Staging: gdm724x: Replace random_ether_addr with eth_random_addr
Author: Bhumika Goyal <bhumirks@gmail.com>
The macro random_ether_addr is calling the function eth_random_addr.
Therefore, the call to random_ether_addr can be replaced with
eth_random_addr.
Done using coccinelle:
expression addr;
- random_ether_addr(addr);
+ eth_random_addr(addr);
Signed-off-by: Bhumika Goyal
 drivers/staging/gdm724x/gdm_lte.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/staging/gdm724x/gdm_lte.c b/drivers/staging/gdm724x/gdm_lte.c
index 98570c6..bb55219 100644
--- a/drivers/staging/gdm724x/gdm_lte.c
+++ b/drivers/staging/gdm724x/gdm_lte.c
@@ -855,7 +855,7 @@ static void form_mac_address(u8 *dev_addr, u8 *nic_src, u8 *nic_dest,
 	/* Create random nic src and copy the first
 	 * 3 bytes to be the same as dev_addr
-	random_ether_addr(nic_src);
+	eth_random_addr(nic_src);
 	memcpy(nic_src, dev_addr, 3);
 	/* Copy the nic_dest from dev_addr*/
BtrLinux
Privacy Overview
