staging: goldfish: remove extra parentheses around function arguments
Author: Aya Mahfouz <mahfouz.saif.elyazal@gmail.com>
Removes extra parentheses around function arguments. Issue
detected and resolved using the following coccinelle script:
expression e;
identifier f;
f(...,
e
Signed-off-by: Aya Mahfouz
 drivers/staging/goldfish/goldfish_audio.c | 8 ++++----
 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/staging/goldfish/goldfish_audio.c b/drivers/staging/goldfish/goldfish_audio.c
index f200359..c7f8f1c 100644
--- a/drivers/staging/goldfish/goldfish_audio.c
+++ b/drivers/staging/goldfish/goldfish_audio.c
@@ -125,8 +125,8 @@ static ssize_t goldfish_audio_read(struct file *fp, char __user *buf,
 		length = (count > READ_BUFFER_SIZE ? READ_BUFFER_SIZE : count);
 		AUDIO_WRITE(data, AUDIO_START_READ, length);
-		wait_event_interruptible(data->wait, (data->buffer_status &
-					 AUDIO_INT_READ_BUFFER_FULL));
+		wait_event_interruptible(data->wait, data->buffer_status &
+					 AUDIO_INT_READ_BUFFER_FULL);
 		length = AUDIO_READ(data, AUDIO_READ_BUFFER_AVAILABLE);
@@ -154,9 +154,9 @@ static ssize_t goldfish_audio_write(struct file *fp, const char __user *buf,
 		if (copy > WRITE_BUFFER_SIZE)
 			copy = WRITE_BUFFER_SIZE;
 					(AUDIO_INT_WRITE_BUFFER_1_EMPTY |
-					AUDIO_INT_WRITE_BUFFER_2_EMPTY)));
+					AUDIO_INT_WRITE_BUFFER_2_EMPTY));
 		if ((data->buffer_status & AUDIO_INT_WRITE_BUFFER_1_EMPTY) != 0)
 			kbuf = data->write_buffer1;
BtrLinux
Privacy Overview
