staging: ft1000: Remove useless return variables
Author: Peter Senna Tschudin <peter.senna@gmail.com>
This patch remove variables that are initialized with a constant,
are never updated, and are only used as parameter of return.
Return the constant instead of using a variable.
Verified by compilation only.
The coccinelle script that find and fixes this issue is:
type T;
constant C;
identifier ret;
- T ret = C;
... when != ret
- return ret;
+ return C;
Signed-off-by: Peter Senna Tschudin
 drivers/staging/ft1000/ft1000-usb/ft1000_download.c | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/staging/ft1000/ft1000-usb/ft1000_download.c b/drivers/staging/ft1000/ft1000-usb/ft1000_download.c
index cab9cdf..65f9801 100644
--- a/drivers/staging/ft1000/ft1000-usb/ft1000_download.c
+++ b/drivers/staging/ft1000/ft1000-usb/ft1000_download.c
@@ -522,7 +522,6 @@ static void usb_dnld_complete(struct urb *urb)
 static int write_blk_fifo(struct ft1000_usb *ft1000dev, u16 **pUsFile,
 			  u8 **pUcFile, long word_length)
-	int Status = 0;
 	int byte_length;
 	byte_length = word_length * 4;
@@ -547,7 +546,7 @@ static int write_blk_fifo(struct ft1000_usb *ft1000dev, u16 **pUsFile,
 	*pUsFile = *pUsFile + (word_length << 1);
 	*pUcFile = *pUcFile + (word_length << 2);
-	return Status;
+	return 0;
 static int scram_start_dwnld(struct ft1000_usb *ft1000dev, u16 *hshake,
BtrLinux
Privacy Overview
