staging: gs_fpgaboot: drop wrapper function ‘finish_driver’
Author: Eva Rachel Retuya <eraretuya@gmail.com>
Remove the function 'finish_driver' since a direct call to
platform_device_unregister() is intuitive enough to signify the original
intention of the function being removed. Coccinelle semantic patch used to
detect this:
identifier wrapper, func;
type T;
*T wrapper(...)
	return func(...);
	func(...);
Signed-off-by: Eva Rachel Retuya
 drivers/staging/gs_fpgaboot/gs_fpgaboot.c | 9 ++-------
 1 file changed, 2 insertions(+), 7 deletions(-)
diff --git a/drivers/staging/gs_fpgaboot/gs_fpgaboot.c b/drivers/staging/gs_fpgaboot/gs_fpgaboot.c
index fe3a6bc..7b7c978 100644
--- a/drivers/staging/gs_fpgaboot/gs_fpgaboot.c
+++ b/drivers/staging/gs_fpgaboot/gs_fpgaboot.c
@@ -281,11 +281,6 @@ static int init_driver(void)
 	return PTR_ERR_OR_ZERO(firmware_pdev);
-static void finish_driver(void)
-	platform_device_unregister(firmware_pdev);
 static int gs_fpgaboot(void)
 	int err;
@@ -370,14 +365,14 @@ static int __init gs_fpgaboot_init(void)
 	return 0;
 errout:
-	finish_driver();
+	platform_device_unregister(firmware_pdev);
 	return err;
 static void __exit gs_fpgaboot_exit(void)
-	finish_driver();
 	pr_info("FPGA image download module removed\n");
BtrLinux
Privacy Overview
