @@ typedef struct _VMBUS_DRIVER_OBJECT {
int
VmbusInitialize(
#endif /* _VMBUS_API_H_ */
diff --git a/drivers/staging/hv/include/vmbus.h b/drivers/staging/hv/include/vmbus.h
index b99c4b5..6f7eecb 100644
--- a/drivers/staging/hv/include/vmbus.h
+++ b/drivers/staging/hv/include/vmbus.h
@@ -33,8 +33,8 @@
/* Data types */
-typedef int (*PFN_DRIVERINITIALIZE)(DRIVER_OBJECT *drv);
-typedef int (*PFN_DRIVEREXIT)(DRIVER_OBJECT *drv);
+typedef int (*PFN_DRIVERINITIALIZE)(struct hv_driver *drv);
+typedef int (*PFN_DRIVEREXIT)(struct hv_driver *drv);
struct driver_context {
GUID class_id;
diff --git a/drivers/staging/hv/vmbus_drv.c b/drivers/staging/hv/vmbus_drv.c
index 32ae68c..699baf5 100644
--- a/drivers/staging/hv/vmbus_drv.c
+++ b/drivers/staging/hv/vmbus_drv.c
@@ -765,7 +765,7 @@ static int vmbus_match(struct device *device, struct device_driver *driver)
if (memcmp(&device_ctx->class_id, &driver_ctx->class_id, sizeof(GUID)) == 0)
/* !! NOTE: The driver_ctx is not a vmbus_drv_ctx. We typecast it here to access the */
- /* DRIVER_OBJECT field */
+ /* struct hv_driver field */
struct vmbus_driver_context *vmbus_drv_ctx = (struct vmbus_driver_context*)driver_ctx;
device_ctx->device_obj.Driver = &vmbus_drv_ctx->drv_obj.Base;
DPRINT_INFO(VMBUS_DRV, "device object (%p) set to driver object (%p)", &device_ctx->device_obj, device_ctx->device_obj.Driver); |
