Staging: goldfish: use !x instead of x == NULL
Author: Somya Anand <somyaanand214@gmail.com>
Functions like devm_kzalloc, kmalloc_array, devm_ioremap,
usb_alloc_urb, alloc_netdev return NULL as a return value on failure.
Generally, When NULL represents failure, !x is commonly used.
This patch cleans up the tests on the results of these functions, thereby
using !x instead of x == NULL or NULL == x. This is done via following
coccinelle script:
@prob_7@
identifier x;
statement S;
x = devm_kzalloc(...);
x = usb_alloc_urb(...);
x = kmalloc_array(...);
x = devm_ioremap(...);
x = alloc_netdev(...);
- if(NULL == x)
+ if(!x)
S
Further we have used isomorphism characteristics of coccinelle to
indicate x == NULL and NULL == x are equivalent. This is done via
following iso script.
Expression
@ is_null @ expression X; @@
X == NULL <=> NULL == X
Signed-off-by: Somya Anand
drivers/staging/goldfish/goldfish_audio.c | 2 +-
drivers/staging/goldfish/goldfish_nand.c | 6 +++---
2 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/staging/goldfish/goldfish_audio.c b/drivers/staging/goldfish/goldfish_audio.c
index c7f8f1c..81abf98 100644
--- a/drivers/staging/goldfish/goldfish_audio.c
+++ b/drivers/staging/goldfish/goldfish_audio.c
@@ -273,7 +273,7 @@ static int goldfish_audio_probe(struct platform_device *pdev)
dma_addr_t buf_addr;
data = devm_kzalloc(&pdev->dev, sizeof(*data), GFP_KERNEL);
- if (data == NULL)
+ if (!data)
return -ENOMEM;
spin_lock_init(&data->lock);
init_waitqueue_head(&data->wait);
diff --git a/drivers/staging/goldfish/goldfish_nand.c b/drivers/staging/goldfish/goldfish_nand.c
index d68f216..213877a 100644
--- a/drivers/staging/goldfish/goldfish_nand.c
+++ b/drivers/staging/goldfish/goldfish_nand.c
@@ -330,7 +330,7 @@ static int goldfish_nand_init_device(struct platform_device *pdev,
mtd->priv = nand;
name = devm_kzalloc(&pdev->dev, name_len + 1, GFP_KERNEL);
- if (name == NULL)
+ if (!name)
return -ENOMEM;
mtd->name = name;
@@ -383,7 +383,7 @@ static int goldfish_nand_probe(struct platform_device *pdev)
return -ENODEV;
base = devm_ioremap(&pdev->dev, r->start, PAGE_SIZE);
- if (base == NULL)
+ if (!base)
return -ENOMEM;
version = readl(base + NAND_VERSION);
@@ -399,7 +399,7 @@ static int goldfish_nand_probe(struct platform_device *pdev)
nand = devm_kzalloc(&pdev->dev, sizeof(*nand) +
sizeof(struct mtd_info) * num_dev, GFP_KERNEL);
- if (nand == NULL)
+ if (!nand)
return -ENOMEM;
mutex_init(&nand->lock); |
- if (data == NULL)
+ if (!data)
return -ENOMEM;
mtd->priv = nand;
- if (name == NULL)
+ if (!name)
return -ENOMEM;
mtd->name = name;
return -ENODEV;
- if (base == NULL)
+ if (!base)
return -ENOMEM;
- if (nand == NULL)
+ if (!nand)
return -ENOMEM;
